  3. Gurux Dlms Ansi C Multi Drop Communication
gurux dlms ansi c multi drop communication
By raghavendra , 27 March, 2019
Hi sir,
Presently i want to read multiple energy meters using rs485. how i can achieve .as per my understanding using server address i can read mutiplemeters but if both meters server address same than i want to change server address. any function is there in ansi c code to read and set server id. i searched in stack but i am not able to get any function please tel me how to do i am hopefully waiting for you replay sir.
Raghavendra
7 years 7 months ago
Hi Raghavendra,
Hi Raghavendra,
You need to count server address from the serial number. Formula is : 0x4000 | SN % (10000 + 1000).
raghavendra
In reply to Hi Raghavendra, by Kurumi
Gurux dlms ansi c profile generic
Hi sir,
How to use this formula. where i want use i dont understand anything . I am new for this concept.please briefly explain me how to do muli drop using rs485 . What are the ansi c functions i want to use to make mutidrop
Raghavendra
Hi Raghavendra,
Hi Raghavendra,
You communicate as with one meter. You just change server address from 1 to serial number.
You count server address using this formula:
0x4000 | [Server address] % (10000 + 1000).
raghavendra
Hi sir,
Thank you so much your replay.i am trying to change server address using this formula .
Raghavendra
raghavendra
Hi sir,
Using this formula how i can set server address.i want to send request to meter to set server address?. there is any functions is there in ansi c dlms code to set server address?
Raghavendra.B
con.settings.serverAddress = server address;
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
