  3. Physical Layer
physical layer
By sayedali , 28 January, 2016
what are physical layer like RS85 or ethernet or..... support dlms protocol?
10 years 9 months ago
physical layer
We are reading using following physical layers:
RS232
RS485
TCP/IP
UDP
Power Line Communication
Terminal (Modem) connection.
Then there has been lots of talk from ZigBee and other wireless communication protocols, but we do not know any meter that supports them. There might be meters where it is implemented, but our clients do not use them.
lugaflo
7 years 1 month ago
Dears, are there any progress
Dears, are there any progress on the ZigBee protocol implementation ? I will work on a use case with an EDMI meter. Any information is welcome.
7 years 1 month ago
You can generate frames with Gurux.DLMS library and send them using Zigbee. There are no Zigbee media at the moment.
lugaflo
7 years 1 month ago
Thanks Mikko. We will then
Thanks Mikko. We will then develop a light Zigbee media.
Florent
7 years 1 month ago
Hi Florent,
Hi Florent,
Let me know if you need any assistant.
lugaflo
7 years 1 month ago
In reply to Hi Florent, by Kurumi
OK. Thx.
OK. Thx.
