  3. How To Set Passive Activity Calender For Season Profile,Week Profile and Day Profile In ANSI C
how to set passive activity calender for Season profile,Week profile and Day profile in ANSI C
By Mohanraj , 5 May, 2020
Could you please provide sample source or steps for setting the activity calender for passive activity calender for Season profile,Week profile and Day profile.
Please provide some sample code snippet
Mohan Raj
Mohanraj
6 years 1 month ago
Any update please?
Mohan Raj
6 years 1 month ago
Hi Mohan ,
Hi Mohan ,
Help is updated.
http://www.gurux.fi/Gurux.DLMS.Objects.GXDLMSActivityCalendar
Mohanraj
6 years 1 month ago
In reply to Hi Mohan , by Kurumi
Followed the link. But unable to write seasonProfile.Below is the trace
Writing an Activity calender
TX: 7E A0 43 03 61 76 91 93 E6 E6 00 C9 35 30 00 00 03 08 CB DC 74 EF E3 D7 21 F9 75 0F CD B4 0F 1A 8C ED 55 3C 6D 6C 75 85 82 22 DC 27 71 22 2D BB 53 F4 C3 07 9E 1D 51 EE 9D AD 0C 13 CA 6B 89 B0 44 6D 55 AF 7E
RX: 7E A0 43 03 61 76 91 93 E6 E6 00 C9 35 30 00 00 03 08 CB DC 74 EF E3 D7 21 F9 75 0F CD B4 0F 1A 8C ED 55 3C 6D 6C 75 85 82 22 DC 27 71 22 2D BB 53 F4 C3 07 9E 1D 51 EE 9D AD 0C 13 CA 6B 89 B0 44 6D 55 AF 7E 7E A0 23 61 03 96 6B 0B E6 E7 00 CD 15 30 00 00 02 54 80 BB 9C F8 FB DB 52 74 32 C3 65 22 04 4B 4C 0C 86 4A 7E
Write failed Activity Calendar0C� 00.00.13.00.00.255:7 Access Error : Device reports a inconsistent Class or Object.
Below is the code snippet
gxActivityCalendar activityCalendar;
gxSeasonProfile* sp;
const unsigned char ln[6] = { 0,0,13,0,0,255 };
if ((ret = cosem_init2((gxObject*)&activityCalendar, DLMS_OBJECT_TYPE_ACTIVITY_CALENDAR, ln)) == 0)
bb_addString(&activityCalendar.calendarNamePassive, "Calendar");
sp = (gxSeasonProfile*)malloc(sizeof(gxSeasonProfile));
bb_init(&sp->name);
bb_addString(&sp->name, "2"); //Season profile name
time_init(&sp->start, -1, 10, 30, -1, -1, -1, -1, -1);
bb_init(&sp->weekName);
arr_push(&activityCalendar.seasonProfilePassive, sp);
time_init(&activityCalendar.time, 2020, 1, 1, 0, 0, 0, -1, -1);
ret = com_write(connection, &activityCalendar.base, 7);
return ret;
Could you please correct me. Not sure what is wrong
Mohan Raj
Mohanraj
6 years 1 month ago
Any update please?
Mohan Raj
6 years 1 month ago
Hi Mohan ,
Hi Mohan ,
Because your connection is ciphered, I can't help you. Can you connect without ciphering?
Mohanraj
6 years 1 month ago
Below is the log of non ciphering meter.Still the same issue. could you please correct me?
TX: 7E A0 07 03 61 93 69 47 7E
RX: 7E A0 07 03 61 93 69 47 7E 7E A0 1E 61 03 73 B5 7C 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
TX: 7E A0 4C 03 61 10 58 27 E6 E6 00 60 3E A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 70 38 9C CE 67 B3 59 AC 56 AB 55 2A 15 8A 45 22 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF BA A8 7E
RX: 7E A0 4C 03 61 10 58 27 E6 E6 00 60 3E A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 70 38 9C CE 67 B3 59 AC 56 AB 55 2A 15 8A 45 22 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF BA A8 7E 7E A0 58 61 03 30 07 51 E6 E7 00 61 4A A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 0E 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 12 80 10 61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 BE 10 04 0E 08 00 06 5F 1F 04 00 00 18 1D 02 30 00 07 57 15 7E
TX: 7E A0 2B 03 61 32 8D EB E6 E6 00 C3 01 81 00 0F 00 00 28 00 00 FF 01 01 09 10 AA 28 52 31 C6 A6 5E E7 FC 54 28 BE 16 8D BC 69 4F AE 7E
RX: 7E A0 2B 03 61 32 8D EB E6 E6 00 C3 01 81 00 0F 00 00 28 00 00 FF 01 01 09 10 AA 28 52 31 C6 A6 5E E7 FC 54 28 BE 16 8D BC 69 4F AE 7E 7E A0 24 61 03 52 62 DC E6 E7 00 C7 01 81 00 01 00 09 10 90 4D 0A 78 22 77 9E 3B E3 AB 17 C0 65 8B 5C 27 8B 51 7E
TX: 7E A0 19 03 61 54 39 98 E6 E6 00 C3 01 82 00 46 00 00 60 03 0A FF 01 00 07 72 7E
RX: 7E A0 19 03 61 54 39 98 E6 E6 00 C3 01 82 00 46 00 00 60 03 0A FF 01 00 07 72 7E 7E A0 11 61 03 74 F3 BA E6 E7 00 C7 01 82 00 00 EE 5D 7E
TX: 7E A0 3A 03 61 76 B7 30 E6 E6 00 C1 01 83 00 14 00 00 0D 00 00 FF 07 00 01 01 02 03 09 0B 57 69 6E 74 65 72 20 74 69 6D 65 09 0C FF FF 0A 1E 01 FF FF FF FF 80 00 00 09 00 47 25 7E
RX: 7E A0 3A 03 61 76 B7 30 E6 E6 00 C1 01 83 00 14 00 00 0D 00 00 FF 07 00 01 01 02 03 09 0B 57 69 6E 74 65 72 20 74 69 6D 65 09 0C FF FF 0A 1E 01 FF FF FF FF 80 00 00 09 00 47 25 7E 7E A0 10 61 03 96 54 62 E6 E7 00 C5 01 83 09 47 61 7E
Write failed Activity Calendar]�� 00.00.13.00.00.255:7 Access Error : Device reports a inconsistent Class or Object.
Mohan Raj
6 years 1 month ago
Hi Mohan,
Hi Mohan,
week_name is empty. Check your week names and update it to the correct one.
Also your hour, minute and second are ignored. Set them to zero.
Try to read correct values from the meter. Meters might expect that date-time value is given in exactly correctly. For example, if the deviation is different, meter don't accept it.
Mohanraj
6 years 1 month ago
In reply to Hi Mohan, by Kurumi
Thanks for the information. After updating correct week_name it is working.
Mohan Raj
6 years 1 month ago
Hi Mohan ,
Hi Mohan ,
Thanks for letting me know what was the problem.
Mohanraj
6 years 1 month ago
We have set Week Name correct after reading and hour, minute and second set to zero.We understood that -1 means value will not be initalized.
Mohan Raj,
6 years 1 month ago
Hi Mohan,
Hi Mohan,
In this case, -1 means that value is ignored. It depends on the meter, what values you need to use.
Mohanraj
6 years 1 month ago
Thank you.
Mohan Raj
