  3. Connection Between Client and Server In C
Connection between client and server in C
By fernando , 26 May, 2020
Hello, I have a problem.
I have the client and server correctly compiled in 2 separate virtual machines (virtualBox).
I run the server. When I run the client with the command: ./bin/gurux.dlms.client.bin -h 192.168.56.101 -p 4061. I get this problem: Connection failed: 111, Connection refused Error. 258.
But with the Gurux Director it does connect correctly and reads the objects.
I don't know why. Could you help me?
Thank you very much.
Fernando
6 years 2 months ago
Hi Fernando,
Hi Fernando,
Do you have firewall, etc that might block the connection?
For some reason TCP/IP connection fails.
fernando
No, I don't have anything
No, I don't have anything activated that can block my connection.
I do not understand what can be.
if i have the client and server on the same machine it works fine.
Thanks you,
Fernando
Can you ping the server from the client PC? Check the firewall. It's VERY common that firewall is blocking the connection or your virtual meters are in different TCP/IP networks and can't see each other.
fernando
Yes I can.
Yes I can.
It is true, something is blocking the connection. We have tested it with 2 raspberry pi and it works correctly.
I'm going to check the firewall, and If I find the problem I will report it.
Thanks you.
Fernando.
  • Tyronesok
  • Dawley07
  • nostra
  • cuiVEAwINCoyynjjn
  • qlMlMNfbqjNumKgGFIo
