  3. How To Run Python Frmaework In Windows?
how to run python frmaework in windows?
By Ram , 16 July, 2019
Gurux.Serial
Im running my python library but im getting error like this
PFA
7 years ago
Check GetReadOut method. It reads all objects and attributes of each object.
Ram
7 years ago
C:\Users\test.EMMYS1546\Desktop\Gurux.DLMS.Python-master_old version\Gurux.DLMS.Client.Example.python>main.py -S COM3 -g "0.0.40.0.2.255"
File "C:\Users\test.EMMYS1546\Desktop\Gurux.DLMS.Python-master_old version\Gurux.DLMS.Client.Example.python\main.py", line 53, in main
ret = settings.getParameters(args)
File "C:\Users\test.EMMYS1546\Desktop\Gurux.DLMS.Python-master_old version\Gurux.DLMS.Client.Example.python\TVMSettings.py", line 183, in getParameters
raise ValueError("Invalid Logical name or attribute index.")
ValueError: Invalid Logical name or attribute index.
we are getting this error If we run with single Obis code without attribute, but we want to get all values related to that OBIS code.
Ram
7 years ago
We are getting OBIS codes from meter right.Is that OBIS codes are saved anywhere.For that we have any code?
7 years ago
You need to add attribute index after the OBIS code. Like this:
0.0.40.0.2.255:2
You can save OBSIS codes to the file and read them when needed.
Ram
7 years ago
We tried that also still we are getting the error. Like this:
C:\Users\test.EMMYS1546\Desktop\Gurux.DLMS.Python-master_old version\Gurux.DLMS.Client.Example.python>main.py -S COM3 -g "0.0.40.0.2.255:2"
ClientAddress: 0x10
File "C:\Users\test.EMMYS1546\Desktop\Gurux.DLMS.Python-master_old version\Gurux.DLMS.Client.Example.python\main.py", line 79, in main
val = reader.read(settings.client.objects.findByLN(ObjectType.NONE, k), v)
File "C:\Users\test.EMMYS1546\Desktop\Gurux.DLMS.Python-master_old version\Gurux.DLMS.Client.Example.python\TVMDLMSReader.py", line 287, in read
data = self.client.read(item, attributeIndex)[0]
File "C:\python3\lib\site-packages\gurux_dlms\GXDLMSClient.py", line 925, in read
return self._read(item.name, item.objectType, attributeOrdinal)
AttributeError: 'NoneType' object has no attribute 'name'
7 years ago
There is no object "0.0.40.0.2.255: in the association view. You need to change the authentication level.
Ram
7 years ago
where we need to change the authentication level? Directly while running we have to give otherwise we need to make changes in code. We gave like this:
C:\Users\test.EMMYS1546\Desktop\Gurux.DLMS.Python-master_old version\Gurux.DLMS.Client.Example.python>main.py -S COM3-a low -P lnt1
File "C:\Users\test.EMMYS1546\Desktop\Gurux.DLMS.Python-master_old version\Gurux.DLMS.Client.Example.python\TVMSettings.py", line 121, in getParameters
parameters = TVMSettings.__getParameters(args, "h:p:c:s:r:it:a:p:wP:g:S:")
File "C:\Users\test.EMMYS1546\Desktop\Gurux.DLMS.Python-master_old version\Gurux.DLMS.Client.Example.python\TVMSettings.py", line 103, in __getParameters
raise ValueError("Invalid parameter: " + args[index])
ValueError: Invalid parameter: low
Thanks.
7 years ago
HI,
HI,
You must Give authentication level as "Low". You also need to change client address.
Something like:
main.py -S COM3-a Low -P lnt1 -c = 1
Ram
7 years ago
We tried like u said but it's disconnecting, we are getting like:
C:\Users\test.EMMYS1546\Desktop\Gurux.DLMS.Python-master_old version\Gurux.DLMS.Client.Example.python>main.py -S COM3 -c 32 -a Low -P lnt1
ClientAddress: 0x20
in reader auth
Authentication.LOW
RX: 14:28:30 7E A0 10 41 03 52 47 E1 E6 E7 00 0E 06 03 02 91 24 7E
Ram
7 years ago
While reading data we are getting error something like:
Error! Index: 1 setValue
setValue
File "C:\Users\test.EMMYS1546\Downloads\Gurux.DLMS.Python-master (1)\Gurux.DLMS.Python-master\Gurux.DLMS.Client.Example.python\GXDLMSReader.py", line 365, in getReadOut
val = self.read(it, pos)
File "C:\Users\test.EMMYS1546\Downloads\Gurux.DLMS.Python-master (1)\Gurux.DLMS.Python-master\Gurux.DLMS.Client.Example.python\GXDLMSReader.py", line 263, in read
return self.client.updateValue(item, attributeIndex, reply.value)
File "C:\python3\lib\site-packages\gurux_dlms\GXDLMSClient.py", line 727, in updateValue
target.setValue(self.settings, e)
File "C:\python3\lib\site-packages\gurux_dlms\objects\GXDLMSExtendedRegister.py", line 145, in setValue
super(GXDLMSExtendedRegister, self).setValue(settings, e)
File "C:\python3\lib\site-packages\gurux_dlms\objects\GXDLMSObject.py", line 262, in setValue
raise ValueError("setValue")
ValueError: setValue
once look into it.
