  3. How To Write Clock and Others Objects (registers) of DLMS/COSEM ER300P Meter?
How to write clock and others objects (registers) of DLMS/COSEM ER300P meter?
By pradson , 17 August, 2018
I have developed a sample application for reading DLMS/COSEM compatible ER300P energy meter using Gurux c++ library. Even I am able to read every object of that meter with the help of my sample application. So now I want to write every object through my sample application using c++. Kindly suggest me.
Kindly provide me the sample of code for writing clock and other registers of ER300P meter.
Pradson
7 years 10 months ago
First, check that you can write the new value. Is your authentication level is None, you can usually only read the values.
If you read value like this:
CGXDLMSClock* it = new CGXDLMSClock();
Read(it, 2, value);
//Update new time.
CGXDateTime time = CGXDateTime::Now();
it->SetTime(time);
You can write the value back like this:
Write(it, 2) ;
pradson
In reply to How to write clock and others objects (registers) of DLMS/COSEM by Kurumi
Thanks for your prompt responce.
I am using "Low" authentication level and its password.
I used above sample code as suggest by you, then I am getting access error mentioned below-
My sample:
CGXDLMSClock *clock2 = new CGXDLMSClock("0.0.1.0.0.255");
clock2->SetTime(time);
if ((ret = comm.Write(clock2, 2)) != 0)
TRACE("err! failed to read register: %s", CGXDLMSConverter::GetErrorMessage(ret));
Getting Error:
err! failed to read register: Access Error : Device reports a hardware fault.
What should I do? Kindly suggest me?
Pradson
Try to read your clock and write it back. Don't change it. Let me know what happened.
pradson
As suggested by you. I am still getting the same write error. There is no any issue in reading. Kindly refer below mentioned code sample and its write-error output.
My sample code:
CGXDLMSClock *clock = new CGXDLMSClock("0.0.1.0.0.255");
std::string strClock;
if ((ret = comm.Read(clock, 2, strClock)) != 0)
clock->SetTime(time);
if ((ret = comm.Write(clock, 2)) != 0)
TRACE("err! failed to write register: %s", CGXDLMSConverter::GetErrorMessage(ret));
Error out-put:
err! failed to write register: Access Error : Device reports a hardware fault.
Pradson
lrd2
6 years 7 months ago
I'm trying to set time in L+G E570 using Java app and Gurux Director. In both cases I get error "Access Error : Other Reason." Do you have any idea what's wrong?
I use Management level ("G") and low authentication. I can read objects without any problems with these settings. When I try to update time, the error occurs.
// Code
GXDLMSClock clock = new GXDLMSClock();
clock.setTime(new GXDateTime(1999, 1, 1, 1, 1, 1, 1));
byte[][] data = meterClient.write(clock, 2);
meterReader.readDataBlock(data, reply);
// Error
gurux.dlms.GXDLMSException: Access Error : Other Reason.
: Connection initialized, AARE response: 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 1E 1D 05 50 00 07.
: TX: 18:07:28.650 00 01 00 01 00 01 00 1B C1 01 C1 00 08 00 00 01 00 00 FF 02 00 09 0C 07 E3 0B 01 05 01 01 01 00 FF C4 00
: RX: 18:07:28.864 00 01 00 01 00 01 00 04 C5 01 C1 FA
Best wishes,
Pietari
lrd2
That's what I get when trying
That's what I get when trying to execute similar operation in Gurux Director:
12:36:10 Writing object 0.0.1.0.0.255, interface Clock 00 01 00 01 00 01 00 1B C1 01 C1 00 08 00 00 01 00 00 FF 02 00 09 0C 07 E2 0B 0D 02 12 12 23 FF FF C4 00
12:36:11 00 01 00 01 00 01 00 04 C5 01 C1 FA
Gurux.DLMS.GXDLMSException: Access Error : Other Reason.
w GXDLMSDirector.GXDLMSCommunicator.Write(GXDLMSObject obj, Int32 index)
w GXDLMSDirector.MainForm.WriteMnu_Click(Object sender, EventArgs e)
Settings time can be the pain with some meters. They expect that data is coming in expect form and if that is not exactly correct they return an error.
Example, some meters expected that milliseconds are zero and some that it's not used. Some meters expected that time zone is same, etc.
Try to read data from the meter and then write it back. Let me know if you have an error and post read/write log here.
lrd2
Hi Kurumi,
Hi Kurumi,
Thank you for taking care. I really appreciate your responsiveness.
I did what you asked for and the result is the same - gurux.dlms.GXDLMSException: Access Error : Other Reason.
That's the code:
GXDLMSObject clock = meterClient.getObjects().findByLN(ObjectType.NONE, "0.0.1.0.0.255");
Please find the log below:
2019-11-15 12:30:09.768 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : TX: 12:30:09.767 00 01 00 01 00 01 00 38 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 41 42 34 38 34 30 43 44 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF
2019-11-15 12:30:09.972 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : RX: 12:30:09.972 00 01 00 01 00 01 00 2B 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 1E 1D 05 50 00 07
2019-11-15 12:30:09.976 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : Connection initialized, AARE response: 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 1E 1D 05 50 00 07.
2019-11-15 12:30:09.978 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : TX: 12:30:09.978 00 01 00 01 00 01 00 0D C0 01 C1 00 0F 00 00 28 00 00 FF 02 00
2019-11-15 12:30:10.974 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : RX: 12:30:10.973 00 01 00 01 00 01 05 4E C4 02 C1 00 00 00 00 01 00 82 05 42 01 82 02 3F 02 04 12 00 07 11 01 09 06 01 00 63 0E 00 FF 02 02 01 0C 02 03 0F FC 16 01 00 02 03 0F FD 16 01 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 01 01 0F 01 02 03 0F 01 16 01 00 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 01 11 00 09 06 00 00 60 0A 06 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 76 5E 11 00 09 06 00 00 C7 86 00 FF 02 02 01 05 02 03 0F 05 16 00 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 76 5C 11 00 09 06 00 00 C7 7D 00 FF 02 02 01 09 02 03 0F 09 16 00 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 76 5F 11 00 09 06 00 00 C7 87 00 FF 02 02 01 04 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 75 54 11 00 09 06 00 00 C7 85 00 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 11 FF 02 02 01 04 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 07 11 01 09 06 00 00 63 62 11 FF 02 02 01 08 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 01 01 0F 01 02 03 0F 01 16 01 00 01 04 02 02 0F 01 16 01 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 00 00 63 62 12 FF 02 02 01 08 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 01 01 0F 01 02 03 0F 01 16 01 00 01 04 02 02 0F 01 16 01 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 0E FF 02 02 01 04 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 12 FF 02 02 01 04 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 76 1A 11 00 09 06 00 00 EF 99 83 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 47 38 0D FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 38 0B FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 38 07 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 38 05 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 38 03 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 38 01 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 38 0D FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 38 0B FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 38 07 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 38 05 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 38 03 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 38 01 FF 02 02 01 03 02 03 0F 03 16 01 00
2019-11-15 12:30:10.974 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : TX: 12:30:10.974 00 01 00 01 00 01 00 07 C0 02 C1 00 00 00 01
2019-11-15 12:30:11.855 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : RX: 12:30:11.855 00 01 00 01 00 01 05 4F C4 02 C1 00 00 00 00 02 00 82 05 43 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 38 0D FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 38 0B FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 38 07 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 38 05 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 38 03 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 38 01 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 38 0D FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 38 0B FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 38 07 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 38 05 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 38 03 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 38 01 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 38 0D FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 38 0B FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 38 07 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 38 05 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 38 03 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 38 01 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 38 0D FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 38 0B FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 38 07 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 38 05 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 38 03 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 38 01 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 75 4F 11 00 09 06 00 00 C7 1D 00 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 64 11 00 09 06 00 00 19 0A 00 FF 02 02 01 07 02 03 0F 07 16 00 00 02 03 0F 06 16 00 00 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 03 02 02 0F 03 16 00 02 02 0F 02 16 00 02 02 0F 01 16 01 02 04 12 00 28 11 00 09 06 00 0B 19 09 00 FF 02 02 01 07 02 03 0F 07
