  3. Secured Connection Configuration In Serial Communication
Secured connection configuration in serial communication
By Bhaumik , 23 October, 2019
Gurux.Serial
I am trying to do secured connection with the meter using the serial interface with following configuration.
Authentication : Low
password : ABCD111
Secured Connection Configuration : As shown in attached image.
It gives error message as
"Specified argument was out of valid values.
Parameter name: Invalid System Title".
Please let me know how I can do secured connection.
Bhaumik
6 years 9 months ago
The system title size is 8 bytes. Your keys also looks strange.
Secured connection means that your messages are ciphered (encrypted). Are you sure that you want to do this?
Bhaumik
Now I am able to connect with the meter using serial interface having authentication level "Low". Apart from that AARQ response is not able to parse and in logs it shows following error "ApplicationContextUnsupported".
<AssociationResponse>
<AssociationResult Value="01" />
<ResultSourceDiagnostic>
<ACSEServiceUser Value="02" />
</ResultSourceDiagnostic>
<RespondingAPTitle Value="AABBVV3030303735" />
<ConfirmedServiceError>
<Service Value="01" />
<ServiceError>
<ApplicationReference Value="ApplicationContextUnsupported" />
</ServiceError>
</ConfirmedServiceError>
</AssociationResponse>
SNRM response parsed successfully.
Is there any other configuration I have to do ?
Can you make the connection without ciphering, using just Low authentication?
It might be that your meter is not support ciphering.
Bhaumik
I have tried with Low Authentication but it gives error message as shown in the attached image.
Using None Authentication I am able to read Clock and Data DLMS objects.
FYI, Meter supports Indian Standard 15959 protocol.
We are reading a lot of different Indian meters. What meter model this is?
What is your client's address? I can't see it from the pic.
Bhaumik
I am trying to read from Single phase 2 wire ac static smart meter having IS16444 standard.
And client address is 32 and the association requirement is of Meter Reader type.
I believe that the reason for this is that there is a context in APDU that you meter don't understand.
Can you ask the meter manufacturer to fix this?
If you can't, can you read it with some other app? If you can, can you post the first two traces so I can check what meter don't understand.
  • Georgerah
  • Pokiessearm
  • Rolling-Slots-Bok
  • OskoNadyLoold
  • @Hmd- several '.
