  3. Not Able To Write From Director
Not able to write from Director
By Bhaumik , 31 August, 2020
I am trying to write Passive Relay Time (1.0.96.128.30.255) into IS15959-2 meter.
In that, If I change any value of structure and try to write, I got an error message as shown in the attached image. Please check.
Following is the response from meter:
<Structure>
<UInt32 Value="500" />
<UInt32 Value="900" />
<UInt8 Value="4" />
<OctetString Value="FF FF FF FF FF FF FF FF FF FF FF FF" />
</Structure>
6 years ago
Please, don't use images with this size. They are compressed and I can't see the error message.
I tested this and it worked. What version from GXDLMSDirector you are using?
Bhaumik
6 years ago
I am using 8.2.2008.2701 GXDLMSDirector.
And the error message in the screenshot was "String was not recognized as a valid DateTime."
6 years ago
I believe that you have changed UIType to DateTime. Select "Passive Relay Time" object. Then select "Access rights" tab and check Type and UIType for attribute #2.
Check that Type is structure and UIType is None. If Type is something else, read the association view again. If UIType is something else, you can just change it.
Bhaumik
6 years ago
Yup, The data type for attribute #2 was DateTime. After updating UIType to None it is working properly.
Thanks for the quick update.
Bhaumik
6 years ago
In the same obis code Passive Relay Time (1.0.96.128.30.255) into IS15959-2 meter, the last object
is DateTime and in that, we got byte array. So is that possible to get it in a proper date-time format?
<Structure>
<UInt8 Value="4" />
</Structure>
6 years ago
Meter sends it in a byte array. It might be possible. I don't have an Indian Standard specification with me at the moment. What are the descriptions of those fields?
Bhaumik
6 years ago
This obis code actually manufacture specific and description added in IS16444 only.
From the description, Fields are as below :
There is no data type provided in description.
-Time interval between autoreconnection attempt
-Lockout time Period
-Number of auto-reconnection attempts
-Activation date-time
6 years ago
This is possible. We need to create a new device template for this manufacturer.
I need to know the meter manufacturer name so we can create the template.
Bhaumik
6 years ago
I am testing the meter of Zen Manufacturer supporting the IS16444 standard.
6 years ago
I checked and Zen has a Flag ID. That is good and we can add device settings for ZEN.
The next version is released next week and support for this feature is there.
6 years ago
There is a new version released. This functionality is added to the new version.
Update to the latest version.
You need to select ZenMeteras Solutions as a manufacturer and then read the association view again.
You should see UI like in the picture.
Bhaumik
6 years ago
I have checked with the latest Director.
For Passive Relay Time, It has ReadWrite access and from Director not able to write.
For Active Relay Time, it has Read-only access and from Director, it gives a writeable textbox.
Please check the attached images for both obis codes respectively.
Bhaumik
6 years ago
Please find Active Relay Time
Please find Active Relay Time image
6 years ago
You need to change the value if you want to write it. You didn't talk from Active Relay Time and it's not added. We'll add it later.
6 years ago
Select "Access rights" tab and check access level for Active Relay Time image. I believe it's ReadWrite and not Read.
Bhaumik
6 years ago
Yes, I haven't informed regarding Active Relay Time as it is read only access.
And In Passive Relay Time, We are trying to change the value in grid but it is not updating.
Please check for Passive Relay Time write operation once
6 years ago
After you have set new values you need to press "Write" -button to write value to the meter.
Write button is gray until you have change the value.
In your previous post you wrote: For Active Relay Time, it has Read-only access and from Director, it gives a writeable textbox.
Textbox is writable because the meter returns the ReadWrite access level or you have changed it from the "Access rights" tab. Check that.
Bhaumik
6 years ago
In the latest Director, When I am read Passive Realy Time, the DateTime value not shown.
Please check this in the attached image.
6 years ago
The reason is the date-time value (FF FF FF FF FF FF FF FF FF FF FF FF). This means that the date-time value is not used. Try to write a new date-time to the meter and read it again.
