  3. Trying To Get a Reading of a Landis+gyr E650
Trying to get a reading of a landis+gyr e650
By ilhan , 14 January, 2020
Gurux.Serial
I have tried to read out the Landys-Gyr E650, finding out it's a DLMS meter
I'm using the following hardware:
- Raspberry Pi 3B
- A RS485 cable connected to the meter, installed by the network operator.
- the RS485 cable connected through ch341-uart converter through usb on the raspberry Pi
Having cloned https://github.com/gurux/gurux.dlms.python and installed all the dependencies, I have tried to get it working through, but so far I get the following outputs:
~/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python $ python main.py -S /dev/ttyUSB0
ClientAddress: 0x10
RX: 17:13:41
What else could I try ?
6 years 8 months ago
I'm not quite sure what converter you have, but In my mind, ch341 UART is for 5V/3.3V.
RS485 is using 12V.
Check is your converter working anymore and buy a converter for RS485.
ilhan
6 years 7 months ago
Thanks for you answers, yes the ch341 is for 5V, what product do you recommend.
The DSO has placed an RS485 cable which is just a D+ and D- Cable, I placed the Red in the D+ and Green in D-, I currently get the following output:
ClientAddress: 0x10
RX: 16:26:33
File "main.py", line 80, in main
reader.readAll()
File "/home/pi/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 423, in readAll
self.initializeConnection()
File "/home/pi/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 235, in initializeConnection
File "/home/pi/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 91, in readDLMSPacket
File "/home/pi/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 142, in readDLMSPacket2
raise e
TimeoutException: Failed to receive reply from the device in given time.
- Besides the converter could it also be a default password that it's missing as it's and industrial meter ?
Best, Ilhan
Hi Ilhan,
Hi Ilhan,
If you are using RS-232 converter (ch341), the connection is newer work. You need an RS-485 converter.
ilhan
The converter is sold as
The converter is sold as RS485, it's this one https://www.reichelt.nl/framboos-pi-usb-rs485-interface-rs485-ch340c-rp…
Should this one work ? Or not because it's 5V
We have not used this model. You need to try. Note that there are no drivers for Windows 10.
Let me know if you have any problems.
ilhan
We are running it on a
We are running it on a raspberry Pi 3, which is linux and the ch340 is in the linux directory, so no drivers are needed.
What device would you recommend for this?
We haven't try with this RS-485 converter. I have to say that it's cheap.
We have used example Exsys converters.
ilhan
I'm looking at the manual of
I'm looking at the manual of Exsys rs485-usb converter: https://cdn-reichelt.de/documents/datenblatt/E910/EXSYS_EX1309T_MN_ENG…
The RS-485 connection the DSO placed was orignally in a rj-11 connection, I stripped it and only the green and red cable are left. Which connection do I put them in (see attached picture) ?
If you have only two wires use the upper (default). Lower is for four wires.
ilhan
Hi again,
Hi again,
I got the exsys cable in and this will I'll head up to solar panel meter to install it. I'm using the https://github.com/Gurux/Gurux.DLMS.Python/tree/master/Gurux.DLMS.Clien… to test the connection and my usual testing command is : `python main.py -S /dev/ttyUSB0`
If you would want to set a different baudrate, how would you do this using the Example Python Client ?
At the moment the best way to set serial port settings is modifying main.py.
We'll improve the example client so you can give serial port settings as a parameter.
ilhan
Hi Miko,
I'm still working on get some data out of the Landis+Gyr E650. I was today at the office of the manufacturer and he was able to get a reading with aan optical cable with the software of the manufacturer called .map110
We tried on his windows pc with the Exsys with .map110 over the RS485 port, but that didn't work. I'm wondering if I should install the D2XX Direct Drivers, but I think the VPC drivers that are included in the kernel should be enough.
Using the :
- Python DLMS Gurux EXAMPLE main.py to get a first sign of response.
- Connected is the Exsys USB RS485 converter, I'm using the VCP driver that is in the kernel my USB and it maps to the "ttyUSB0" port.
- For the Exsys, I'm using the `RS485-2W` diagram, pin number 2 is up and all the rest is down.
- After a `pip install -r requirements.txt` in the Client example folder.
The main command I'm resting with is python main.py -S /dev/ttyUSB0, where the result itsn't different. I see the RX light of the meter burning, but it gives the following output:
ClientAddress: 0x10
RX: 12:29:27
6 years 6 months ago
Check the cables if the meter manufacturer was unable to read the meter using RS-485.