2019-11-15 12:30:11.857 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : TX: 12:30:11.857 00 01 00 01 00 01 00 07 C0 02 C1 00 00 00 02
2019-11-15 12:30:12.672 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : RX: 12:30:12.671 00 01 00 01 00 01 05 50 C4 02 C1 00 00 00 00 03 00 82 05 44 16 03 00 02 03 0F 06 16 03 00 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 28 11 00 09 06 00 0A 19 09 00 FF 02 02 01 07 02 03 0F 07 16 03 00 02 03 0F 06 16 03 00 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 28 11 00 09 06 00 09 19 09 00 FF 02 02 01 07 02 03 0F 07 16 03 00 02 03 0F 06 16 03 00 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 28 11 00 09 06 00 08 19 09 00 FF 02 02 01 07 02 03 0F 07 16 03 00 02 03 0F 06 16 03 00 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 28 11 00 09 06 00 06 19 09 00 FF 02 02 01 07 02 03 0F 07 16 03 00 02 03 0F 06 16 03 00 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 28 11 00 09 06 00 00 19 09 00 FF 02 02 01 07 02 03 0F 07 16 03 00 02 03 0F 06 16 03 00 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 28 11 00 09 06 00 07 19 09 00 FF 02 02 01 07 02 03 0F 07 16 03 00 02 03 0F 06 16 03 00 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 28 11 00 09 06 00 05 19 09 00 FF 02 02 01 07 02 03 0F 07 16 03 00 02 03 0F 06 16 03 00 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 28 11 00 09 06 00 04 19 09 00 FF 02 02 01 07 02 03 0F 07 16 03 00 02 03 0F 06 16 03 00 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 28 11 00 09 06 00 03 19 09 00 FF 02 02 01 07 02 03 0F 07 16 03 00 02 03 0F 06 16 03 00 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 28 11 00 09 06 00 02 19 09 00 FF 02 02 01 07 02 03 0F 07 16 03 00 02 03 0F 06 16 03 00 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 28 11 00 09 06 00 01 19 09 00 FF 02 02 01 07 02 03 0F 07 16 03 00 02 03 0F 06 16 03 00 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 16 11 00 09 06 00 00 0F 00 80 FF 02 02 01 07 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 16 11 00 09 06 00 00 0F 00 81 FF 02 02 01 07 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 16 11 00 09 06 00 08 0F 00 04 FF 02 02 01 04 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 16 11 00 09 06 00 07 0F 00 04 FF 02 02 01 04 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 16 11 00 09 06 00 06 0F 00 04 FF 02 02 01 04 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 16 11 00 09 06 00 05 0F 00 04 FF 02 02 01 04 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 16 11 00 09 06 00 04 0F 00 04 FF 02 02 01 04 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 16 11 00 09 06 00 03 0F 00 04 FF 02 02 01 04 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 16 11 00 09 06 00 02 0F 00 04 FF 02 02 01 04 02 03 0F 04 16 03
2019-11-15 12:30:12.672 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : TX: 12:30:12.672 00 01 00 01 00 01 00 07 C0 02 C1 00 00 00 03
2019-11-15 12:30:13.572 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : RX: 12:30:13.571 00 01 00 01 00 01 05 4D C4 02 C1 00 00 00 00 04 00 82 05 41 00 02 03 0F 03 16 01 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 16 11 00 09 06 00 01 0F 00 04 FF 02 02 01 04 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 1D 11 02 09 06 00 00 02 01 00 FF 02 02 01 07 02 03 0F FF 16 03 00 02 03 0F 06 16 03 00 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 00 04 03 FF 02 02 01 05 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 00 04 02 FF 02 02 01 05 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 75 4A 11 03 09 06 00 00 C7 0D 00 FF 02 02 01 15 02 03 0F 15 16 01 00 02 03 0F 14 16 01 00 02 03 0F 13 16 01 00 02 03 0F 12 16 01 00 02 03 0F 11 16 01 00 02 03 0F 10 16 01 00 02 03 0F 0F 16 01 00 02 03 0F 0E 16 01 00 02 03 0F 0D 16 01 00 02 03 0F 0C 16 01 00 02 03 0F 0B 16 01 00 02 03 0F 0A 16 01 00 02 03 0F 09 16 01 00 02 03 0F 08 16 03 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 75 38 11 00 09 06 00 00 C7 17 00 FF 02 02 01 04 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 06 11 00 09 06 00 00 0E 00 02 FF 02 02 01 06 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 04 02 02 0F FF 16 01 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 04 12 00 06 11 00 09 06 00 00 0E 00 01 FF 02 02 01 06 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 04 02 02 0F FF 16 01 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 04 12 00 09 11 00 09 06 00 00 0A 00 84 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 09 11 00 09 06 00 00 0A 00 82 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 09 11 00 09 06 00 00 0A 00 80 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 09 11 00 09 06 00 00 0A 00 83 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 09 11 00 09 06 00 00 0A 00 81 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 09 11 00 09 06 00 00 0A 00 6C FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 09 11 00 09 06 00 01 0A 00 6A FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 09 11 00 09 06 00 00 0A 00 64 FF 02 02 01 05 02 03 0F FD 16 01 00 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 01 02 02 0F 01 16 01 02 04 12 00 09 11 00 09 06 00 00 0A 00 67 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 09 11 00 09 06 00 00 0A 00 6B FF 02 02 01 02 02 03 0F 02 16 00 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 09 11 00 09 06 00 00 0A 00 01 FF 02 02 01 02 02 03 0F 02 16 00 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 16 11 00 09 06 00 00 0F 00 82 FF 02 02 01 04 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 16 11 00 09 06 00 00 0F 00 03 FF 02 02 01 04 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 16 11 00 09 06 00 00 0F 00 00 FF 02 02 01 04 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 16 11 00 09 06 00 00 0F 00 02 FF 02 02 01 04 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 03 11 00
2019-11-15 12:30:13.575 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : TX: 12:30:13.574 00 01 00 01 00 01 00 07 C0 02 C1 00 00 00 04
2019-11-15 12:30:14.411 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : RX: 12:30:14.410 00 01 00 01 00 01 05 50 C4 02 C1 00 00 00 00 05 00 82 05 44 09 06 00 00 C7 06 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 60 0C 05 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 01 11 00 09 06 00 00 60 0A 04 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 07 11 01 09 06 01 00 63 80 00 FF 02 02 01 0C 02 03 0F FC 16 01 00 02 03 0F FD 16 01 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 01 01 0F 01 02 03 0F 01 16 01 00 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 01 11 00 09 06 00 00 60 0A 02 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 07 11 01 09 06 01 00 63 02 00 FF 02 02 01 0C 02 03 0F FC 16 03 00 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 01 01 0F 01 02 03 0F 01 16 01 00 01 04 02 02 0F 01 16 01 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 01 11 00 09 06 00 01 60 0A 04 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 07 11 01 09 06 00 00 63 01 00 FF 02 02 01 0A 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 01 01 0F 01 02 03 0F 01 16 01 00 01 04 02 02 0F 01 16 01 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 75 40 11 00 09 06 00 00 C7 10 00 FF 02 02 01 01 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 01 11 00 09 06 00 04 60 0B 04 FF 02 02 01 04 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 03 60 0B 04 FF 02 02 01 04 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 02 60 0B 04 FF 02 02 01 04 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 01 60 0B 04 FF 02 02 01 04 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 07 11 01 09 06 00 04 18 05 00 FF 02 02 01 08 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 01 01 0F 01 02 03 0F 01 16 01 00 01 04 02 02 0F 01 16 01 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 00 03 18 05 00 FF 02 02 01 08 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 01 01 0F 01 02 03 0F 01 16 01 00 01 04 02 02 0F 01 16 01 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 00 02 18 05 00 FF 02 02 01 08 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 01 01 0F 01 02 03 0F 01 16 01 00 01 04 02 02 0F 01 16 01 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 00 01 18 05 00 FF 02 02 01 08 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 01 01 0F 01 02 03 0F 01 16 01 00 01 04 02 02 0F 01 16 01 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 01 11 00 09 06 00 00 60 81 00 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 02 01 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 04 60 01 01 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 03 60 01 01 FF 02 02 01 02 02 03
2019-11-15 12:30:14.412 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : TX: 12:30:14.412 00 01 00 01 00 01 00 07 C0 02 C1 00 00 00 05
