  3. Gcc Version Required
gcc version required
By xxq20121221 , 12 June, 2018
if I want to compile the DLMS.c or DLMS.cpp on linux and use the gcc tool chain,which version is required?
secondtononewe
8 years 3 months ago
gcc version should update to bigger than Ver4.7?
I compile the DLMS,and meet a promblem:
debian:/home/zhangling/Gurux.DLMS.cpp-master/development# make
Compiled src/GXAdjacentCell.cpp successfully!
Compiled src/GXAPDU.cpp successfully!
Compiled src/GXApplicationContextName.cpp successfully!
Compiled src/GXAuthenticationMechanismName.cpp successfully!
Compiled src/GXBytebuffer.cpp successfully!
Compiled src/GXCipher.cpp successfully!
Compiled src/GXDateTime.cpp successfully!
Compiled src/GXDLMSActionItem.cpp successfully!
src/GXDLMSActionSchedule.cpp: In constructor ‘CGXDLMSActionSchedule::CGXDLMSActionSchedule()’:
src/GXDLMSActionSchedule.cpp:44: error: type ‘CGXDLMSActionSchedule’ is not a direct base of ‘CGXDLMSActionSchedule’
src/GXDLMSActionSchedule.cpp: In constructor ‘CGXDLMSActionSchedule::CGXDLMSActionSchedule(std::string)’:
src/GXDLMSActionSchedule.cpp:49: error: type ‘CGXDLMSActionSchedule’ is not a direct base of ‘CGXDLMSActionSchedule’
make: *** [obj/GXDLMSActionSchedule.o] 错误 1
Does the mistake related to the gcc version?
Our versions are newer. Let me know if you can't update to the newer version and we'll fix those few issues.
Errors are coming because your compiler doesn't support delegating constructors.
https://secure.wikimedia.org/wikipedia/en/wiki/C++11#Object_constructio…
secondtononewe
In reply to gcc version should update to bigger than Ver4.7? by Kurumi
Thank you very much, we
Thank you very much, we choose to modify it to fit our compiler instead of upgrading gcc version.
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