Can you read your meter using an optical cable? Just add -i parameter and that should work.
ilhan
So the manufacturer had
So the manufacturer had access to an optical cable, I'm just using the exsys rs485-USB and having hard time getting a reading. What should I check in terms of the cable ?
Serial port reading is causing sometimes problems because there is no clear reason if connection is broken. With TCP/IP error message is clear if the client can't make the connection to the meter.
With serial port connection settings might be wrong or cable is not connected correctly.
ilhan
sudo python main.py -S /dev
sudo python main.py -S /dev/ttyUSB0
ClientAddress: 0x10
File "main.py", line 69, in main
reader.readAll()
File "/home/ilhan/dev/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 485, in readAll
File "/home/ilhan/dev/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 303, in initializeConnection
self.client.parseAareResponse(reply.data)
File "/home/ilhan/.local/lib/python2.7/site-packages/gurux_dlms/GXDLMSClient.py", line 522, in parseAareResponse
self.isAuthenticationRequired = _GXAPDU.parsePDU(self.settings, self.settings.cipher, reply, None) == SourceDiagnostic.AUTHENTICATION_REQUIRED
File "/home/ilhan/.local/lib/python2.7/site-packages/gurux_dlms/_GXAPDU.py", line 641, in parsePDU
ret = _GXAPDU.parsePDU2(settings, cipher, buff, xml)
File "/home/ilhan/.local/lib/python2.7/site-packages/gurux_dlms/_GXAPDU.py", line 674, in parsePDU2
raise GXDLMSException(AssociationResult.PERMANENT_REJECTED, SourceDiagnostic.NOT_SUPPORTED)
GXDLMSException: Access Error : Device reports a hardware fault.
I believe that your meter don't allow connection without an authentication. You need to use Low authentication to connect to the meter. You need to know the Low-level password and change the client address.
If you add -t Verbose parameter I can check this from the bytes.
ilhan
So I tried I think again all
So I tried I think again all types of combinations, in order to let this work.
Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python$ sudo python main.py -S /dev/ttyUSB0 -a Low
ClientAddress: 0x10
reader.readAll()
File "/home/ilhan/dev/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 302, in initializeConnection
self.readDataBlock(self.client.aarqRequest(), reply)
File "/home/ilhan/.local/lib/python2.7/site-packages/gurux_dlms/GXDLMSClient.py", line 491, in aarqRequest
_GXAPDU.generateAarq(self.settings, self.settings.cipher, None, buff)
File "/home/ilhan/.local/lib/python2.7/site-packages/gurux_dlms/_GXAPDU.py", line 274, in generateAarq
cls.getAuthenticationString(settings, data, encryptedData)
File "/home/ilhan/.local/lib/python2.7/site-packages/gurux_dlms/_GXAPDU.py", line 93, in getAuthenticationString
len_ = len(callingAuthenticationValue)
TypeError: object of type 'NoneType' has no len()
The meter provider and meter manufacturer, say it doesn't have a password, I get the following output, also trying out different client addresses doesn't give me anything different. I see the RX and TX lights going on and off when I send a command, so the connection to the smart meter works.
http://www.gurux.fi/sites/default/files/20200303_115353.jpg
It seems that the meter has replied. Can you run this with -t Verbose parameter as I ask in the previous post.
Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python$ sudo python main.py -S /dev/ttyUSB0 -a Low -t Verbose
ilhan
I get the following then:
ClientAddress: 0x10
TX: 13:44:51 7E A0 07 03 21 93 0F 01 7E
RX: 13:44:51 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 3E 07 04 00 00 00 01 08 04 00 00 00 01 07 22 7E
TX: 13:44:51 7E A0 07 03 21 53 03 C7 7E
reader.readAll()
If you don't use the password, your authentication level is None.
Try with this:
Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python$ sudo python main.py -S /dev/ttyUSB0 -t Verbose
ilhan
[sudo] password for ilhan:
ClientAddress: 0x10
TX: 09:33:54 7E A0 07 03 21 93 0F 01 7E
RX: 09:33:54 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 3E 07 04 00 00 00 01 08 04 00 00 00 01 07 22 7E
TX: 09:33:54 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E
RX: 09:33:54 7E A0 36 21 03 30 D7 60 E6 E7 00 61 28 A1 09 06 07 60 85 74 05 08 01 02 A2 03 02 01 01 A3 05 A1 03 02 01 02 BE 0F 04 0D 08 00 06 5F 04 00 18 02 20 09 60 FA 00 C0 3F 7E
TX: 09:33:54 7E A0 07 03 21 53 03 C7 7E
reader.readAll()
Your meter is using Short Name referencing.