2019-11-15 12:30:15.273 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : RX: 12:30:15.272 00 01 00 01 00 01 05 50 C4 02 C1 00 00 00 00 06 00 82 05 44 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 02 60 01 01 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 01 60 01 01 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 11 11 00 09 06 00 00 29 00 00 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 40 11 00 09 06 00 00 2B 00 03 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 02 02 02 0F 02 16 01 02 02 0F 01 16 01 02 04 12 00 40 11 00 09 06 00 00 2B 00 02 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 02 02 02 0F 02 16 01 02 02 0F 01 16 01 02 04 12 00 40 11 00 09 06 00 00 2B 00 01 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 02 02 02 0F 02 16 01 02 02 0F 01 16 01 02 04 12 00 40 11 00 09 06 00 00 2B 00 00 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 02 02 02 0F 02 16 01 02 02 0F 01 16 01 02 04 12 00 07 11 01 09 06 00 04 18 03 00 FF 02 02 01 0C 02 03 0F FC 16 03 00 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 01 01 0F 01 02 03 0F 01 16 01 00 01 04 02 02 0F 01 16 01 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 00 03 18 03 00 FF 02 02 01 0C 02 03 0F FC 16 03 00 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 01 01 0F 01 02 03 0F 01 16 01 00 01 04 02 02 0F 01 16 01 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 00 02 18 03 00 FF 02 02 01 0C 02 03 0F FC 16 03 00 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 01 01 0F 01 02 03 0F 01 16 01 00 01 04 02 02 0F 01 16 01 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 00 01 18 03 00 FF 02 02 01 0C 02 03 0F FC 16 03 00 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 01 01 0F 01 02 03 0F 01 16 01 00 01 04 02 02 0F 01 16 01 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 01 11 00 09 06 00 04 60 0A 03 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 03 60 0A 03 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 02 60 0A 03 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 01 60 0A 03 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0A 01 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 4A 11 00 09 06 00 00 18 06 00 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 52 08 00 FF 02 02 01 06 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 75 33 11 03 09 06 00 00 C7 00 00 FF 02 02 01 04 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 16 11 00 09 06 00 01 0F 00 01 FF 02 02 01 04 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 16 11 00 09 06 00 00 0F 01 00 FF 02 02 01 04 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01
2019-11-15 12:30:15.274 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : TX: 12:30:15.274 00 01 00 01 00 01 00 07 C0 02 C1 00 00 00 06
2019-11-15 12:30:16.132 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : RX: 12:30:16.131 00 01 00 01 00 01 05 4F C4 02 C1 00 00 00 00 07 00 82 05 43 00 01 00 02 04 12 00 16 11 00 09 06 00 00 0F 00 01 FF 02 02 01 04 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 46 11 00 09 06 00 04 18 04 00 FF 02 02 01 04 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 02 16 01 02 02 0F 01 16 01 02 04 12 00 46 11 00 09 06 00 03 18 04 00 FF 02 02 01 04 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 02 16 01 02 02 0F 01 16 01 02 04 12 00 46 11 00 09 06 00 02 18 04 00 FF 02 02 01 04 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 02 16 01 02 02 0F 01 16 01 02 04 12 00 46 11 00 09 06 00 01 18 04 00 FF 02 02 01 04 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 02 16 01 02 02 0F 01 16 01 02 04 12 00 01 11 00 09 06 01 00 00 02 08 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 75 32 11 02 09 06 00 00 C7 01 06 FF 02 02 01 05 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 75 32 11 02 09 06 00 00 C7 01 0D FF 02 02 01 05 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 75 4C 11 01 09 06 00 00 C7 01 C8 FF 02 02 01 05 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 75 32 11 02 09 06 00 00 C7 01 05 FF 02 02 01 05 02 03 0F 05 16 03 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 75 32 11 02 09 06 00 00 C7 01 04 FF 02 02 01 05 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 75 32 11 02 09 06 00 00 C7 01 03 FF 02 02 01 05 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 00 0D 03 00 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0D 05 00 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 0A FF 02 02 01 04 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 07 FF 02 02 01 04 02 03 0F FE 16 03 00 02 03 0F FF 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 0C FF 02 02 01 0B 02 03 0F F7 16 03 00 02 03 0F F8 16 01 00 02 03 0F F9 16 01 00 02 03 0F FA 16 01 00 02 03 0F FB 16 01 00 02 03 0F FC 16 01 00 02 03 0F FD 16 01 00 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 08 FF 02 02 01 04 02 03 0F FE 16 03 00 02 03 0F FF 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 0B FF 02 02 01 04 02 03 0F FE 16 01 00 02 03 0F FF 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 05 FF 02 02 01 04 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 0F FF 02 02 01 04 02 03 0F FE 16 03 00 02 03 0F FF 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 04 FF 02 02 01 04 02 03 0F FE 16 03 00 02 03 0F FF 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 03 FF 02 02 01 04 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 02 FF 02 02 01 04 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 01 FF 02 02
2019-11-15 12:30:16.133 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : TX: 12:30:16.133 00 01 00 01 00 01 00 07 C0 02 C1 00 00 00 07
2019-11-15 12:30:16.972 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : RX: 12:30:16.971 00 01 00 01 00 01 05 50 C4 02 C1 00 00 00 00 08 00 82 05 44 01 04 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 07 11 01 09 06 00 00 63 62 0D FF 02 02 01 08 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 01 01 0F 01 02 03 0F 01 16 01 00 01 04 02 02 0F 01 16 01 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 00 00 63 62 0A FF 02 02 01 08 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 01 01 0F 01 02 03 0F 01 16 01 00 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 00 00 63 62 0C FF 02 02 01 08 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 01 01 0F 01 02 03 0F 01 16 01 00 01 04 02 02 0F 01 16 01 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 00 00 63 62 08 FF 02 02 01 08 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 01 01 0F 01 02 03 0F 01 16 01 00 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 00 00 63 62 0E FF 02 02 01 08 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 01 01 0F 01 02 03 0F 01 16 01 00 01 04 02 02 0F 01 16 01 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 00 00 63 62 0B FF 02 02 01 08 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 01 01 0F 01 02 03 0F 01 16 01 00 01 04 02 02 0F 01 16 01 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 00 00 63 62 05 FF 02 02 01 08 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 01 01 0F 01 02 03 0F 01 16 01 00 01 04 02 02 0F 01 16 01 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 01 00 63 61 00 FF 02 02 01 08 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 01 01 0F 01 02 03 0F 01 16 01 00 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 00 00 63 62 04 FF 02 02 01 08 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 01 01 0F 01 02 03 0F 01 16 01 00 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 00 00 63 62 03 FF 02 02 01 08 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 01 01 0F 01 02 03 0F 01 16 01 00 01 04 02 02 0F 01 16 01 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 00 00 63 62 02 FF 02 02 01 08 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 01 01 0F 01 02 03 0F 01 16 01 00 01 04 02 02 0F 01 16 01 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 00 00 63 62 01 FF 02 02 01 08 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 01 01 0F 01 02 03 0F 01 16 01 00 01 04 02 02 0F 01 16 01 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 75 55 11 00 09 06 00 00 C7 28 00 FF 02 02 01 06 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 76 5D
2019-11-15 12:30:16.973 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : TX: 12:30:16.973 00 01 00 01 00 01 00 07 C0 02 C1 00 00 00 08
