  3. Decode Frame From DLMSTranslator
Decode frame from DLMSTranslator
By Bhaumik , 28 August, 2020
I am trying to decode the frame from using DLMSTranslator from GXDLMSDirector.
In that, I have configured all secured details in Ciphering. Still not able to decode a secured HDLC frame from that.
Can you please provide a suggestion on how to decode frame using Translator
6 years 2 months ago
Can you see any output from the frame? Can you paste the frame here so I can check it?
Bhaumik
Following is the request frame which I want to decode
7E A0 48 03 61 98 F4 5D E6 E6 00 C9 3A 30 00 00 00 0F C5 92 EE 6A 25 AC FB AE 36 AA B8 13 44 8A 0C F3 FB B8 07 8A 8A CD 4B AF 43 93 FD 3C 59 02 01 A5 97 0B 28 03 00 4C 61 27 33 79 B7 4D CB 09 23 83 E7 44 D9 3E FD 26 94 7E
Your frame looks correct. Select "Ciphering" -tab and set system title, block cipher key, and authentication key. Then you can decrypt the message if keys are correct. There is a new feature in the latest GXDLMSDirector. It'll update system titles automatically if you add all the messages to the messages view.
