  3. GuruX DLMS Protocol Porting On Microcontroller
GuruX DLMS Protocol Porting on Microcontroller
By bagdeparag , 24 August, 2018
I am working on Genus 3-phase meter with DLMS Protocol.
I can check data using a Common Meter Reading Instrument, even I can check data using GXDLMSDirector via optical port.
I suppose to collect the meter data via Serial/Optical port using Microcontroller and send it further.
I am using 16-bit microcontroller with 16KB SRAM & 128KB ROM and a IDE with C++ AVR Compiler.
My queries are:
1. Is my controller is sufficient to handle the GuruX DLMS Stack?
2. As I am using only Serial Port for communication, can I skip, ignore or comment out the code related to other communication media. If YES, which files can be excluded from the project?
3. I am getting STL related error while compiling. Please suggest the STL link that includes all the files required to successful compilation.
4. Kindly suggest the essential defines to begin...
Thanks & Regards...
7 years 10 months ago
I believe that you need to use our ANSI C stack. It's not open source.
Send an email to me if you are interested in it.
bagdeparag
Thanks for Replay Mikko...
Yes... I am interested.
Please Share email address.
Thanks & Regards...
