  3. Gurux.DLMS.CPP TCP Supports IPv6?
Gurux.DLMS.CPP TCP supports IPv6?
By pradson , 12 July, 2020
I am using Gurux.DLMS.cpp lib for my project. Currently I am using TCP based connection. Can Gurux.DLMS.cpp lib supports TCP/IPv6 connection? If not, then what should I do to implement IPv6 type connection in my project?
Kindly suggest me asap.
Pradson
6 years 4 months ago
Hi Pradson,
Hi Pradson,
CGXDLMSIp6Setup is implemented and tests are started in the following weeks. New version is released in August.
The client example doesn't support IP v4. This is updated also in the next release in August.
If you want, you can add support by your self in int CGXCommunication::Connect -function.
pradson
6 years 1 month ago
How are you? I hope you are doing well.
I had asked to you earlier about CGXDLMSIp6Setup implementation in Gurux.DLMS.cpp lib. You had said that CGXDLMSIp6Setup implementation will be release in August 2020.
Has CGXDLMSIp6Setup implemented in Gurux.DLMS.cpp lib? If yes, then how could I use this suggest me?
Pradson
6 years 1 month ago
It's done, but not released as open source. I created an issued from this and a new Open source version is released today.
https://www.gurux.fi/node/16974
pradson
6 years 1 month ago
Thanks a lot Mikko.
Thanks a lot Mikko.
pradson
6 years ago
How are you?
I have a question regarding CGXDLMSIp6Setup object testing. Actually, I have not any IPV6 compatible hardware or software device. So I am unable to test CGXDLMSIp6Setup object at my end.
Kindly suggest me any software(Simulator) or any alternate way so that I could test CGXDLMSIp6Setup object at my end.
Thanks & Regards,
Pradson
6 years ago
You can use server example. It supports GXDLMSIp6Setup.
https://github.com/Gurux/Gurux.DLMS.Net/tree/master/Gurux.DLMS.Server.E…
pradson
6 years ago
Does Gurux.DLMS.cpp/GuruxDLMSServerExample not support GXDLMSIp6Setup?
Pradson
6 years ago
Hi Pradson,
Hi Pradson,
GuruxDLMSServerExample supports GXDLMSIp6Setup.
https://github.com/Gurux/Gurux.DLMS.Net/blob/751bb67d22bb379dee47f05076…
pradson
4 years 5 months ago
I am using Gurux.DLMS.cpp and I have tested with IPv4 setup. I just wanted to know from your end regarding CGXDLMSIp6Setup. Is any your customer which using stack of CGXDLMSIp6Setup for smart metering in India?
Thanks & Regards,
Pradson
Hi Pradson,
Hi Pradson,
In my mind, all are using IPv4 at the moment, but it is changing. There are more meters that are using IPv6.
pradson
In reply to Hi Pradson, by Kurumi
Thanks a lot for prompt reply.
Kindly share the link of latest version of the stack which includes CGXDLMSIp6Setup.
Thanks & Regards,
Pradson
You can get it from GitHub.
https://github.com/Gurux/Gurux.DLMS.cpp
pradson
May I know the more information regarding CGXDLMSIp6Setup?
As you said there is no any customer which using CGXDLMSIp6Setup in India. How many customers which using stack of CGXDLMSIp6Setup for smart metering all over world? The purpose of knowing this information just for my knowledge.
Thanks & Regards,
Pradson
There are several meter models that are supporting IPv6. I can't say any exact numbers. IPv6 is coming more important when LPWAN and Wi-Sun Over the Air communication channels are used.