2019-11-15 12:30:17.814 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : RX: 12:30:17.814 00 01 00 01 00 01 05 50 C4 02 C1 00 00 00 00 09 00 82 05 44 11 00 09 06 00 00 C7 84 00 FF 02 02 01 07 02 03 0F 07 16 03 00 02 03 0F 06 16 03 00 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 17 11 01 09 06 00 03 16 00 00 FF 02 02 01 0D 02 03 0F FC 16 03 00 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 09 16 03 00 02 03 0F 08 16 03 00 02 03 0F 07 16 03 00 02 03 0F 06 16 03 00 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 17 11 01 09 06 00 02 16 00 00 FF 02 02 01 0B 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 09 16 03 00 02 03 0F 08 16 03 00 02 03 0F 07 16 03 00 02 03 0F 06 16 03 00 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 17 11 01 09 06 00 01 16 00 00 FF 02 02 01 0B 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 09 16 03 00 02 03 0F 08 16 03 00 02 03 0F 07 16 03 00 02 03 0F 06 16 03 00 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 17 11 01 09 06 00 04 16 00 00 FF 02 02 01 0D 02 03 0F FC 16 03 00 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 09 16 03 00 02 03 0F 08 16 03 00 02 03 0F 07 16 03 00 02 03 0F 06 16 03 00 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 17 11 01 09 06 00 00 16 00 00 FF 02 02 01 0D 02 03 0F FC 16 03 00 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 09 16 03 00 02 03 0F 08 16 03 00 02 03 0F 07 16 03 00 02 03 0F 06 16 03 00 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 04 60 01 00 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 03 60 01 00 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 02 60 01 00 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 01 60 01 00 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 15 11 00 09 06 01 00 10 04 00 FF 02 02 01 06 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 15 11 00 09 06 00 00 10 01 02 FF 02 02 01 06 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 15 11 00 09 06 00 00 10 01 01 FF 02 02 01 06 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 15 11 00 09 06 00 00 10 01 00 FF 02 02 01 06 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 15 11 00 09 06 01 00 47 04 00 FF 02 02 01 06 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 15 11 00 09 06 01 00 33 04 00 FF 02 02 01 06 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 15 11 00 09 06 01 00 1F 04 00 FF 02 02 01 06 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0A 05 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 05 00 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 04 00 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 03 00 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 08 08 04 FF 02 02 01 06 02 03 0F FD 16 03 00 02 03 0F FE
2019-11-15 12:30:17.816 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : TX: 12:30:17.816 00 01 00 01 00 01 00 07 C0 02 C1 00 00 00 09
2019-11-15 12:30:18.694 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : RX: 12:30:18.693 00 01 00 01 00 01 05 50 C4 02 C1 00 00 00 00 0A 00 82 05 44 16 03 00 02 03 0F FF 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 01 00 08 08 03 FF 02 02 01 06 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 01 00 08 08 02 FF 02 02 01 06 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 01 00 08 08 01 FF 02 02 01 06 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 01 00 07 08 04 FF 02 02 01 06 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 01 00 07 08 03 FF 02 02 01 06 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 01 00 07 08 02 FF 02 02 01 06 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 01 00 07 08 01 FF 02 02 01 06 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 01 00 06 08 04 FF 02 02 01 06 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 01 00 06 08 03 FF 02 02 01 06 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 01 00 06 08 02 FF 02 02 01 06 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 01 00 06 08 01 FF 02 02 01 06 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 01 00 05 08 04 FF 02 02 01 06 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 01 00 05 08 03 FF 02 02 01 06 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 01 00 05 08 02 FF 02 02 01 06 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 01 00 05 08 01 FF 02 02 01 06 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 01 00 04 08 04 FF 02 02 01 06 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 01 00 04 08 03 FF 02 02 01 06 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 01 00 04 08 02 FF 02 02 01 06 02 03 0F FD 16 03 00 02 03
2019-11-15 12:30:18.695 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : TX: 12:30:18.695 00 01 00 01 00 01 00 07 C0 02 C1 00 00 00 0A
2019-11-15 12:30:19.658 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : RX: 12:30:19.658 00 01 00 01 00 01 05 4F C4 02 C1 00 00 00 00 0B 00 82 05 43 0F FE 16 03 00 02 03 0F FF 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 01 00 04 08 01 FF 02 02 01 06 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 01 00 03 08 04 FF 02 02 01 06 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 01 00 03 08 03 FF 02 02 01 06 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 01 00 03 08 02 FF 02 02 01 06 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 01 00 03 08 01 FF 02 02 01 06 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 01 00 02 08 04 FF 02 02 01 06 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 01 00 02 08 03 FF 02 02 01 06 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 01 00 02 08 02 FF 02 02 01 06 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 01 00 02 08 01 FF 02 02 01 06 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 01 00 01 08 04 FF 02 02 01 06 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 01 00 01 08 03 FF 02 02 01 06 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 01 00 01 08 02 FF 02 02 01 06 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 01 00 01 08 01 FF 02 02 01 06 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 01 00 00 08 80 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 00 08 02 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0E 18 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 18 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 18 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 18 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 48 03 00 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03
2019-11-15 12:30:19.660 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : TX: 12:30:19.659 00 01 00 01 00 01 00 07 C0 02 C1 00 00 00 0B
2019-11-15 12:30:20.711 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : RX: 12:30:20.711 00 01 00 01 00 01 05 4F C4 02 C1 00 00 00 00 0C 00 82 05 43 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 34 03 00 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 20 03 00 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 48 06 00 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 34 06 00 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 20 06 00 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0C 1F 01 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0C 23 01 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0D 27 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 60 07 14 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0C 2D 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0C 2B 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0C 2C 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0C 27 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0C 1F 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0C 23 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 60 07 13 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 01 11 00 09 06 00 00 60 07 00 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 09 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 15 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 48 20 00 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 34 20 00 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 20 20 00 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 48 24 00 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 34 24 00 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 20 24 00 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 48 11 01 09 06 00 04 18 01 00 FF 02 02 01 12 02 03 0F FC 16 03 00 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 0E 16 01 00 02 03 0F 0D 16 01 00 02 03 0F 0C 16 01 00 02 03 0F 0B 16 01 00 02 03 0F 0A 16 01 00 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 08 02 02 0F 08 16 01 02 02 0F 07 16 01 02 02 0F 02 16 01 02 02 0F 01
2019-11-15 12:30:20.714 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : TX: 12:30:20.713 00 01 00 01 00 01 00 07 C0 02 C1 00 00 00 0C
2019-11-15 12:30:21.591 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : RX: 12:30:21.591 00 01 00 01 00 01 05 4F C4 02 C1 00 00 00 00 0D 00 82 05 43 16 01 02 02 0F 03 16 00 02 02 0F 04 16 00 02 02 0F 05 16 00 02 02 0F 06 16 00 02 04 12 00 48 11 01 09 06 00 03 18 01 00 FF 02 02 01 12 02 03 0F FC 16 03 00 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 0E 16 01 00 02 03 0F 0D 16 01 00 02 03 0F 0C 16 01 00 02 03 0F 0B 16 01 00 02 03 0F 0A 16 01 00 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 08 02 02 0F 08 16 01 02 02 0F 07 16 01 02 02 0F 02 16 01 02 02 0F 01 16 01 02 02 0F 03 16 00 02 02 0F 04 16 00 02 02 0F 05 16 00 02 02 0F 06 16 00 02 04 12 00 48 11 01 09 06 00 02 18 01 00 FF 02 02 01 12 02 03 0F FC 16 03 00 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 0E 16 01 00 02 03 0F 0D 16 01 00 02 03 0F 0C 16 01 00 02 03 0F 0B 16 01 00 02 03 0F 0A 16 01 00 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 08 02 02 0F 08 16 01 02 02 0F 07 16 01 02 02 0F 02 16 01 02 02 0F 01 16 01 02 02 0F 03 16 00 02 02 0F 04 16 00 02 02 0F 05 16 00 02 02 0F 06 16 00 02 04 12 00 48 11 01 09 06 00 01 18 01 00 FF 02 02 01 12 02 03 0F FC 16 03 00 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 0E 16 01 00 02 03 0F 0D 16 01 00 02 03 0F 0C 16 01 00 02 03 0F 0B 16 01 00 02 03 0F 0A 16 01 00 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 08 02 02 0F 08 16 01 02 02 0F 07 16 01 02 02 0F 02 16 01 02 02 0F 01 16 01 02 02 0F 03 16 00 02 02 0F 04 16 00 02 02 0F 05 16 00 02 02 0F 06 16 00 02 04 12 00 04 11 00 09 06 00 04 18 02 08 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 04 11 00 09 06 00 04 18 02 07 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 04 11 00 09 06 00 04 18 02 06 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 04 11 00 09 06 00 04 18 02 05 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 04 11 00 09 06 00 04 18 02 04 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 04 11 00 09 06 00 04 18 02 03 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 04 11 00 09 06 00 04 18 02 02 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 04 11 00 09 06 00 04 18 02 01 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 04 11 00 09 06 00 03 18 02 08 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 04 11 00 09 06 00 03 18 02 07 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 04 11 00 09 06 00 03 18 02 06 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 04 11 00 09 06 00 03 18 02 05 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00
