  3. Failed To Establishing Connection To Dlms Using "authentication HighGMAC"
Failed to establishing connection to dlms using "authentication HighGMAC"
Profile picture for user mahsen
By mahsen , 5 February, 2020
when I want connect to dlms using DLMSDirector "authentication HighGMAC",
but I faced to this answer: "invalide password", while I am sure all passwords were true,
please help me.
6 years 9 months ago
HighGMAC authentication doesn't use the password. If you have the password check what authentication you need to use.
mahsen
I was meaning "blockCipherKey
I was meaning "blockCipherKey", "authenticationKey" and "systemTitle" were true,
thanks for your time.
What is exact error message that you are receiving? There is no "invalide password" error on GXDLMSDirector.
mahsen
I sent screen shot.
I sent screen shot.
Your Block Cipher key and Authentication keys are the default ones. Verify them from the meter vendor.
mahsen
That side (DLMS c) is also
That side (DLMS c) is also used by default.
We have released the wrong version from the dll. We'll fix this to GXDLMSDirector and release a new version today.
mahsen
thank you, I am waiting.
thank you,
I am waiting.
The new version is released. Restart GXDLMSDirector and update to the latest version.
mahsen
Thank you, problem was solved
Thank you, problem was solved.
