  3. Compile Error
Compile error
By fernando , 28 August, 2020
What compiler do you use for ARM and what operating system?
When compiling it gives me the error that appears in the image.
Thank you.
5 years 11 months ago
I believe that your compiler is not supporting float32 and float64.
Open gxignore.h file and un-comment DLMS_IGNORE_FLOAT32 and DLMS_IGNORE_FLOAT64
Let me know if you have any problems.
fernando
after doing it, now it gives me this error.
fernando
in another compiler it gives me this error.
Thank you.
What compilers you are using? DLMS_IGNORE_FLOAT64 issue if fixed, but your second looks strange.
Get the latest version.
fernando
We have tested on a debian 10: with the following compiler arm-linux-gnueabi-gcc:
COLLECT_GCC=arm-linux-gnueabi-gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc-cross/arm-linux-gnueabi/8/lto-wrapper
Target: arm-linux-gnueabi
Configured with: ../src/configure -v --with-pkgversion='Debian 8.3.0-2' --with-bugurl=file:///usr/share/doc/gcc-8/README.Bugs --enable-languages=c,ada,c++,go,d,fortran,objc,obj-c++ --prefix=/usr --with-gcc-major-version-only --program-suffix=-8 --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-libitm --disable-libquadmath --disable-libquadmath-support --enable-plugin --enable-default-pie --with-system-zlib --with-target-system-zlib --enable-multiarch --disable-sjlj-exceptions --with-arch=armv5te --with-float=soft --disable-werror --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=arm-linux-gnueabi --program-prefix=arm-linux-gnueabi- --includedir=/usr/arm-linux-gnueabi/include
Thread model: posix
gcc version 8.3.0 (Debian 8.3.0-2)
AND IT GIVES US THE FOLLOWING ERROR:
/gxvalueeventargs.c: In function ‘vec_attach’:
src/gxvalueeventargs.c:64:15: warning: assignment to ‘gxValueEventArg **’ {aka ‘struct <anonymous> **’} from incompatible pointer type ‘gxValueEventArg *’ {aka ‘struct <anonymous> *’} [-Wincompatible-pointer-types]
arr->data = value;
Compiled src/gxvalueeventargs.c successfully!
Compiled src/dlmsSettings.c successfully!
src/notify.c: In function ‘notify_parsePush’:
src/notify.c:278:43: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
arr_push(items, key_init(obj, (void*)(uint64_t)index));
Compiled src/notify.c successfully!
Compiled src/message.c successfully!
src/variant.c: In function ‘convert’:
src/variant.c:1612:37: error: ‘dlmsVARIANT’ {aka ‘struct tagdlmsVARIANT’} has no member named ‘fltVal’; did you mean ‘pfltVal’?
sprintf(buff, "%f", tmp.fltVal);
pfltVal
src/variant.c:1628:38: error: ‘dlmsVARIANT’ {aka ‘struct tagdlmsVARIANT’} has no member named ‘dblVal’; did you mean ‘pdblVal’?
sprintf(buff, "%lf", tmp.dblVal);
pdblVal
src/variant.c:1763:58: error: ‘dlmsVARIANT’ {aka ‘struct tagdlmsVARIANT’} has no member named ‘fltVal’; did you mean ‘pfltVal’?
sscanf((char*)tmp.strVal->data, "%f", &item->fltVal);
pfltVal
src/variant.c:1774:59: error: ‘dlmsVARIANT’ {aka ‘struct tagdlmsVARIANT’} has no member named ‘dblVal’; did you mean ‘pdblVal’?
sscanf((char*)tmp.strVal->data, "%lf", &item->dblVal);
pdblVal
make: *** [makefile:33: obj/variant.o] Error 1
WE HAVE ALSO TESTED ON AN UBUNTU 10.04 WITH THE ARM-LINUX-GCC COMPILER:
arm-linux-gcc (GCC) 3.3.2
Copyright (C) 2003 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE
GETTING THE FOLLOWING ERRORS
In file included from src/../include/helpers.h:46,
from src/apdu.c:36:
src/../include/variant.h:134: warning: declaration does not declare anything
Compiled src/apdu.c successfully!
from src/bitarray.c:44:
Compiled src/bitarray.c successfully!
from src/bytebuffer.c:47:
Compiled src/bytebuffer.c successfully!
from src/ciphering.c:53:
Compiled src/ciphering.c successfully!
