  3. Settings On Bluetooth Connection
Settings on Bluetooth connection
By hhkx , 15 April, 2020
I am trying to read landis e450 meter via Bluetooh on Windows pc. Bluetooth device
can connect successfully to windows. I am attaching the settings screenshot.
Is there something wrong with the settings? I would be pleased if you could support me.
6 years 3 months ago
Check that your baud rate is correct. You can change it from "Advanced..." button.
hhkx
Thanks for your reply. We tried with 9600 which bluetooth supports. Below is showing logs.
GXDLMSDirector 8.2.2004.0801
Log created 19:08:12
19:12:02 Initializing serial connection.
19:12:04 Send SNRM request.
7E A0 0A 00 02 7E 79 03 93 05 65 7E
19:12:09 Failed to receive reply from the device in given time.
19:12:09 Disconnect request
19:12:09 Send Disconnect request.
7E A0 0A 00 02 7E 79 03 53 09 A3 7E
19:12:14 Failed to receive reply from the device in given time.
konum: GXDLMSDirector.GXDLMSDevice.InitializeConnection()
konum: GXDLMSDirector.MainForm.Connect(Object sender, GXAsyncWork work, Object[] parameters)
19:22:45 Initializing serial connection.
19:22:48 Send SNRM request.
7E A0 07 03 03 93 8C 11 7E
19:22:53 Data send failed. Try to resend 1/3
19:22:58 Failed to receive reply from the device in given time.
7E 20 20 03 03 73 70 2E 01 00 14 05 02 00 00 06 02 00 00 07 04 00 00 00 01 08 04 00 00 00 01 4E 6A 7E 7E 20 20 03 03 73 70 2E 01 00 14 05 02 00 00 06 02 00 00 07 04 00 00 00 01 08 04 00 00 00 01 4E 6A 7E
19:22:58
19:22:58 Disconnect request
19:22:58 Send Disconnect request.
7E A0 07 03 03 53 80 D7 7E
19:23:03 Data send failed. Try to resend 1/3
19:23:08 Failed to receive reply from the device in given time.
7E 20 09 03 03 73 40 58 47 0F 7E 7E 20 07 03 03 1F 68 5F 7E
19:23:08
19:24:28 Initializing serial connection.
19:24:31 Send SNRM request.
7E A0 07 03 21 93 0F 01 7E
19:24:36 Data send failed. Try to resend 1/3
19:24:41 Failed to receive reply from the device in given time.
7E 20 20 21 03 73 73 18 01 00 14 05 02 00 00 06 02 00 00 07 04 00 00 00 01 08 04 00 00 00 01 4E 6A 7E 7E 20 20 21 03 73 73 18 01 00 14 05 02 00 00 06 02 00 00 07 04 00 00 00 01 08 04 00 00 00 01 4E 6A 7E
19:24:41
19:24:41 Disconnect request
19:24:41 Send Disconnect request.
7E A0 07 03 21 53 03 C7 7E
19:24:47 Data send failed. Try to resend 1/3
19:24:52 Failed to receive reply from the device in given time.
7E 20 09 21 03 73 43 6E 47 0F 7E 7E 20 07 21 03 1F 6B 69 7E
19:24:52
19:26:04 Initializing serial connection.
19:26:07 Send SNRM request.
7E A0 08 02 21 21 93 05 D1 7E
19:26:12 Data send failed. Try to resend 1/2
19:26:17 Failed to receive reply from the device in given time.
19:26:17 Disconnect request
19:26:17 Send Disconnect request.
7E A0 08 02 21 21 53 09 17 7E
19:26:22 Data send failed. Try to resend 1/2
19:26:27 Failed to receive reply from the device in given time.
19:27:34 Initializing serial connection.
19:27:37 Send SNRM request.
19:27:42 Data send failed. Try to resend 1/2
19:27:47 Failed to receive reply from the device in given time.
19:27:47 Disconnect request
19:27:47 Send Disconnect request.
19:27:52 Data send failed. Try to resend 1/2
19:27:57 Failed to receive reply from the device in given time.
19:29:14 Initializing serial connection.
19:29:16 Send SNRM request.
7E A0 08 02 21 03 93 86 C1 7E
19:29:21 Data send failed. Try to resend 1/2
19:29:26 Failed to receive reply from the device in given time.
19:29:26 Disconnect request
19:29:26 Send Disconnect request.
7E A0 08 02 21 03 53 8A 07 7E
19:29:31 Data send failed. Try to resend 1/2
19:29:37 Failed to receive reply from the device in given time.
19:30:21 Initializing serial connection.
19:30:23 Send SNRM request.
7E A0 08 02 21 23 93 B5 E2 7E
19:30:28 Data send failed. Try to resend 1/2
19:30:34 Failed to receive reply from the device in given time.
19:30:34 Disconnect request
19:30:34 Send Disconnect request.
7E A0 08 02 21 23 53 B9 24 7E
19:30:39 Data send failed. Try to resend 1/2
19:30:44 Failed to receive reply from the device in given time.
Received data is corrupted. One of your serial port settings is wrong.
I believe it should be 9600 8None1.
  • ScottCab
  • prmjPfWJENeYCh…
  • Tyronesok
  • Dawley07
  • nostra