Try this:
sudo python main.py -S /dev/ttyUSB0 -t Verbose -r sn
ilhan
That is helping, getting a
That is helping, getting a lot of Verbose messages, not sure what they all mean...
ClientAddress: 0x10
TX: 10:57:57 7E A0 07 03 21 93 0F 01 7E
RX: 10:57:57 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 3E 07 04 00 00 00 01 08 04 00 00 00 01 07 22 7E
TX: 10:57:57 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 02 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF 0F 59 7E
RX: 10:57:57 7E A8 4E 21 03 30 6A 85 E6 E7 00 0C 81 93 00 02 02 0F 00 16 FF 00 02 02 0F 00 16 FF 00 02 02 0F 00 16 FF 00 02 02 0F 00 16 FF 00 02 02 0F 00 16 FF 00 02 02 0F 00 16 FF 00 02 02 0F FF 16 1E 00 02 02 0F FF 16 1E 00 02 02 0F FF 16 1E 1F 98 7E
TX: 10:57:57 7E A0 07 03 21 53 03 C7 7E
reader.readAll()
File "/home/ilhan/dev/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 177, in readDataBlock
self.readDataBlock(it, reply)
File "/home/ilhan/dev/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 179, in readDataBlock
File "/home/ilhan/dev/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 116, in readDLMSPacket
File "/home/ilhan/dev/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 167, in readDLMSPacket2
raise e
AttributeError: GXReplyData instance has no attribute 'setValue'
ilhan
Could this error be, as this
Could this error be, as this Meter is not connected to the grid?
It's just connected to a power source and not reporting any power values at the moment.
No, this is an error in the source code. We'll fix this and release a new version today.
I was checking bytes more and I was wrong. This is not the reply message and I don't know where this is coming. The frame is correct, but data is not. Can you try to read it again? I want to see is meter returning same reply.
ilhan
I left the office already,
I left the office already, saw your reply too late, Ill try it again, it was giving me a longer version of response before, somehow wasn't able to replicate that again with the same command. You'll have it first thing tomorrow. You think trying out a different code base of Gurux such a the Java version will give me different results ?
All programming languages produces the same response. Received data is response for the read.
ilhan
I'm on the latest release,
I'm on the latest release, tried running it again. I get the same error:
ClientAddress: 0x10
TX: 12:03:57 7E A0 07 03 21 93 0F 01 7E
RX: 12:03:57 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 3E 07 04 00 00 00 01 08 04 00 00 00 01 07 22 7E
TX: 12:03:57 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 02 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF 0F 59 7E
RX: 12:03:57 7E A8 4E 21 03 30 6A 85 E6 E7 00 0C 81 93 00 02 02 0F 00 16 FF 00 02 02 0F 00 16 FF 00 02 02 0F 00 16 FF 00 02 02 0F 00 16 FF 00 02 02 0F 00 16 FF 00 02 02 0F 00 16 FF 00 02 02 0F FF 16 1E 00 02 02 0F FF 16 1E 00 02 02 0F FF 16 1E 1F 98 7E
TX: 12:03:57 7E A0 07 03 21 53 03 C7 7E
reader.readAll()
raise e
Would changing the switches with Exsys help, not really sure what all of these stand for, but also putting from 4 to 8 on on, doesn't change the outcome of the commands.
This is very interesting. The client tries to make a connection to the meter and the meter replies read-response. And the values are the same. I'm wondering is this meter some kind of event mode and meter is sending readout data. There should 93 items on the read response.
Is this your own meter or is this meter of the electricity utilizer?
