  3. How Can I Continue To Receive Data From TGXReplyData.data?
How can I continue to receive data from TGXReplyData.data?
By TaeSoo_Han , 30 October, 2019
Hello Sir,
Thanks a lot for your good comment from Gurux.DLMS.delphi problem.
Now, I am facing problem that limit size of TGXReplyData.Data (2byte, 0 ~ 65535).
I am trying to get data form TGXReplyData.Data and overall data size is more than 90kbytes.
When I get data from TGXDLMSClient.GetData(reply: TBytes; data: TGXReplyData),
I have problem of continual getting data from TGXReplyData.data because of limitation of TGXByteBuffer buffier size during Load profile process of DLMS.
I compare data size in my source code as bellows;
if TGXReplyData.Data.Size >= 655,00 then
begin
- Store TGXReplyData.Data to buffer in my source code.
- TGXReplyData.Data.Clear;
end;
but continual getting data from TGXReplyData.Data is not exact because discontinuity of data from changing state of size ( 65535 to 0 ) in TGXReplyData.Data.
I tried to change data size of TGXByteBuffer in Gurux.DLMS library, but
I faced problem SetLength( FData, cap ) from TGXByteBuffer.Capacity(cap : integer --> double);
So, I found that changing code of Gurux.DLMS library is not correct.
How can I solve this problem about limitation of buffer size in TGXByteBuffer?
Please comment me to get continual data from TGXReplyData.Data.
Thanks a lot.
TaeSoo_Han
6 years 9 months ago
Sir, I solved the problem to
Sir, I solved the problem to set data size as bellows;
if TGXReplyData.Data.Size >= 650,00 then
begin
end;
I get continuous data from TGXReplyData.Data of "TGXDLMSClient.GetData(reply: TBytes; data: TGXReplyData) "
Thanks a lot
Max PDU size is 65535 (0xFFFF), so the meter can't return so much data.
What you try to read?
TaeSoo_Han
Hello, Sir
Hello, Sir
I am try to read data as bellows;
01 0A
02 02
11 00
01 0C
02 03 09 04 00 00 00 00 09 06 00 00 0A 00 64 FF 12 00 01
02 03 09 04 03 00 00 00 09 06 00 00 0A 00 64 FF 12 00 02
02 03 09 04 06 00 00 00 09 06 00 00 0A 00 64 FF 12 00 03
02 03 09 04 09 00 00 00 09 06 00 00 0A 00 64 FF 12 00 04
02 03 09 04 0C 00 00 00 09 06 00 00 0A 00 64 FF 12 00 01
02 03 09 04 0F 00 00 00 09 06 00 00 0A 00 64 FF 12 00 02
02 03 09 04 12 00 00 00 09 06 00 00 0A 00 64 FF 12 00 03
02 03 09 04 15 00 00 00 09 06 00 00 0A 00 64 FF 12 00 04
02 03 09 04 FF FF FF FF 09 06 00 00 0A 00 64 FF 12 00 00
02 02
11 01
01 0C
02 03 09 04 00 00 00 00 09 06 00 00 0A 00 64 FF 12 00 02
02 03 09 04 03 00 00 00 09 06 00 00 0A 00 64 FF 12 00 03
02 03 09 04 06 00 00 00 09 06 00 00 0A 00 64 FF 12 00 04
02 03 09 04 09 00 00 00 09 06 00 00 0A 00 64 FF 12 00 01
02 03 09 04 0C 00 00 00 09 06 00 00 0A 00 64 FF 12 00 02
02 03 09 04 0F 00 00 00 09 06 00 00 0A 00 64 FF 12 00 03
02 03 09 04 12 00 00 00 09 06 00 00 0A 00 64 FF 12 00 04
02 03 09 04 15 00 00 00 09 06 00 00 0A 00 64 FF 12 00 01
02 02
11 02
01 0C
02 03 09 04 00 00 00 00 09 06 00 00 0A 00 64 FF 12 00 03
02 03 09 04 03 00 00 00 09 06 00 00 0A 00 64 FF 12 00 04
02 03 09 04 06 00 00 00 09 06 00 00 0A 00 64 FF 12 00 01
02 03 09 04 09 00 00 00 09 06 00 00 0A 00 64 FF 12 00 02
02 03 09 04 0C 00 00 00 09 06 00 00 0A 00 64 FF 12 00 03
02 03 09 04 0F 00 00 00 09 06 00 00 0A 00 64 FF 12 00 04
02 03 09 04 12 00 00 00 09 06 00 00 0A 00 64 FF 12 00 01
02 03 09 04 15 00 00 00 09 06 00 00 0A 00 64 FF 12 00 02
up to 6420 lines, but I can read data when TGXReplyData.Data.Size >= 650,00, I can read from zero position of data by doing TGXReplyData.Data.Clear;
processing load profile needs to get data more than 65535 in my meter and it goes well now.
  • SgwTHoQsOQXBixXP
  • omOOQJmnOZZWWf…
  • Wooplke djoole…
  • Duaneduh
  • ClaytonPap
