  3. Landis+gyr G350 IR Readout
Landis+gyr g350 IR readout
By yctn , 21 September, 2018
Im trying to do a readout on a landis+gyr g350. i have ab IR head which works just fine on my iskra MT171.
when i just send /?! i get =========================
as output
when i send: /?!\r\n. 2F 3F 21 0D 0A
i get this as output: /?!
. 2F 3F 21 0D 0A
here is my python script im using:
import time
import serial
import re
ser = serial.Serial(
port='/dev/ttyUSB0',
baudrate=300,
parity=serial.PARITY_EVEN,
stopbits=serial.STOPBITS_ONE,
bytesize=serial.SEVENBITS,
while 1:
ser.flushInput()
ser.write('/?!\r\n. 2F 3F 21 0D 0A')
time.sleep(15)
output=ser.read(ser.inWaiting())
print output
print '========================='
ser.flushInput()
7 years 10 months ago
Your meters are using different protocols.
Iskraemeco MT-171 is using IEC 62053-21
Landis+Gyr G350 is using M-Bus.
yctn
Any idea if i can read out the meter by using M-bus?
M-bus
Find a software that supports it or make own app. M-Bus isn't a very complicated protocol.
yctn
7 years 9 months ago
hi, i found https://github
hi, i found https://github.com/rscada/libmbus and i tryed to scan with mbus-serial-scan for an address but it didnt find any address. so at this moment im not sure if i can communicate with the meter at all. any idea's?
M-bus
I'm sorry, but we have not communicated with M-bus devices for a long time and I just can't remember this anymore.
Rohit
I have l&t em101+ meter .
How reset value of kwh to 0.
Pls describe strat to end process.
In reply to Hi by Rohit
L&G em101
Your meter is not DLMS meter and we don't know how to do this. You should ask this info from the meter vendor.
  • CTKNhZElptjSlOrpkXl
  • YCbccqfLGRMnlCWoJhXP
  • Malcolmactig
  • mhliang
  • Kevinmug