<ReadResponse Qty="93" >
<Data>
<Structure Qty="02" >
<Int8 Value="00" />
<Enum Value="FF" />
</Structure>
</Data>
<Data>
<Int8 Value="00" />
<Enum Value="FF" />
</Structure>
</Data>
<Data>
<Int8 Value="00" />
<Enum Value="FF" />
</Structure>
</Data>
<Data>
<Int8 Value="00" />
<Enum Value="FF" />
</Structure>
</Data>
<Data>
<Int8 Value="00" />
<Enum Value="FF" />
</Structure>
</Data>
<Data>
<Int8 Value="00" />
<Enum Value="FF" />
</Structure>
</Data>
<Data>
<Int8 Value="FF" />
<Enum Value="1E" />
</Structure>
</Data>
<Data>
<Int8 Value="FF" />
<Enum Value="1E" />
</Structure>
</Data>
<Data>
<Int8 Value="FF" />
<Enum Value="1E" />
</Structure>
</Data>
ilhan
Not fully understanding what
Not fully understanding what you mean, The meter is currently connected on my desk to a power source. It just turns it on, but there is currently no energy being drawn from it. I don't know it what kind of mode this puts it, but I have seen it works with an optical cable on-site of the manufacturer Landis+Gyr.
I got this meter, to experiment and make it work, so I don't have to do this where the actual meter is that I want to read out (which is on a rooftop connected to solar panels).
What can you advise we do next, also I want to escalate this in the Netherlands for a professional to do it, as this is not my expertise. You have any advice how to proceed further ?
I'm sorry for the bad explanation. I believe that your meter is sending readouts all the time as a notification message and you don't need to connect to it. I'm not 100% sure of this because this is the first time when I have seen meter working like this.
I need some time to think about how we can handle this.
ilhan
If I would try to go to a
If I would try to go to a connected meter, which is the exact same type, you think the readings can be different? As this is a demo model that is being used for testing purposes and without the .map110 software it might react differently to the Gurux software.
Best, Ilhan
Can you read this meter with Map110 and sent log to me by email? I can check the bytes and try to verify the reason.
ilhan
I personally cannot, as I don
I personally cannot, as I don't have the software and/or the cable. If you know exactly what needs to be read out, I can ask the manufacturer ?
You don't need the cable. It's great If you can ask map110 from the manufacturer.
Let me know what happened.
ilhan
So I got the request from the
So I got the request from the Landis+Gyr with an example.
You can find the logs here:
https://pastebin.com/7HTFDmEv
In the logfile of dMAP110 you will see a reading of the “Energy Total Registers” op security level 1 (UID 32 of Hex 20) with static password 00000000
It communicates with the meter with over Ethernet which loops through a connection via RS485.( this is a translation I got from the manufacturer, tried to translate it the best way)
For the configuration of the tracer see the attached image
Thank you for this info. I don't know why invalid data is returned when default settings are used.
Try with this:
sudo python main.py -S /dev/ttyUSB0 -t Verbose -r sn -c 16 -s 25205 -a Low -P 00000000
ilhan
Hey, again today I am not in
Hey, again today I am not in the office to test this, but can test it on thursday.
Thank you for your effort for making this work, one thing that I would like to clarify about the supplied logs is that this is not the same meter I have on my desk.
I see that you have supplied -s 25205 to the command, this is something that you have seen from the logs? I am not the one that created the logs, I just copied them from the manafacturer that send them to me. The difference is that I'm only using a Exsys USB-RS485 Cable and the logs are connected in a different way as I mentioned in the previous post.
25205 is server address. What is your meter serial number? I believe that the server address is count from it.
ilhan
I got the following back from
I got the following back from the manufacturer:
The serial number you can also find n the dmap110 screens: 50377821
The “Physical address” for DLMS is derived of it, the last 4 digits + 1000: 8821
Yes, it's using the default serial number formula. Try with this:
sudo python main.py -S /dev/ttyUSB0 -t Verbose -r sn -c 16 -n 50377821 -a Low -P 00000000
ilhan
The Machine I have in front
The Machine I have in front of me to test has a serial nr of 5039997 and I used the following command:
sudo python main.py -S /dev/ttyUSB0 -t Verbose -r sn -c 16 -n 50399974 -a Low -P 00000000
gurux_dlms version: 1.0.54
gurux_net version: 1.0.12
gurux_serial version: 1.0.13
ClientAddress: 0x10
ServerAddress: 0x6ade
TX: 10:36:13 7E A0 0A 00 02 AA BD 21 93 E9 96 7E
RX: 10:36:13 7E A0 21 21 00 02 AA BD 73 AD 0D 81 80 12 05 01 80 06 01 3E 07 04 00 00 00 01 08 04 00 00 00 01 07 22 7E
TX: 10:36:13 7E A0 47 00 02 AA BD 21 10 33 C9 E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 02 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 30 30 30 30 30 30 30 30 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF 84 75 7E
RX: 10:36:13 7E A0 39 21 00 02 AA BD 30 17 16 E6 E7 00 61 28 A1 09 06 07 60 85 74 05 08 01 02 A2 03 02 01 01 A3 05 A1 03 02 01 0D BE 0F 04 0D 08 00 06 5F 04 00 18 02 20 09 60 FA 00 18 3A 7E
TX: 10:36:13 7E A0 0A 00 02 AA BD 21 53 E5 50 7E
RX: 10:36:14 7E A0 21 21 00 02 AA BD 73 AD 0D 81 80 12 05 01 80 06 01 3E 07 04 00 00 00 01 08 04 00 00 00 01 07 22 7E
File "main.py", line 84, in main
File "/home/ilhan/dev/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 487, in readAll
File "/home/ilhan/dev/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 304, in initializeConnection
File "/home/ilhan/.local/lib/python2.7/site-packages/gurux_dlms/_GXAPDU.py", line 807, in parsePDU2
raise GXDLMSException(resultComponent, resultDiagnosticValue)
I also used the following command based on what the manufacturer said to add +1000 to the serial no.