2019-11-15 12:30:21.592 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : TX: 12:30:21.592 00 01 00 01 00 01 00 07 C0 02 C1 00 00 00 0D
2019-11-15 12:30:22.451 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : RX: 12:30:22.450 00 01 00 01 00 01 05 4F C4 02 C1 00 00 00 00 0E 00 82 05 43 01 01 02 02 0F 01 16 01 02 04 12 00 04 11 00 09 06 00 03 18 02 04 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 04 11 00 09 06 00 03 18 02 03 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 04 11 00 09 06 00 03 18 02 02 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 04 11 00 09 06 00 03 18 02 01 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 04 11 00 09 06 00 02 18 02 08 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 04 11 00 09 06 00 02 18 02 07 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 04 11 00 09 06 00 02 18 02 06 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 04 11 00 09 06 00 02 18 02 05 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 04 11 00 09 06 00 02 18 02 04 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 04 11 00 09 06 00 02 18 02 03 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 04 11 00 09 06 00 02 18 02 02 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 04 11 00 09 06 00 02 18 02 01 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 04 11 00 09 06 00 01 18 02 08 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 04 11 00 09 06 00 01 18 02 07 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 04 11 00 09 06 00 01 18 02 06 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 04 11 00 09 06 00 01 18 02 05 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 04 11 00 09 06 00 01 18 02 04 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 04 11 00 09 06 00 01 18 02 03 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 04 11 00 09 06 00 01 18 02 02 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 04 11 00 09 06 00 01 18 02 01 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 76 60 11 00 09 06 00 00 C7 18 00 FF 02 02 01 04 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 75 32 11 02 09 06 00 00 C7 01 02 FF 02 02 01 05 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02
2019-11-15 12:30:22.454 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : TX: 12:30:22.453 00 01 00 01 00 01 00 07 C0 02 C1 00 00 00 0E
2019-11-15 12:30:23.313 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : RX: 12:30:23.313 00 01 00 01 00 01 05 50 C4 02 C1 00 00 00 00 0F 00 82 05 44 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 75 45 11 02 09 06 00 00 C7 01 01 FF 02 02 01 05 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 10 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 07 7C FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 07 7C FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 07 7C FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0B 07 7C FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 07 7C FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 07 7C FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 07 7C FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0C 07 7C FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 49 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 35 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 21 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 46 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 32 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1E 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 40 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2C 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 18 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3E 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2A 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 16 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 45 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 31 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1D 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3F 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2B 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 17 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01
2019-11-15 12:30:23.314 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : TX: 12:30:23.314 00 01 00 01 00 01 00 07 C0 02 C1 00 00 00 0F
2019-11-15 12:30:24.154 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : RX: 12:30:24.153 00 01 00 01 00 01 05 4F C4 02 C1 00 00 00 00 10 00 82 05 43 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3D 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 29 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 15 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 5B 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 51 07 15 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 51 07 14 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 51 07 0A FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 82 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 5A 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0D 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 51 07 3E FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 51 07 33 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 51 07 28 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0E 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 07 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 26 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03
2019-11-15 12:30:24.155 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : TX: 12:30:24.154 00 01 00 01 00 01 00 07 C0 02 C1 00 00 00 10
2019-11-15 12:30:24.999 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : RX: 12:30:24.998 00 01 00 01 00 01 05 4F C4 02 C1 00 00 00 00 11 00 82 05 43 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 26 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 26 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 25 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 25 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 25 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 22 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 22 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 22 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 21 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 21 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 21 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 01 11 00 09 06 00 00 2B 01 03 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 2B 01 02 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 2B 01 00 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 2B 01 01 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 75 53 11 00 09 06 00 00 C7 23 00 FF 02 02 01 06 02 03 0F 06 16 03 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 75 31 11 05 09 06 00 00 C7 0C 08 FF 02 02 01 09 02 03 0F 09 16 03 00 02 03 0F 08 16 03 00 02 03 0F 07 16 03 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 02 00 02 03 0F 01 16 01 00 01 00 02 04 12 75 31 11 05 09 06 00 00 C7 0C 07 FF 02 02 01 09 02 03 0F 09 16 03 00 02 03 0F 08 16 03 00 02 03 0F 07 16 03 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 02 00 02 03 0F 01 16 01 00 01 00 02 04 12 75 31 11 05 09 06 00 00 C7 0C 05 FF 02 02 01 09 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 00 00 02 03 0F 01 16 01 00 01 00 02 04 12 75 31 11 05 09 06 00 00 C7 0C 04 FF 02 02 01 09 02 03 0F 09 16 03 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 02 00 02 03 0F 01 16 01 00 01 00 02 04 12 75 31 11 05 09 06 00 00 C7 0C 03 FF 02 02 01 09 02 03 0F 09 16 03 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 02 00 02 03 0F 01 16 01 00 01 00 02 04 12 75 31 11 05 09 06 00 00 C7 0C 02 FF 02 02 01 09 02 03 0F 09 16 03 00 02 03 0F 08 16 03 00 02 03 0F 07 16 03 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 02 00 02 03 0F 01 16 01 00 01 00 02 04 12 75 31 11 05 09 06 00 00 C7 0C 01 FF 02 02 01 09 02 03 0F 09 16 03 00 02 03 0F 08 16 03 00 02 03 0F 07 16 03 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 02 00 02 03 0F 01 16 01 00 01 00 02 04 12 75 31 11 05 09 06 00 00 C7 0C 00 FF
2019-11-15 12:30:25.000 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : TX: 12:30:25.000 00 01 00 01 00 01 00 07 C0 02 C1 00 00 00 11
