  3. Compilation Warnings
By José Torres , 5 August, 2020
I just compiled gurux.dlms.c client demo and got 2 warnings that migth cause some problem:
src/gxset.c: In function ‘cosem_setSwitchTable’:
src/gxset.c:7811:44: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
src/gxvalueeventargs.c:64:15: warning: assignment to ‘gxValueEventArg **’ {aka ‘struct <anonymous> **’} from incompatible pointer type ‘gxValueEventArg *’ {aka ‘struct <anonymous> *’} [-
Wincompatible-pointer-types]
Is there any policy regarding warnings?
Torres
6 years 1 month ago
Hi Torres,
Hi Torres,
Thank you for this info. Those warnings are now fixed. We try to make a new release tomorrow.
José Torres
6 years 1 month ago
thanks for the reply. These warnings are the ones that I think could be critical, but there are a lot more regarding unused variables and use o uninitialized variables...
Any way, thanks for promptly response.
Best Regards,
José Torres.
6 years 1 month ago
What compiler you are using?
José Torres
6 years 1 month ago
I am using gcc GNU Tools for STM32, version 7-2018-q2-update, with the following flags:
-mcpu=cortex-m4 -std=gnu11 -g3 -Og -ffunction-sections -fdata-sections -Wall -Wextra -fstack-usage --specs=nano.specs -mfpu=fpv4-sp-d16 -mfloat-abi=hard -mthumb.
However, I have used also gcc from cygwin on Windows 10 and get the warnings too.
José Torres
6 years 1 month ago
Hi José,
Hi José,
Have you got the latest version from Github? We are also using Cygwin, but I just realized that we are not using malloc with it (DLMS_IGNORE_MALLOC). We'll check this with the malloc to see if we can get more errors.
José Torres
6 years 1 month ago
After update to the latest version from GitHub, I got the following warnings when compiling for STM32:
gurux/src/dlms.c:1532:9: warning: unused parameter 'len' [-Wunused-parameter]
gurux/src/dlms.c:1706:19: warning: unused parameter 'settings' [-Wunused-parameter]
gurux/src/dlms.c:4239:19: warning: unused parameter 'first' [-Wunused-parameter]
gurux/src/dlms.c:2474:12: warning: 'len' may be used uninitialized in this function [-Wmaybe-uninitialized]
gurux/src/gxarray.c:226:74: warning: unused parameter 'itemSize' [-Wunused-parameter]
gurux/src/gxget.c:819:19: warning: unused parameter 'settings' [-Wunused-parameter]
gurux/src/gxinvoke.c:1607:25: warning: unused parameter 'settings' [-Wunused-parameter]
gurux/src/gxget.c:4890:19: warning: unused parameter 'settings' [-Wunused-parameter]
gurux/src/gxget.c:4894:19: warning: unused parameter 'appendAA' [-Wunused-parameter]
gurux/src/gxget.c:807:20: warning: 'pduSize' may be used uninitialized in this function [-Wmaybe-uninitialized]
gurux/src/gxget.c:1139:18: warning: 'pduSize' may be used uninitialized in this function [-Wmaybe-uninitialized]
gurux/src/gxget.c:2250:18: warning: 'pduSize' may be used uninitialized in this function [-Wmaybe-uninitialized]
gurux/src/gxget.c:2385:20: warning: 'pduSize' may be used uninitialized in this function [-Wmaybe-uninitialized]
gurux/src/gxset.c:7552:19: warning: unused parameter 'settings' [-Wunused-parameter]
gurux/src/gxset.c:7576:19: warning: unused parameter 'settings' [-Wunused-parameter]
gurux/src/gxset.c:7607:19: warning: unused parameter 'settings' [-Wunused-parameter]
gurux/src/gxset.c:7646:19: warning: unused parameter 'settings' [-Wunused-parameter]
gurux/src/gxset.c:7703:19: warning: unused parameter 'settings' [-Wunused-parameter]
gurux/src/gxset.c:8093:19: warning: unused parameter 'settings' [-Wunused-parameter]
gurux/src/gxset.c:8127:19: warning: unused parameter 'settings' [-Wunused-parameter]
gurux\include\gxmem.h:48:30: warning: 'ipcpItem' may be used uninitialized in this function [-Wmaybe-uninitialized]
gurux/src/gxset.c:4534:9: warning: 'ret' may be used uninitialized in this function [-Wmaybe-uninitialized]
gurux/src/gxset.c:4992:9: warning: 'ret' may be used uninitialized in this function [-Wmaybe-uninitialized]
gurux/src/helpers.c:708:26: warning: unused parameter 'scaler' [-Wunused-parameter]
gurux/src/notify.c:364:43: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
gurux/src/server.c:3248:23: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
gurux/src/serverevents.c:34:34: warning: unused parameter 'str' [-Wunused-parameter]
gurux/src/serverevents.c:34:43: warning: unused parameter 'err' [-Wunused-parameter]
gurux/src/serverevents.c:50:35: warning: unused parameter 'str' [-Wunused-parameter]
gurux/src/serverevents.c:50:52: warning: unused parameter 'ot' [-Wunused-parameter]
gurux/src/serverevents.c:50:77: warning: unused parameter 'ln' [-Wunused-parameter]
gurux/src/serverevents.c:50:85: warning: unused parameter 'err' [-Wunused-parameter]
gurux/src/variant.c:389:12: warning: this statement may fall through [-Wimplicit-fallthrough=]
gurux/src/variant.c:824:9: warning: 'ret' may be used uninitialized in this function [-Wmaybe-uninitialized]
José Torres
6 years 1 month ago
Thank you very much for this info. We'll fix those warnings in next week. I believe that must make toolchain for STM32.
José Torres
6 years 1 month ago
no problem, thanks for reply. I am looking forward for the next update.
Best Regards,
José Torres