sudo python main.py -S /dev/ttyUSB0 -t Verbose -r sn -c 16 -n 50400974 -a Low -P 00000000
ClientAddress: 0x10
ServerAddress: 0x47b6
TX: 10:37:59 7E A0 0A 00 02 1E 6D 21 93 96 0A 7E
^CEnded. Press any key to continue.
This is correct.
Try to run
pip install --upgrade gurux-dlms
ilhan
No Change :
No Change :
gurux_dlms version: 1.0.55
ClientAddress: 0x10
TX: 16:02:08 7E A0 0A 00 02 AA BD 21 93 E9 96 7E
RX: 16:02:08 7E A0 21 21 00 02 AA BD 73 AD 0D 81 80 12 05 01 80 06 01 3E 07 04 00 00 00 01 08 04 00 00 00 01 07 22 7E
TX: 16:02:08 7E A0 47 00 02 AA BD 21 10 33 C9 E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 02 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 30 30 30 30 30 30 30 30 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF 84 75 7E
RX: 16:02:08 7E A0 39 21 00 02 AA BD 30 17 16 E6 E7 00 61 28 A1 09 06 07 60 85 74 05 08 01 02 A2 03 02 01 01 A3 05 A1 03 02 01 0D BE 0F 04 0D 08 00 06 5F 04 00 18 02 20 09 60 FA 00 18 3A 7E
TX: 16:02:08 7E A0 0A 00 02 AA BD 21 53 E5 50 7E
File "/home/ilhan/.local/lib/python2.7/site-packages/gurux_dlms/GXDLMSClient.py", line 523, in parseAareResponse
There was an issue and I made a report from this.
http://www.gurux.fi/node/15147
It's now fixed. Get the latest version.
ilhan
With the latest packages I
With the latest packages I get the same, what do you recommend ?
gurux_dlms version: 1.0.60
gurux_net version: 1.0.17
gurux_serial version: 1.0.14
ClientAddress: 0x10
TX: 12:42:54 7E A0 0A 00 02 AA BD 21 93 E9 96 7E
RX: 12:42:54 7E A0 21 21 00 02 AA BD 73 AD 0D 81 80 12 05 01 80 06 01 3E 07 04 00 00 00 01 08 04 00 00 00 01 07 22 7E
TX: 12:42:54 7E A0 47 00 02 AA BD 21 10 33 C9 E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 02 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 30 30 30 30 30 30 30 30 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF 84 75 7E
RX: 12:42:54 7E A0 39 21 00 02 AA BD 30 17 16 E6 E7 00 61 28 A1 09 06 07 60 85 74 05 08 01 02 A2 03 02 01 01 A3 05 A1 03 02 01 0D BE 0F 04 0D 08 00 06 5F 04 00 18 02 20 09 60 FA 00 18 3A 7E
TX: 12:42:54 7E A0 0A 00 02 AA BD 21 53 E5 50 7E
ilhan
I have access to the .map110
I have access to the .map110 software and it works with the same adapter and the meter out of the box on DLMS settings, I can provide you with information you need about it.
I also see you have uploaded a new version, I'll try it.
Hi Ilhan,
Hi Ilhan,
Can you try to read this using Python3? For some reason Raspberry Pi Python 2.7 is not call useLogicalNameReferencing property. This is changed to the method, but testing is taking some time.
Pagination
  • Page 1
  • Page 2
  • Next page
  • Last page