2019-11-15 12:30:25.895 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : RX: 12:30:25.894 00 01 00 01 00 01 05 4D C4 02 C1 00 00 00 00 12 00 82 05 41 02 02 01 09 02 03 0F 09 16 03 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 00 00 02 03 0F 01 16 01 00 01 00 02 04 12 75 30 11 02 09 06 00 00 C7 0C 06 FF 02 02 01 05 02 03 0F 05 16 01 00 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 29 11 00 09 06 00 00 19 00 00 FF 02 02 01 06 02 03 0F 06 16 03 00 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 2A 11 00 09 06 00 00 19 01 00 FF 02 02 01 0A 02 03 0F 0A 16 03 00 02 03 0F 09 16 03 00 02 03 0F 08 16 03 00 02 03 0F 07 16 03 00 02 03 0F 06 16 03 00 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 03 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 04 12 00 2C 11 00 09 06 00 00 19 03 00 FF 02 02 01 05 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 2D 11 00 09 06 00 00 19 04 00 FF 02 02 01 07 02 03 0F FD 16 03 00 02 03 0F FE 16 01 00 02 03 0F FF 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 1B 11 01 09 06 00 00 02 00 00 FF 02 02 01 0D 02 03 0F F7 16 01 00 02 03 0F F8 16 01 00 02 03 0F F9 16 01 00 02 03 0F FA 16 03 00 02 03 0F FB 16 03 00 02 03 0F FC 16 03 00 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 75 3E 11 02 09 06 00 00 C7 0A 00 FF 02 02 01 0C 02 03 0F 0C 16 01 00 02 03 0F 0B 16 01 00 02 03 0F 0A 16 03 00 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 1C 11 02 09 06 00 00 02 02 00 FF 02 02 01 09 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 07 16 03 00 02 03 0F 06 16 03 00 02 03 0F 05 16 03 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 07 11 01 09 06 00 00 62 01 00 FF 02 02 01 0C 02 03 0F FC 16 03 00 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 01 01 0F 01 02 03 0F 01 16 01 00 01 04 02 02 0F 01 16 01 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 00 FF 02 02 01 04 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 07 11 01 09 06 00 00 63 62 00 FF 02 02 01 08 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 01 01 0F 01 02 03 0F 01 16 01 00 01 04 02 02 0F 01 16 01 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 03 11 00 09 06 00 00 60 08 00 FF 02 02 01 03 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 00 00 60 06 00 FF 02 02 01 04 02 03 0F FF 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 00 00 60 08 06 FF 02 02 01 04 02 03 0F FF 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 00 00 60 08 05 FF 02 02 01 04 02 03 0F FF 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 00 00 60 08 04 FF 02 02 01 04 02 03 0F FF 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 00 00 60 08 03 FF 02 02 01 04 02 03 0F FF 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 03 11 00
2019-11-15 12:30:25.895 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : TX: 12:30:25.895 00 01 00 01 00 01 00 07 C0 02 C1 00 00 00 12
2019-11-15 12:30:26.813 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : RX: 12:30:26.813 00 01 00 01 00 01 05 50 C4 02 C1 00 00 00 00 13 00 82 05 44 09 06 00 00 60 08 02 FF 02 02 01 04 02 03 0F FF 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 00 00 60 08 01 FF 02 02 01 04 02 03 0F FF 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 01 02 04 12 00 07 11 01 09 06 01 00 63 01 00 FF 02 02 01 0C 02 03 0F FC 16 03 00 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 01 01 0F 01 02 03 0F 01 16 01 00 01 04 02 02 0F 01 16 01 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 75 49 11 02 09 06 00 00 C7 09 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 00 00 01 00 02 04 12 75 39 11 0A 09 06 00 00 C7 08 00 FF 02 02 01 10 02 03 0F 0F 16 00 00 02 03 0F 10 16 00 00 02 03 0F 0E 16 00 00 02 03 0F 0D 16 00 00 02 03 0F 0C 16 00 00 02 03 0F 0B 16 00 00 02 03 0F 0A 16 00 00 02 03 0F 09 16 00 00 02 03 0F 08 16 00 00 02 03 0F 07 16 00 00 02 03 0F 06 16 00 00 02 03 0F 05 16 00 00 02 03 0F 04 16 00 00 02 03 0F 03 16 00 00 02 03 0F 02 16 00 00 02 03 0F 01 16 01 00 01 06 02 02 0F 06 16 00 02 02 0F 05 16 00 02 02 0F 04 16 00 02 02 0F 03 16 00 02 02 0F 02 16 00 02 02 0F 01 16 00 02 04 12 00 01 11 00 09 06 00 00 60 5B 00 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 C7 2B 00 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0D 01 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0D 00 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 5A FF FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 05 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 04 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 03 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 02 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 01 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 00 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 00 02 00 FF 02 02 01 05 02 03 0F FD 16 01 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 01 00 02 00 FF 02 02 01 05 02 03 0F FD 16 01 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 02 00 FF 02 02 01 05 02 03 0F FD 16 01 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 2A 00 00 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 53 08 13 FF 02 02 01 05 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 53 08 14 FF 02 02 01 05 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 53 08 05 FF 02 02 01 05 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 53 08 04 FF 02 02 01 05 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 53 08 06 FF 02 02 01 05 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03
2019-11-15 12:30:26.814 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : TX: 12:30:26.814 00 01 00 01 00 01 00 07 C0 02 C1 00 00 00 13
2019-11-15 12:30:27.713 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : RX: 12:30:27.712 00 01 00 01 00 01 05 50 C4 02 C1 00 00 00 00 14 00 82 05 44 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 53 08 02 FF 02 02 01 05 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 53 08 01 FF 02 02 01 05 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 53 08 03 FF 02 02 01 05 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 40 08 00 FF 02 02 01 05 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2C 08 00 FF 02 02 01 05 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 18 08 00 FF 02 02 01 05 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3F 08 00 FF 02 02 01 05 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2B 08 00 FF 02 02 01 05 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 17 08 00 FF 02 02 01 05 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3E 08 00 FF 02 02 01 05 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2A 08 00 FF 02 02 01 05 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 16 08 00 FF 02 02 01 05 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3D 08 00 FF 02 02 01 05 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 29 08 00 FF 02 02 01 05 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 15 08 00 FF 02 02 01 05 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 00 FF 02 02 01 05 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 00 FF 02 02 01 05 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 00 FF 02 02 01 05 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 00 FF 02 02 01 05 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 00 FF 02 02 01 05 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 03
2019-11-15 12:30:27.713 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : TX: 12:30:27.713 00 01 00 01 00 01 00 07 C0 02 C1 00 00 00 14
2019-11-15 12:30:28.612 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : RX: 12:30:28.612 00 01 00 01 00 01 05 50 C4 02 C1 00 00 00 00 15 00 82 05 44 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 00 FF 02 02 01 05 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 00 FF 02 02 01 05 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 00 FF 02 02 01 05 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 00 FF 02 02 01 05 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 00 FF 02 02 01 05 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 00 FF 02 02 01 05 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 00 FF 02 02 01 05 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F FF 16 00 02 02 0F 01 16 00 02 04 12 00 08 11 00 09 06 00 00 01 00 00 FF 02 02 01 09 02 03 0F 09 16 01 00 02 03 0F 08 16 03 00 02 03 0F 07 16 03 00 02 03 0F 06 16 03 00 02 03 0F 05 16 03 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 06 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 02 0F 05 16 00 02 02 0F 06 16 00 02 04 12 00 14 11 00 09 06 00 00 0D 00 00 FF 02 02 01 0B 02 03 0F FF 16 03 00 02 03 0F 0A 16 03 00 02 03 0F 09 16 03 00 02 03 0F 08 16 03 00 02 03 0F 07 16 03 00 02 03 0F 06 16 03 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 0B 11 00 09 06 00 00 0B 00 00 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 01 11 00 09 06 00 00 60 0E 00 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 04 11 00 09 06 00 00 7F 00 88 FF 02 02 01 08 02 03 0F FD 16 03 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 00 7F 00 87 FF 02 02 01 08 02 03 0F FD 16 03 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 00 7F 00 86 FF 02 02 01 08 02 03 0F FD 16 03 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 00 7F 00 85 FF 02 02 01 08 02 03 0F FD 16 03 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 00 7F 00 84 FF 02 02 01 08 02 03 0F FD 16 03 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 00 7F 00 83 FF 02 02 01 08 02 03 0F FD 16 03 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 00 7F 00 82 FF 02 02 01 08 02 03 0F FD 16 03 00 02 03 0F FE 16 01 00 02 03 0F FF
2019-11-15 12:30:28.613 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : TX: 12:30:28.613 00 01 00 01 00 01 00 07 C0 02 C1 00 00 00 15