In file included from src/../include/dlmssettings.h:41,
from src/../include/apdu.h:36,
from src/client.c:44:
src/client.c: In function 'cl_getApplicationAssociationRequest':
src/client.c:337: error: 'dlmsVARIANT' has no member named 'byteArr'
src/client.c:338: error: 'dlmsVARIANT' has no member named 'byteArr'
src/client.c:339: error: 'dlmsVARIANT' has no member named 'byteArr'
src/client.c:340: error: 'dlmsVARIANT' has no member named 'byteArr'
src/client.c:341: error: 'dlmsVARIANT' has no member named 'byteArr'
src/client.c: In function 'cl_parseApplicationAssociationResponse':
src/client.c:419: error: 'dlmsVARIANT' has no member named 'byteArr'
src/client.c:458: error: 'dlmsVARIANT' has no member named 'byteArr'
src/client.c:459: error: 'dlmsVARIANT' has no member named 'byteArr'
src/client.c: In function 'cl_parseLNObjects':
src/client.c:526: error: 'dlmsVARIANT' has no member named 'Arr'
src/client.c:530: error: 'dlmsVARIANT' has no member named 'Arr'
src/client.c:531: error: 'dlmsVARIANT' has no member named 'Arr'
src/client.c:532: error: 'dlmsVARIANT' has no member named 'Arr'
src/client.c:533: error: 'dlmsVARIANT' has no member named 'Arr'
src/client.c:541: error: 'dlmsVARIANT' has no member named 'Arr'
src/client.c:552: error: 'dlmsVARIANT' has no member named 'Arr'
src/client.c:557: error: 'dlmsVARIANT' has no member named 'byteArr'
src/client.c: In function 'cl_parseSNObjects':
src/client.c:628: error: 'dlmsVARIANT' has no member named 'Arr'
src/client.c:633: error: 'dlmsVARIANT' has no member named 'Arr'
src/client.c:634: error: 'dlmsVARIANT' has no member named 'Arr'
src/client.c:635: error: 'dlmsVARIANT' has no member named 'Arr'
src/client.c:636: error: 'dlmsVARIANT' has no member named 'Arr'
src/client.c:658: error: 'dlmsVARIANT' has no member named 'byteArr'
src/client.c: In function 'cl_writeLN':
src/client.c:1592: error: 'dlmsVARIANT' has no member named 'byteArr'
src/client.c: In function 'cl_methodLN':
src/client.c:1736: error: 'dlmsVARIANT' has no member named 'byteArr'
src/client.c: In function 'cl_methodSN':
src/client.c:1782: error: 'dlmsVARIANT' has no member named 'byteArr'
make: *** [obj/client.o] Error 1
fernando
WE HAVE ALSO TESTED IT WITH
Ubuntu 16.04 con arm-linux-gnueabi-gcc –version:
arm-linux-gnueabi-gcc (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.9) 5.4.0 20160609
Copyright (C) 2015 Free Software Foundation, Inc.
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
COMPILE THE DEVELOPMENT WAS WELL
BUT WHEN COMPILING THE CLIENT IT GIVES THIS ERROR
Compiled src/getopt.c successfully!
Compiled src/connection.c successfully!
Compiled src/main.c successfully!
src/communication.c: In function 'com_readRowsByEntry2':
src/communication.c:1212:9: warning: format not a string literal and no format arguments [-Wformat-security]
printf(str);
Compiled src/communication.c successfully!
/usr/bin/ld: obj/getopt.o: Relocations in generic ELF (EM: 40)
obj/getopt.o: error adding symbols: File in wrong format
collect2: error: ld returned 1 exit status
makefile:26: recipe for target 'bin/gurux.dlms.client.bin' failed
make: *** [bin/gurux.dlms.client.bin] Error 1
thanks you
You need to open gxigone and uncomment this line:
#define DLMS_IGNORE_MALLOC
or add -DDLMS_IGNORE_MALLOC to the compiler flags.
  • nostra
  • cuiVEAwINCoyynjjn
  • qlMlMNfbqjNumKgGFIo
  • randx-super.ru
  • Arturolooth
