  3. Aarq
aarq
By hasha , 16 May, 2019
Gurux.Net
Hello, Gurux
I have try gurux.DLMS.Meter.Listener.Net . I am using Holley DTSD545 with gprs modem using dynamic addressing. So I have faced some problem and I show it below picture. I think I change AARQ, then I will be pass that error. Because, Holley DTSD545S meter AARQ is:
00 01 00 11 00 01 00 3C 60 3A 80 02 02 84 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 30 30 30 30 30 30 30 30 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 FF FF FF 28 00
My question is how can I change AARQ? is possible or not?
Please help me?
7 years 1 month ago
Change client address to 0x11. Now it's 0x10. Change authentication level from None to Low. Password is "00000000".
hasha
7 years 1 month ago
wow, very thanks for your
wow, very thanks for your kind reply.
hasha
7 years ago
Hello Mr. Mikko
Hello Mr. Mikko
Sorry for trouble with you. I can't connect my meter. Please help me where is the problem?
I am attaching my log
"This server is listening port 7011 and waiting incoming connections from the meters.
This server can be used with DLMS meters that are using dynamic IP addresses.
Client 66.181.161.40:33611 is connected.
Send AARQ request
<- 12:23:46 PM 00 01 00 11 00 01 00 38 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 30 30 30 30 30 30 30 30 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF
-> 12:23:47 PM 00 01 00 01 00 11 00 12 DD 10 30 30 30 30 30 30 30 30 31 37 31 33 30 34 30 37
Disconnecting from the meter.
Secure connection is not supported."
7 years ago
Meter returns invalid reply. Check that you can connect directly to the meter with those settings.
Ask meter vendor if any optional commands need to send before connection.
