  3. There Is IEC62056-21 Handshake ANSI C Example Code?
there is IEC62056-21 Handshake ANSI C example code?
By pangda , 8 November, 2019
i want use IEC62056-21 Handshake in my application by using ANSI C Language?But there is not an example for ANSI C
6 years 10 months ago
An example of ANSI C is not in an open-source client example. I'll add this to the worklist.
pangda
thanks very much.
thanks very much.
Could you tell me when will this is finished.
I'm sorry. It's there. You need to add -i parameter. It's implemented in com_open method.
