  3. The System Cannot Find The Reference Specified GuruX.DLMS
The system cannot find the reference specified GuruX.DLMS
Profile picture for user Joshua SOONG
By Joshua SOONG , 6 October, 2018
I downloaded the example code Gurux.DLMS.Client.Example.VB. I am using VS 2017. When I open the project, it says "The system cannot find the reference specified GuruX.DLMS" for GuruX.DLMS. I went into "My Project" then "References". I added the "GuruX.DLMS.dll" file and yet this error persists. Can someone advice how to resolve this?
Much appreciate.
7 years 11 months ago
You need to install nuget.org for VS 2017. That will download all libraries automatically for you.
Joshua SOONG
In reply to The system cannot find the reference specified GuruX.DLMS by Kurumi
It is the same problem. I downloaded the nuget.org version 4.7.1. When I run the example client vb program, it is the same error message.
How can I specifically solve this?
Thanks in advance.
7 years 10 months ago
Do you have the latest version from the source code? I just try and it works without problems.
You can try this:
Select project file. and press right mouse button. Select "Manage Nuget Packages.." from the pop-up menu. Update all references.