2019-11-15 12:30:29.553 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : RX: 12:30:29.553 00 01 00 01 00 01 05 4F C4 02 C1 00 00 00 00 16 00 82 05 43 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 00 7F 00 81 FF 02 02 01 08 02 03 0F FD 16 03 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 00 7F 00 80 FF 02 02 01 08 02 03 0F FD 16 03 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 00 7F 00 7F FF 02 02 01 08 02 03 0F FD 16 03 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 00 7F 00 7E FF 02 02 01 08 02 03 0F FD 16 03 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 00 7F 00 7D FF 02 02 01 08 02 03 0F FD 16 03 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 00 7F 00 7C FF 02 02 01 08 02 03 0F FD 16 03 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 00 7F 00 7B FF 02 02 01 08 02 03 0F FD 16 03 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 00 7F 00 7A FF 02 02 01 08 02 03 0F FD 16 03 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 00 7F 00 79 FF 02 02 01 08 02 03 0F FD 16 03 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 00 7F 00 78 FF 02 02 01 08 02 03 0F FD 16 03 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 00 7F 00 77 FF 02 02 01 08 02 03 0F FD 16 03 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 00 7F 00 76 FF 02 02 01 08 02 03 0F FD 16 03 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 00 7F 00 75 FF 02 02 01 08 02 03 0F FD 16 03 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 00 7F 00 74 FF 02 02 01 08 02 03 0F FD 16 03 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 00 7F 00 73 FF 02 02 01 08 02 03 0F FD 16 03 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 04 FF 02 02 01 08 02 03 0F FD 16 03 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03
2019-11-15 12:30:29.553 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : TX: 12:30:29.553 00 01 00 01 00 01 00 07 C0 02 C1 00 00 00 16
2019-11-15 12:30:30.429 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : RX: 12:30:30.429 00 01 00 01 00 01 05 4F C4 02 C1 00 00 00 00 17 00 82 05 43 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 03 FF 02 02 01 08 02 03 0F FD 16 03 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 02 FF 02 02 01 08 02 03 0F FD 16 03 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 01 FF 02 02 01 08 02 03 0F FD 16 03 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 08 06 00 FF 02 02 01 08 02 03 0F FD 16 03 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 07 06 00 FF 02 02 01 08 02 03 0F FD 16 03 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 06 06 00 FF 02 02 01 08 02 03 0F FD 16 03 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 05 06 00 FF 02 02 01 08 02 03 0F FD 16 03 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0A 06 00 FF 02 02 01 08 02 03 0F FD 16 03 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 09 06 00 FF 02 02 01 08 02 03 0F FD 16 03 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 00 FF 02 02 01 08 02 03 0F FD 16 03 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 00 FF 02 02 01 08 02 03 0F FD 16 03 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 00 FF 02 02 01 08 02 03 0F FD 16 03 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 00 FF 02 02 01 08 02 03 0F FD 16 03 00 02 03 0F FE 16 01 00 02 03 0F FF 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 03 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 05 11 00 09 06 01 00 47 38 7C FF 02 02 01 09 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 33 38 7C FF 02 02 01 09 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 1F 38 7C FF 02 02 01 09 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03
2019-11-15 12:30:30.429 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : TX: 12:30:30.429 00 01 00 01 00 01 00 07 C0 02 C1 00 00 00 17
2019-11-15 12:30:31.311 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : RX: 12:30:31.311 00 01 00 01 00 01 05 50 C4 02 C1 00 00 00 00 18 00 82 05 44 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 0B 38 7C FF 02 02 01 09 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 48 38 7C FF 02 02 01 09 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 34 38 7C FF 02 02 01 09 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 20 38 7C FF 02 02 01 09 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 0C 38 7C FF 02 02 01 09 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 10 1B 00 FF 02 02 01 09 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 0F 1B 00 FF 02 02 01 09 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 04 1B 00 FF 02 02 01 09 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 03 1B 00 FF 02 02 01 09 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 02 1B 00 FF 02 02 01 09 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 01 1B 00 FF 02 02 01 09 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 0E 1B 00 FF 02 02 01 09 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 0D 1B 00 FF 02 02 01 09 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 49 1B 00 FF 02 02 01 09 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01
2019-11-15 12:30:31.312 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : TX: 12:30:31.312 00 01 00 01 00 01 00 07 C0 02 C1 00 00 00 18
2019-11-15 12:30:32.194 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : RX: 12:30:32.193 00 01 00 01 00 01 05 4F C4 02 C1 00 00 00 00 19 00 82 05 43 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 35 1B 00 FF 02 02 01 09 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 21 1B 00 FF 02 02 01 09 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 47 1B 00 FF 02 02 01 09 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 33 1B 00 FF 02 02 01 09 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 1F 1B 00 FF 02 02 01 09 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 48 1B 00 FF 02 02 01 09 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 34 1B 00 FF 02 02 01 09 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 20 1B 00 FF 02 02 01 09 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 5B 04 00 FF 02 02 01 09 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 47 04 00 FF 02 02 01 09 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 33 04 00 FF 02 02 01 09 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 1F 04 00 FF 02 02 01 09 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 0F 18 00 FF 02 02 01 09 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 10 18 00 FF 02 02 01 09 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03
2019-11-15 12:30:32.195 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : TX: 12:30:32.195 00 01 00 01 00 01 00 07 C0 02 C1 00 00 00 19
2019-11-15 12:30:33.117 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : RX: 12:30:33.117 00 01 00 01 00 01 05 4F C4 02 C1 00 00 00 00 1A 00 82 05 43 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 04 18 00 FF 02 02 01 09 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 03 18 00 FF 02 02 01 09 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 02 18 00 FF 02 02 01 09 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 01 18 00 FF 02 02 01 09 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 08 04 00 FF 02 02 01 0A 02 03 0F FF 16 03 00 02 03 0F 09 16 03 00 02 03 0F 08 16 03 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 07 04 00 FF 02 02 01 0A 02 03 0F FF 16 03 00 02 03 0F 09 16 03 00 02 03 0F 08 16 03 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 06 04 00 FF 02 02 01 0A 02 03 0F FF 16 03 00 02 03 0F 09 16 03 00 02 03 0F 08 16 03 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 05 04 00 FF 02 02 01 0A 02 03 0F FF 16 03 00 02 03 0F 09 16 03 00 02 03 0F 08 16 03 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 0A 04 00 FF 02 02 01 0A 02 03 0F FF 16 03 00 02 03 0F 09 16 03 00 02 03 0F 08 16 03 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 09 04 00 FF 02 02 01 0A 02 03 0F FF 16 03 00 02 03 0F 09 16 03 00 02 03 0F 08 16 03 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 04 04 00 FF 02 02 01 0A 02 03 0F FF 16 03 00 02 03 0F 09 16 03 00 02 03 0F 08 16 03 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 03 04 00 FF 02 02 01 0A 02 03 0F FF 16 03 00 02 03 0F 09 16 03 00 02 03 0F 08 16 03 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 02 04 00 FF 02 02 01 0A 02 03 0F FF 16 03 00 02 03 0F 09 16 03 00 02 03 0F 08 16 03 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02
2019-11-15 12:30:33.118 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : TX: 12:30:33.118 00 01 00 01 00 01 00 07 C0 02 C1 00 00 00 1A