Ram
7 years ago
Is it necessary to give Attribute index along with OBIS code in command prompt to get all attribute values of that OBIS code or else Is it sufficient to give only OBIS code.
waiting for your fast rply
7 years ago
Hi Ram,
Hi Ram,
ExtendedRegister issue is fixed. Get the latest version (1.0.27).
Attribute index is mandatory. You can modify the example for your needs if you don't want to give attribute index.
Ram
7 years ago
For every OBIS code of 2nd attribute index we are getting error instead of values
something like:
C:\Users\test.EMMYS1546\Downloads\Gurux.DLMS.Python-master (1)\Gurux.DLMS.Python-master\Gurux.DLMS.Client.Example.python>main.py -S COM3 -c 32 -s 1 -a Low -P lnt1 -g "0.0.94.91.10.255:2"
ClientAddress: 0x20
File "C:\Users\test.EMMYS1546\Downloads\Gurux.DLMS.Python-master (1)\Gurux.DLMS.Python-master\Gurux.DLMS.Client.Example.python\main.py", line 77, in main
File "C:\python3\lib\site-packages\gurux_dlms\objects\GXDLMSProfileGeneric.py", line 380, in setValue
self.setBuffer(e)
File "C:\python3\lib\site-packages\gurux_dlms\objects\GXDLMSProfileGeneric.py", line 456, in setBuffer
raise ValueError("Read capture objects first.")
ValueError: Read capture objects first.
Ram
7 years ago
For 3rd attribute index we
For 3rd attribute index we are getting object references instead of OBIS
Like:
C:\Users\test.EMMYS1546\Downloads\Gurux.DLMS.Python-master (1)\Gurux.DLMS.Python-master\Gurux.DLMS.Client.Example.python>main.py -S COM3 -c 32 -s 1 -a Low -P lnt1 -g "0.0.94.91.10.255:3"
ClientAddress: 0x20
Index: 3 Value: (<gurux_dlms.objects.GXDLMSData.GXDLMSData object at 0x0000020AFE9FBE48>, <gurux_dlms.objects.GXDLMSCaptureObject.GXDLMSCaptureObject object at 0x0000020AFE9E92E8>), (<gurux_dlms.objects.GXDLMSData.GXDLMSData object at 0x0000020AFE9FBEF0>, <gurux_dlms.objects.GXDLMSCaptureObject.GXDLMSCaptureObject object at 0x0000020AFE9E91D0>), (<gurux_dlms.objects.GXDLMSData.GXDLMSData object at 0x0000020AFEA0D278>, <gurux_dlms.objects.GXDLMSCaptureObject.GXDLMSCaptureObject object at 0x0000020AFE9E9208>), (<gurux_dlms.objects.GXDLMSData.GXDLMSData object at 0x0000020AFE9FB978>, <gurux_dlms.objects.GXDLMSCaptureObject.GXDLMSCaptureObject object at 0x0000020AFE9E93C8>), (<gurux_dlms.objects.GXDLMSData.GXDLMSData object at 0x0000020AFE9FBB38>, <gurux_dlms.objects.GXDLMSCaptureObject.GXDLMSCaptureObject object at 0x0000020AFE9E96A0>), (<gurux_dlms.objects.GXDLMSData.GXDLMSData object at 0x0000020AFE9FBBE0>, <gurux_dlms.objects.GXDLMSCaptureObject.GXDLMSCaptureObject object at 0x0000020AFE9E9358>), (<gurux_dlms.objects.GXDLMSData.GXDLMSData object at 0x0000020AFEA0D320>, <gurux_dlms.objects.GXDLMSCaptureObject.GXDLMSCaptureObject object at 0x0000020AFE9E9128>), (<gurux_dlms.objects.GXDLMSData.GXDLMSData object at 0x0000020AFEA0D5C0>, <gurux_dlms.objects.GXDLMSCaptureObject.GXDLMSCaptureObject object at 0x0000020AFE9E9668>), (<gurux_dlms.objects.GXDLMSData.GXDLMSData object at 0x0000020AFE9FBF98>, <gurux_dlms.objects.GXDLMSCaptureObject.GXDLMSCaptureObject object at 0x0000020AFE9E9710>)
Thnaks
Ram
7 years ago
while trying to upgrade the requirements we are getting error like:
C:\Users\test.EMMYS1546\Desktop\Gurux.DLMS.Python-master\Gurux.DLMS.Client.Example.python>pip install -r requirements.txt
Requirement already satisfied: pytz==2019.2 in c:\python3\lib\site-packages (from -r requirements.txt (line 1)) (2019.2)
Requirement already satisfied: python-dateutil==2.8.0 in c:\python3\lib\site-packages (from -r requirements.txt (line 2)) (2.8.0)
Requirement already satisfied: gurux-common==1.0.13 in c:\python3\lib\site-packages (from -r requirements.txt (line 3)) (1.0.13)
Collecting gurux-dlms==1.0.27 (from -r requirements.txt (line 4))
ERROR: Could not find a version that satisfies the requirement gurux-dlms==1.0.27 (from -r requirements.txt (line 4)) (from versions: 1.0.6, 1.0.7, 1.0.8, 1.0.9, 1.0.11, 1.0.12, 1.0.14, 1.0.16, 1.0.17, 1.0.18, 1.0.19, 1.0.20, 1.0.21, 1.0.22, 1.0.23, 1.0.24, 1.0.25, 1.0.26)
ERROR: No matching distribution found for gurux-dlms==1.0.27 (from -r requirements.txt (line 4))
7 years ago
GXDLMSCaptureObject contains a reference to an object. You can get OBSIS code from there.
