  3. Rejected-permanent With Electricity Meter
Rejected-permanent with electricity meter
By Mihai Enuta , 21 November, 2018
Hi!
I am trying to connect to a meter (which is in server mode, as I understand it should be) using DMLS director. And whatever I try, I keep getting rejected.
What I send:
0001000B0001001F601DA109060760857405080101BE10040E01000000065F1F040060FEDFFFFF
decoded:
<AssociationRequest>
<InitiateRequest>
<ProposedConformance>
<ConformanceBit Name="EventNotification" />
<ConformanceBit Name="Set" />
<ConformanceBit Name="Get" />
<ConformanceBit Name="DataNotification" />
<ConformanceBit Name="Attribute0SupportedWithGet" />
<ConformanceBit Name="PriorityMgmtSupported" />
<ConformanceBit Name="Attribute0SupportedWithSet" />
</ProposedConformance>
</InitiateRequest>
</AssociationRequest>
What I get: 00010001000B002B6129A109060760857405080101A203020101A305A1030201FFBE10040E0800065F1F040000181F00800007
<AssociationResponse>
<AssociationResult Value="01" />
<ResultSourceDiagnostic>
<ACSEServiceUser Value="FF" />
</ResultSourceDiagnostic>
<InitiateResponse>
<NegotiatedConformance>
</NegotiatedConformance>
<NegotiatedMaxPduSize Value="0080" />
<VaaName Value="0007" />
</InitiateResponse>
</AssociationResponse>
What am I doing wrong, here?
The diagnostic info from the meter is not very helpful.
Thank you!
7 years 10 months ago
What meter did you try to read? Returned Associate-source-diagnostic is invalid and it is not in the standard.
You should ask this from the meter manufacturer and ask them to fix this. Reason for the failure might be anything.
Mihai Enuta
The meter is a Ningbo Sanxing Electric Co.,Ltd SX5A2-SELS-04. It has a DMLS User Association Certification number 1248.
I also suspected they are not according to standard since Gurux and also Wireshark dissector are failing to read any of their responses.
Weird they have this certification that they passed DLMS/Cosem Conformance test.
Thank you for helping!
One thing what you can try to do is change server address 1 and client address 10. Now it is 11 (0xB).
Mihai Enuta
Unfortunately the result is
Unfortunately the result is the same:
0001000A0001001F601DA109060760857405080101BE10040E01000000065F1F040060FEDFFFFF
00010001000A002B6129A109060760857405080101A203020101A305A1030201FFBE10040E0800065F1F040000181F00800007
I tried several combinations of client and server address, without success.
I think only the manufacturer can help, if they are willing.
Thank you for your support!
7 years 7 months ago
I checked meter reply and it's not correct. ResultSourceDiagnostic is 0xFF. This value is not correct. Standard defines values from 0 to 14. So there is an issue on the meter.
