  3. GXStructure
GXStructure
By Srinivasan , 22 June, 2020
Im trying to do write operation using Java.
Code:
GXStructure input = new GXStructure();
input.add(0, 400);
input.add(1, 1800);
input.add(2, 4);
input.add(3, new GXDateTime(2020, 10, 22, 0,0,0,0));
Above code generate the following PDU
<SetRequest>
<SetRequestNormal>
<Value>
<Structure Qty="04" >
<Int32 Value="400" />
<Int32 Value="1800" />
<Int32 Value="4" />
# 7/27/2020 9:55:00 PM
<Date Time Value="07E4071BFF0A3700FF014A00" />
</Structure>
</Value>
</SetRequestNormal>
</SetRequest>
But device report it as error like "Access Error : Device reports a unmatched type"
Expected behavior:
Meter expect the PDU exactly like
<Value>
<UInt32 Value="00000190" />
<UInt32 Value="00000708" />
<UInt8 Value="04" />
<OctetString Value="07E4071BFF0A3700FF014A00" />
</Structure>
</Value>
Please guide me to how to create above GXStructure using java code.
6 years 1 month ago
You can try with this.
input.add(0, new GXUInt32(400));
input.add(1, GXUInt32(1800));
input.add(2, GXUInt8(4));
Srinivasan
6 years 1 month ago
Thanks for your quick
Thanks for your quick response
As per your suggestion i got partial success :), see the below PDU
<Value>
# 10/22/2020 12:00:00 AM
<DateTime Value="07E40A1604000000FFFEB600" />
</Structure>
</Value>
</SetRequestNormal>
Only DateTime need to converted into OctetString type.
Please guide me on this.
6 years 1 month ago
I need to think about this a little bit. We have used XML to set values like this, but I'll think something.
6 years 1 month ago
Hi Srinivasan,
Hi Srinivasan,
We have added new class for date time octect string.
You can use it like this:
input.add(3, new GXDateTimeOS(2020, 10, 22, 0,0,0,0));
Now date-time is sent as an octet string.
Srinivasan
6 years ago
Sorry for the late response.
I Have followed the above code snippet, which is also not giving correct datatype. PFB for Request PDU:
<UInt32 Value="0000012C" />
# 09/07/20, 7:00 AM
<DateTime Value="07E407080314000000014A00" />
</Structure>
Expected:
# 09/07/20, 7:00 AM
<OctetString Value="07E407080314000000014A00" />
</Structure>
6 years ago
This is fixed. Update to the latest version (4.0.19).
  • Dawsontot
  • Jerrylam
  • qvlLdJweKzGUYaSOVS
  • LindanEt
  • annoyingconsultants
