  3. Problem With ACE6000
Problem with ACE6000
By camilo.zapata , 18 September, 2018
I have an ACE6000 meter and I read it without problems with the default configuration, but suddenly I started answering "Connection is permanently rejected. Authentication failure", I already tried with another meter and it does respond. Does anyone know how to reset the meter configuration to the default?
Thank you
I'm sorry for my English
Send SNRM request.
TX: 7E A0 08 02 23 03 93 3E 74 7E
RX: 7E A0 23 03 00 02 00 23 73 C0 48 81 80 14 05 02 00 80 06 02 00 80 07 04 00 00 00 01 08 04 00 00 00 01 CE 6A 7E
Send AARQ request.
TX: 7E A0 45 02 23 03 10 FB 7F E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 41 42 43 44 45 46 47 48 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF 19 02 7E
RX: 7E A0 53 03 00 02 00 23 30 13 29 E6 E7 00 61 42 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 01 A3 05 A1 03 02 01 0D 88 02 07 80 89 07 60 85 74 05 08 02 01 AA 0A 80 08 00 00 00 00 00 00 00 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 10 1D 21 34 00 07 A3 8E 7E
RX: 7E A0 0A 03 00 02 00 23 73 7A 6A 7E
Disconnect request
TX: 7E A0 08 02 23 03 53 32 B2 7E
RX: 7E A0 0A 03 00 02 00 23 1F 10 C3 7E
8 years ago
You need a password if you want to do it programmatically. You should ask this info from the meter vendor.
Note! you will lose all the readings if you reset the meter.
