  3. File Correction
File correction
Profile picture for user mahsen
By mahsen , 1 June, 2020
In the "apdu.c" file, the "apdu_parseUserInformation" function has a problem,
In the case, lines 538 to 567 must be replaced with the following code,
// Optional usage field of the proposed quality of service component
if ((ret = bb_getUInt8(data, &tag)) != 0)
return ret;
// Skip if used.
if (tag != 0)
if ((ret = bb_getUInt8(data, &settings->qualityOfService)) != 0)
return ret;
// Optional usage field of the negotiated quality of service
// component
return ret;
// Skip if used.
if (tag != 0)
if ((ret = bb_getUInt8(data, &len)) != 0)
return ret;
data->position = (data->position + len);
Thank you,
Mahsen
6 years 2 months ago
Hi Mahsen,
Hi Mahsen,
There is no length in QualityOfService because it's a byte. Can you tell me why you want to change this?
Your changes will work when QualityOfService is not used, but otherwise, it fails.
mahsen
6 years 1 month ago
This code was originally like
This code was originally like this, then corrected in the previous message,
// component
return ret;
// Skip if used.
if (tag != 0)
return ret;
return ret;
// Skip if used.
if (tag != 0)
return ret;
For example, in the analysis of the following line, an error was created,
because "QualityOfService" is a byte,
00 01 00 01 00 01 00 39 60 37 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 31 32 33 34 35 36 37 38 BE 11 04 0F 01 00 01 01 00 06 5F 1F 04 00 60 BE DD 04 00
Mahsen
6 years 1 month ago
Hi Mahsen,
Hi Mahsen,
You are right. You need to remove this line:
Tests are started and we are releasing a new version where this is fixed tomorrow.
mahsen
6 years 1 month ago
Hi I'm glad I helped؈ Mahsen
I'm glad I helped
Mahsen
mahsen
6 years 1 month ago
Why GXDLMSDirector wrapper remove "gateway bytes" when using "gateway" and "encryption" together in the request?
Mahsen
6 years 1 month ago
Gateway bytes are added to Gateway.NetworkId and Gateway.PhysicalDeviceAddress.
The reason is to try to make it easier to use.
mahsen
6 years 1 month ago
I have no problem to used gateway when security select "none",
but Gateway bytes are not added to Gateway.NetworkId and Gateway.PhysicalDeviceAddress when i am select "AuthenticationEncryption",
Mahsen
6 years ago
Hi Mahsen,
Hi Mahsen,
Are you using a real gateway or our server simulator? I need to check are NetworkId and PhysicalDeviceAddress encrypted.
  • Tyronesok
  • Dawley07
  • nostra
  • cuiVEAwINCoyynjjn
  • qlMlMNfbqjNumKgGFIo