Version 1.0.27 is interesting. I can see the version here:
https://pypi.org/project/gurux-dlms/
But when I run pip install --upgrade it updates to version 1.0.26.
Maybe they are making some improvements to pypi.org and we need to wait for a while.
Ram
7 years ago
Is it possible to retrieve OBSIS code from GXDLMSCaptureObject? If possible how?
7 years ago
It's something like this:
I'll create profile generic object here:
pg = GXDLMSProfileGeneric()
for k, v in pg.captureObjects:
print(k.logicalName)
Ram
7 years ago
something like:
ClientAddress: 0x20
self.setBuffer(e)
7 years ago
You need to read capture objects first before you read profile generic buffer.
1. Read attribute 3. (capture objects)
2. Read attribute 2. (buffer)
Ram
7 years ago
In get parameters function we added the code like below to get all attributes of OBSIS code, here we have fixed the attributes using range function but when we try with getattributeIndex function we are getting error. how to solve this issue.
elif it.tag == 'g':
# Get (read) selected objects.
for o in it.value.split(";,"):
tmp = o.split(":")
if len(tmp) != 2:
if len(tmp) == 1:
for i in range(1,8):
tmp.insert(1,i)
self.readObjects.append((tmp[0].strip(), int(tmp[1])))
else:
Ram
7 years ago
We are getting 2nd Attribute of OBIS like below:
C:\Users\test.EMMYS1546\Desktop\Gurux.DLMS.Python-master\Gurux.DLMS.Client.Example.python>main.py -S COM3 -c 32 -s 1 -a Low -P lnt1 -g "1.0.94.91.0.255:3;, 1.0.94.91.0.255:2"
ClientAddress: 0x20
Index: 2 Value: [<gurux_dlms.GXDateTime.GXDateTime object at 0x0000026CD2233048>, 0, 0, 0, 5551, 0, 0, 0, 0, 0, 0, 5001, 0, 0, 0, 2, 15820, 6, 2, 0, bytearray(b'\x07\xe3\t\x01\xff\x00\x00\xff\xff\x01J\x00'), 0, 0, 0, 0, 0, <gurux_dlms.GXDateTime.GXDateTime object at 0x0000026CD2233DA0>, 0, <gurux_dlms.GXDateTime.GXDateTime object at 0x0000026CD2233D68>, 0, 0, 0, 0, 99005, 99005, bytearray(b'\x00\x01\x01'), 99005, 99005, 99005, bytearray(b'\x01\x01\x01'), 99005, bytearray(b'\x01\x00\x00'), 0, bytearray(b'\x00\x00\x00'), 0, 0, 0, bytearray(b'\x00\x00\x00'), 0, bytearray(b'\x00\x00\x00'), 0, bytearray(b'\x00\x00\x00'), 0, bytearray(b'\x00\x00\x00'), 0, bytearray(b'\x00\x00\x00'), 0, bytearray(b'\x00\x00\x00'), 0, 0, 0, 0, 0, 0, 0, 0] DisconnectRequest
we are getting date.time object we are not getting values there, how and where to modify it.
Ram
7 years ago
for some values we are
for some values we are getting bytearray why is it like that?
7 years ago
For GXDateTime use str() method to transform it into the string. You are receiving byte arrays because the meter is sending a value as byte array.
Ram
7 years ago
what about reply 72
what about reply 72
Ram
7 years ago
elif it.tag == 'g':
tmp = o.split(":")
if len(tmp) != 2:
if len(tmp) == 1:
tmp.insert(1,i)
else:
waiting for reply
6 years 12 months ago
I prose that you add a list of attributes what you want to read. Like this:
-g "0.0.1.0.0.255:1;0.0.1.0.0.255:2"
BR
Ram
That is okay we are able to get values using attribute index.but we want to get all values directly using obis code.that is also we are able to do it.
But if we want to getattributeindextoread() function in gxdlmsSettings.py which package/library i need to import.
Amount of attributes depends on the object you want to read.
You need to create that object what you want to read first and then ask how many attributes there are.
Pagination
  • First page
  • Previous page
  • Page 1
  • Page 2
