  3. How To Setup DLMSDirector To Listen and Display PUSH Message On Its GUI
How to setup DLMSDirector to listen and display PUSH message on its GUI
By biswa.pal , 19 June, 2018
I am trying to use DLMSExplorer to be able to listen to a TCP port 4059 for TCP wrapper COSEM packet. I have tried to do it myself, and used an Hercules windows utility to connect to machine with Gurux listening at port 4059 port. From Hercules I send the wrapper packet, but there is no sign or traffic being displayed on Gurux GUI.
If I used another listener like Hercules at the TCP listening end, the same wrapper traffic is seen as expected. So, there must be something I am missing to setup the Gurux DLMSEDirector properly. Can someone help me to do it correctly with probably some instructions or snapshorts, will be great help for me.
Best regards,
Biswanath
7 years 11 months ago
DLMS PUSH message on GXDLMSDirector
You can see Push messages selecting "View" | "Notifications" | "Hex" menu. Then you need to start the listener.
Select "Start" from "Notifications".
Default Port is 4059. You can change it from Notifications tab selecting "Tools" | "Settings" menu.
biswa.pal
In reply to DLMS PUSH message on GXDLMSDirector by Kurumi
Thank you very much!
I can see the Hex and PDU option even gives some parsed information, quite helpful for me.
Best regards,
Biswanath
