  3. Serial Over Bluetooth On Android (Xamarin)
Serial over bluetooth on Android (Xamarin)
By vhouck@sqli.com , 12 November, 2019
Gurux.Serial
I'm trying to connect to Kamstrup (686-162-WK-65) meters using bluetooth optical probes from a Xamarin Android app. These meters only support IEC (61036).
I'm able to connect to the bluetooth optical probe however, I'm not sure how to integrate with the Gurux.Serial API.
Any help, guidance would be appreciated.
Thanks, Vincent
7 years ago
Hi Vincent,
Hi Vincent,
If you can send data directly to the Bluetooth device, you don't need a serial port.
If your Bluetooth device is shown as serial port, you can send data the same way than communicating with a normal serial port.
  • Suria
  • pespinosaferrer777
  • Gabice William
  • ngewe
  • jojon15
