  3. Decrypted Log
Decrypted log
Profile picture for user sluge
By sluge , 8 June, 2018
I'm working with meter that uses Encryption and Authentication. I log my exchange with meter, it is several MBs, but all data are ciphered. Is any way in DLMS Director to log decrypted data to the log, because there are no ways to decrypt it?
8 years ago
Decrypted log
You can do this if you select "Xml" and Comments from "View Log".
sluge
7 years 12 months ago
Not workig
Hello Mikko,
I've set xml and comments, but unfortunately no decrypted APDS and no comments at all
Decrypted log
I just check this. I'm sorry, data is decrypted to trace view, not log file.
If you select "Pdu" and "Comments" from "Trace" menu you see something like this:
<!--Decrypt data:
<GetResponse>
<GetResponseNormal>
<Result>
<Data>
<Enum Value="00" />
</Data>
</Result>
</GetResponseNormal>
</GetResponse>
<glo_GetResponse Value="3000000008A5256B89C71637D3DAA6017D07D012A34982" />
sluge
Hello Mikko,
Thanks, that's working Ok. But better to add this feature to log also
Decrypted log
Reason for this is that log is same for all the clients and each client might have own encryption settings. I'll add this to the work list, but this is with a low priority.