KhushbuBadheka
6 years ago
As per the screen shot, you can see that I received proper data for date time. However, can not write it properly.
Thanks.
6 years ago
Please, don't use images. They are compressed and I can't read them. As far as I can see from the pic, year, month, day, hour, and minute are not used.
KhushbuBadheka
6 years ago
As per your previous reply ;
"The reason is the date-time value (FF FF FF FF FF FF FF FF FF FF FF FF). This means that the date-time value is not used. Try to write a new date-time to the meter and read it again."
However, we are unable to write in the meter, due to non responsive UI of the Director.
Please find reading data PDU for your reference.
<HDLC len="3E" >
<TargetAddress Value="30" />
<SourceAddress Value="1" />
<FrameType Value="1E" />
<PDU>
<!-- Invocation Counter: 6 -->
<!-- Decrypt data: C4 01 81 00 02 04 06 00 00 01 2C 06 00 00 03 84 11 04 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF
<GetResponse>
<GetResponseNormal>
# Priority: High, ServiceClass: UnConfirmed, ID: 1
<InvokeIdAndPriority Value="81" />
<Result>
<Data>
<Structure Qty="04" >
<UInt32 Value="0000012C" />
<UInt32 Value="00000384" />
<UInt8 Value="04" />
<OctetString Value="FFFFFFFFFFFFFFFFFF8000FF" />
</Structure>
</Data>
</Result>
</GetResponseNormal>
</GetResponse>
<ded_GetResponse Value="3000000006AA4FB183DD6D514BE0D8CED4E55D352E26F140C64E27A3702D6FEFE9E0AF18D8AC55B2E5A1423F0EDF8686F4" />
</PDU>
</HDLC>
Thanks.
6 years ago
You need to give a new date-time value in your localization format. Like in the picture below. When you double click the cell you can change the value.
KhushbuBadheka
6 years ago
Thanks Mikko,
Thanks Mikko,
We can write properly from the latest director. However, we are getting error code 11 (Unavailable Object's error) on each writing from tour source. We are using latest DLMS package to write.
FYI : We checked that in both sources (director and ours) writing value structure list has same values to be written.
Can you please add Passive Relay Time object to Indian Stranded?
Khushbu Badheka
6 years ago
Are you using Gurux DLMS stack on the server-side or something else?
At some point, you told me that this Passive Relay Time is manufacturer specific and it's not defined in the Indian standard. For that reason, it's added only to ZenMeter Solutions device template.
KhushbuBadheka
6 years ago
Thanks Mikko for the quick
Thanks Mikko for the quick reply.
However, Zen Meters is the Indian manufacture which is belongs to IS 16444 so please update this in IS.
6 years ago
We can't make custom modifications. I'll first ask this from a few Indian meter manufacturers how they have implemented this.
KhushbuBadheka
6 years ago
Thanks Mikko,
Thanks Mikko,
You can find this in IS16444 standard and Zen meter is following it too.
FYI : Indian Standard is made of IS15959 and IS16444 both.
Khushbu
KhushbuBadheka
6 years ago
Please find IS 16444:2015
Please find IS 16444:2015 documentation.
Bhaumik
6 years ago
Have you confirmed with other Indian manufacturers?
Can you please provide an update
6 years ago
We have spoken from it. IS 16444:2015 doesn't define the structure of Passive or active Relay Time. They have implemented it differently. For this reason, it can't be added to the Indian Standard template.
chauvaux
5 years 4 months ago
I cannot write a meter Genus from director with hls security level.
The error message is : Service error read exception.Access scope of access violated.
The object is : 1.0.0.8.4.255
I have modified the access rights as followed :
Access : ReadWrite (Write doesn't work too)
UIType none (UInt16 doesn't work too)
Can you help please.
Best regards
Marc Chauvaux
In reply to Hello, by chauvaux
Hi Marc,
Hi Marc,
If you modify the access level in GXDLMSDirector it doesn't affect the meter. Try to refresh the meter.
If the access level is Read, you can't write this value for the meter.
