  3. Physical Layer
physical layer
By sayedali , 28 January, 2016
what are physical layer like RS85 or ethernet or..... support dlms protocol?
10 years 7 months ago
physical layer
We are reading using following physical layers:
RS232
RS485
TCP/IP
UDP
Power Line Communication
Terminal (Modem) connection.
Then there has been lots of talk from ZigBee and other wireless communication protocols, but we do not know any meter that supports them. There might be meters where it is implemented, but our clients do not use them.
lugaflo
6 years 11 months ago
Dears, are there any progress
Dears, are there any progress on the ZigBee protocol implementation ? I will work on a use case with an EDMI meter. Any information is welcome.
You can generate frames with Gurux.DLMS library and send them using Zigbee. There are no Zigbee media at the moment.
lugaflo
Thanks Mikko. We will then
Thanks Mikko. We will then develop a light Zigbee media.
Florent
Hi Florent,
Hi Florent,
Let me know if you need any assistant.
lugaflo
In reply to Hi Florent, by Kurumi
OK. Thx.
OK. Thx.
  • Ask313
  • EmilioBecerra
  • Kundan Dhande
  • Shah Wali Haidari
  • Olga
