  3. Gurux DLMS Tool Installation and Usage For INDIA
Gurux DLMS tool installation and usage for INDIA
By Vikas Balichakra , 18 May, 2020
Let's discuss GURUX tool installation and usage issues.....
Can anyone let me know how to write ToU (time of use).
6 years 2 months ago
You can download GXDLMSDirector and read your meter with that.
You need to know the password if you want to write anything. Do you have it?
Vikas Balichakra
I am using version number 8.2
I am using version number 8.2.1905.1401
I am not able to download the new version.
Please let me know the latest version number and how to download it.
While installing a new version i am getting an error. Kindly help me in fixing this issue.
Please find the attached pic for the error pic.
Hi Vikas,
Hi Vikas,
You must download GXDLMSDirector from Gurux.
https://www.gurux.fi/Downloads
Vikas Balichakra
I am unable to download it
I am unable to download it from your link. It is showing error. The error pic is attached.
There is something wrong with your Windows certifications. Try to solve why the https connection fails.
Vikas Balichakra
Sir i am able to download 8.2
Sir i am able to download 8.2.2005.1401 version but unable to add associations.
kindly help me in adding associations.
Vikas Balichakra
Hello sir,
Hello sir,
Please let me know about the GXDLMSDirector settings.
I want to access HDLC with the optical port.
kindly suggest how to make associations.
Before I have used GuruX but this version I am facing the issue.
I am not at all able to add associations.
Kindly help.
Vikas Balichakra
Dear sir,
Dear sir,
I am able to add associations and download associations.
Can you share the tool manual if any?
It will be useful for me to download and operate DLMS functionalities.
Thanks for your support.
Hi Vikas,
Hi Vikas,
You can start reading this:
https://www.gurux.fi/GXDLMSDirectorHelp
Vikas Balichakra
6 years 1 month ago
Dear Sir,
Dear Sir,
I am able to download and access data through serial port(Optical port).
Now I want to establish a connection through TCP. I tried establishing the connection but unable to connect.
kindly help me in this regard. I am using two Static IPV6 sim cards, one in PC and one in Modem for connection establishment.
Vikas Balichakra
6 years 1 month ago
PFA
PFA
Vikas Balichakra
6 years 1 month ago
After establishing connection
After establishing connection it is failing automatically I am not able to download associations.
I am not able to download data from the Meter.
Please find the attached pic for the error message.
6 years 1 month ago
This is Windows error. The client can't make TCP/IP connection to the meter. Check your IP address and port number.
  • ksFhuuipOxKrxk…
  • sherylrk3
  • OLaneHycle
  • LxfgLnoisbruoL…
  • SunbetLith