2019-11-15 12:30:33.993 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : RX: 12:30:33.993 00 01 00 01 00 01 05 50 C4 02 C1 00 00 00 00 1B 00 82 05 44 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 01 04 00 FF 02 02 01 0A 02 03 0F FF 16 03 00 02 03 0F 09 16 03 00 02 03 0F 08 16 03 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 46 11 00 09 06 00 00 60 03 0A FF 02 02 01 05 02 03 0F FF 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 03 02 02 0F FF 16 01 02 02 0F 02 16 01 02 02 0F 01 16 01 02 04 12 00 03 11 00 09 06 01 00 01 04 80 FF 02 02 01 04 02 03 0F FF 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 47 11 00 09 06 00 00 11 00 00 FF 02 02 01 0B 02 03 0F 0B 16 03 00 02 03 0F 0A 16 01 00 02 03 0F 09 16 03 00 02 03 0F 08 16 03 00 02 03 0F 07 16 03 00 02 03 0F 06 16 03 00 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 75 3C 11 04 09 06 00 00 C7 02 07 FF 02 02 01 08 02 03 0F 08 16 03 00 02 03 0F 07 16 03 00 02 03 0F 06 16 03 00 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 75 3C 11 04 09 06 00 00 C7 02 06 FF 02 02 01 08 02 03 0F 08 16 03 00 02 03 0F 07 16 03 00 02 03 0F 06 16 03 00 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 75 3C 11 04 09 06 00 00 C7 02 05 FF 02 02 01 08 02 03 0F 08 16 03 00 02 03 0F 07 16 03 00 02 03 0F 06 16 03 00 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 75 3C 11 04 09 06 00 00 C7 02 04 FF 02 02 01 08 02 03 0F 08 16 03 00 02 03 0F 07 16 03 00 02 03 0F 06 16 03 00 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 75 3C 11 04 09 06 00 00 C7 02 03 FF 02 02 01 08 02 03 0F 08 16 03 00 02 03 0F 07 16 03 00 02 03 0F 06 16 03 00 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 75 3C 11 04 09 06 00 00 C7 02 02 FF 02 02 01 08 02 03 0F 08 16 03 00 02 03 0F 07 16 03 00 02 03 0F 06 16 03 00 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 75 3C 11 04 09 06 00 00 C7 02 01 FF 02 02 01 08 02 03 0F 08 16 03 00 02 03 0F 07 16 03 00 02 03 0F 06 16 03 00 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 75 3C 11 04 09 06 00 00 C7 02 00 FF 02 02 01 08 02 03 0F 08 16 03 00 02 03 0F 07 16 03 00 02 03 0F 06 16 01 00 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 12 11 00 09 06 00 00 2C 00 00 FF 02 02 01 0B 02 03 0F FC 16 01 00 02 03 0F FD 16 01 00 02 03 0F FE 16 01 00 02 03 0F FF 16 03 00 02 03 0F 07 16 01 00 02 03 0F 06 16 01 00 02 03 0F 05 16 03 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 04 02 02 0F 04 16 01 02 02 0F 03 16 01 02 02 0F 02 16 01 02 02 0F 01 16 01 02 04 12 00 01 11 00 09 06 00 00 61 62 82 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 61 62 8C FF 02 02 01 05 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 01 02 02 0F FF 16 01 02 04 12 00 01 11 00 09 06 00 00 61 62 0C FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 61 62 02 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 61 62 16 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 61 62 81 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 61 62 8B FF 02 02 01 05 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 03
2019-11-15 12:30:33.994 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : TX: 12:30:33.993 00 01 00 01 00 01 00 07 C0 02 C1 00 00 00 1B
2019-11-15 12:30:34.952 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : RX: 12:30:34.951 00 01 00 01 00 01 05 50 C4 02 C1 00 00 00 00 1C 00 82 05 44 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 01 02 02 0F FF 16 01 02 04 12 00 01 11 00 09 06 00 00 61 62 0B FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 61 62 01 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 61 62 15 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 61 62 80 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 61 62 8A FF 02 02 01 05 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 01 02 02 0F FF 16 01 02 04 12 00 01 11 00 09 06 00 00 61 62 0A FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 61 62 00 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 61 62 14 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 61 61 00 FF 02 02 01 02 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 75 3A 11 01 09 06 00 00 C7 03 01 FF 02 02 01 06 02 03 0F 06 16 03 00 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 75 3A 11 01 09 06 00 00 C7 03 00 FF 02 02 01 06 02 03 0F 06 16 03 00 02 03 0F 05 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 46 11 00 09 06 00 03 60 03 0A FF 02 02 01 09 02 03 0F FB 16 03 00 02 03 0F FC 16 03 00 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 03 02 02 0F FF 16 01 02 02 0F 02 16 01 02 02 0F 01 16 01 02 04 12 00 46 11 00 09 06 00 02 60 03 0A FF 02 02 01 09 02 03 0F FB 16 03 00 02 03 0F FC 16 03 00 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 03 02 02 0F FF 16 01 02 02 0F 02 16 01 02 02 0F 01 16 01 02 04 12 00 46 11 00 09 06 00 01 60 03 0A FF 02 02 01 09 02 03 0F FB 16 03 00 02 03 0F FC 16 03 00 02 03 0F FD 16 03 00 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 04 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 03 02 02 0F FF 16 01 02 02 0F 02 16 01 02 02 0F 01 16 01 02 04 12 00 0F 11 02 09 06 00 00 28 00 01 FF 02 02 01 0B 02 03 0F 0B 16 01 00 02 03 0F 0A 16 03 00 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 00 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 04 02 02 0F 04 16 00 02 02 0F 03 16 00 02 02 0F 02 16 00 02 02 0F 01 16 01 02 04 12 00 0C 11 03 09 06 00 00 28 00 02 FF 02 02 01 06 02 03 0F 06 16 01 00 02 03 0F 05 16 03 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 08 02 02 0F 08 16 01 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 02 0F 05 16 00 02 02 0F 06 16 00 02 02 0F 07 16 00 02 04 12 00 03 11 00 09 06 01 00 00 09 0B FF 02 02 01 05 02 03 0F FE 16 03 00 02 03 0F FF 16 03 00 02 03 0F 03 16 01 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 09 11 00 09 06 00 00 0A 00 6A FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 01 11 00 09 06 01 00 00 09 01 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 09 02 FF 02 02 01 02 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 00 02 04 12 75 44 11 04 09 06 00 00 C7 13 00 FF 02 02 01 01 02 03 0F 01 16 01 00 01 0D 02 02 0F 0D 16 00 02 02 0F 0C 16 00 02 02 0F 0B 16 00 02 02 0F 0A 16 01 02 02 0F 09 16 01 02 02 0F 08 16 01 02 02 0F 07 16 00 02 02 0F 06 16 00 02 02 0F 05 16 01 02 02 0F 04 16 00 02 02 0F 03 16 01 02 02 0F 02 16 00 02 02 0F 01 16 00 02 04 12 75 6B 11 00 09 06 00 00 C7 2A 00 FF 02 02 01 03 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01
2019-11-15 12:30:34.952 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : TX: 12:30:34.952 00 01 00 01 00 01 00 07 C0 02 C1 00 00 00 1C
2019-11-15 12:30:35.238 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : RX: 12:30:35.238 00 01 00 01 00 01 00 EA C4 02 C1 01 00 00 00 1D 00 81 DF 00 01 00 02 04 12 75 92 11 00 09 06 00 00 C7 16 00 FF 02 02 01 04 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 75 92 11 00 09 06 00 00 C7 16 01 FF 02 02 01 04 02 03 0F 04 16 03 00 02 03 0F 03 16 03 00 02 03 0F 02 16 03 00 02 03 0F 01 16 01 00 01 00 02 04 12 00 0F 11 02 09 06 00 00 28 00 00 FF 02 02 01 0B 02 03 0F 0B 16 01 00 02 03 0F 0A 16 03 00 02 03 0F 09 16 01 00 02 03 0F 08 16 01 00 02 03 0F 07 16 00 00 02 03 0F 06 16 01 00 02 03 0F 05 16 01 00 02 03 0F 04 16 01 00 02 03 0F 03 16 01 00 02 03 0F 02 16 01 00 02 03 0F 01 16 01 00 01 04 02 02 0F 04 16 00 02 02 0F 03 16 00 02 02 0F 02 16 00 02 02 0F 01 16 01
2019-11-15 12:30:35.634 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : TX: 12:30:35.634 00 01 00 01 00 01 00 1B C1 01 C1 00 08 00 00 01 00 00 FF 02 00 09 0C 07 E3 0B 0F 05 0C 1E 23 1F FF C4 00
2019-11-15 12:30:35.797 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : RX: 12:30:35.797 00 01 00 01 00 01 00 04 C5 01 C1 FA
2019-11-15 12:30:35.803 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : TX: 12:30:35.803 00 01 00 01 00 01 00 17 62 15 80 01 00 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D 05 50
2019-11-15 12:30:35.990 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : RX: 12:30:35.990 00 01 00 01 00 01 00 05 63 03 80 01 00
2019-11-15 12:30:35.991 TRACE DESKTOP-13UJRQD --- [nio-8080-exec-1] GXDLMSReaderLogger : Connection released: 63 03 80 01 00
6 years 7 months ago
You need to read the date-time from the meter and post only the read response here.
I need to check what format meter is using.
lrd2
Hi Kurumi,
Hi Kurumi,
This is a successful reply from the meter:
Reading object: 0.0.1.0.0.255 Ch. 0 Clock object #1, attribute: 2
TX: 10:00:00.577 00 01 00 01 00 01 00 0D C0 01 C1 00 08 00 00 01 00 00 FF 02 00
RX: 10:00:00.792 00 01 00 01 00 01 00 12 C4 01 C1 00 09 0C 07 E3 0B 12 01 09 3B 0D FF 80 00 00
TX: 10:00:00.815 00 01 00 01 00 01 00 17 62 15 80 01 00 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D 05 50
RX: 10:00:01.005 00 01 00 01 00 01 00 05 63 03 80 01 00
Before I've got this result, I obtained getUint16 error:
java.lang.IllegalArgumentException: getUInt16
TX: 09:47:25.218 00 01 00 01 00 01 00 38 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 41 42 34 38 34 30 43 44 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF
RX: 09:47:25.465 00 01 00 01 00 01 00 2B 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 1E 1D 05 50 00 07
Connection initialized, AARE response: 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 1E 1D 05 50 00 07.
TX: 09:47:25.470 00 01 00 01 00 01 00 0D C0 01 C1 00 0F 00 00 28 00 00 FF 02 00
TX: 09:47:26.472 00 01 00 01 00 01 00 0D C0 01 C1 00 0F 00 00 28 00 00 FF 02 00
Your meter is not using the time zone. You need to skip it and ms.
CGXDateTime time = CGXDateTime::Now();
time.SetSkip(DATETIME_SKIPS_MS | DATETIME_SKIPS_DEVITATION);
lrd2
THANK YOU Kurumi, problem
THANK YOU Kurumi, problem solved!
However, it's a bit confusing because when I read the meter with .map110, it looks like it can handle timezones (please find the screen below).
For Java developers, code for adding skips according to Kurumi's advice:
GXDateTime timeToSet = new GXDateTime();
timeToSet.setSkip(new HashSet<>(Arrays.asList(DateTimeSkips.DEVITATION, DateTimeSkips.MILLISECOND));
If you can send me the Map 110 trace, I can check it, but I believe that value is converted to UTC time before send.
