  3. ImageBlockTransfer Send Wrong Image_block_number
ImageBlockTransfer send wrong image_block_number
By SgmUsr , 29 October, 2019
I'm following the example of Image Transfer in Gurux.DLMS.Client but when I use ImageBlockTransfer() method, it always sends image_block_number = 0 and the correct segment for each segment.
Where is the problem?
7 years ago
Have you read ImageBlockSize? What it's the size? What is the size of your image in bytes?
Check that you have not modified the source code.
SgmUsr
7 years ago
I have ImageBlockSize is 183, Number of Segments is 1461, ImageSize is 267363.
I set them with those values.
7 years ago
I tested this with one meter. image_block_number is correct. Can you send the second message that you send to the meter where the image index should be 1.
Note that image_block_number is UInt32.
SgmUsr
7 years ago
But when GetImageBlocks(byte[
But when GetImageBlocks(byte[] image) creates frame, I have:
for (int pos = 0; pos != cnt; ++pos)
GXByteBuffer data = new GXByteBuffer();
data.SetUInt8((byte)DataType.Structure);
data.SetUInt8((byte)2);
GXCommon.SetData(null, data, DataType.UInt32, pos); -> pos is always 0
7 years ago
This is for loop where pos is increased every time (++pos).
It's zero in the first time. Can you add this line before packets.Add(...)
System.Diagnostics.Debug.WriteLine(data);
Post the second debug line and I'll verify this from the bytes.
SgmUsr
7 years ago
Ok, I found my error: I used
Ok, I found my error: I used ImageBlockTransfer() method fo each segment and not with all segment together.
Now it work correctly.
Thanks for help
7 years ago
Thanks for the info. Have a nice coding.
