By mohamadop , 12 August, 2020 Forums DLMSDirector HOW TO GET the physical server from ID meter ? for example : what is the physical server of ID meter =35074728 Thanks Hi, Hi, There are differences between the meters, so I can't say this for sure but usually DLMS meters are using this formula: SN % 10000 + 1000 BR, Mikko It's 5728 the right answer It's 5728 the right answer with this formula ? Hi, Hi, Yes. Remember that meter manufacturer might use different formulas if this is not working. BR, Mikko
SN % 10000 + 1000
