  3. Problem With Special Days
Problem with Special Days
By AndreasAtPowel , 22 March, 2018
Hello
I´m having some problem setting special days. I have a tool that´s not using Gurux, setting the special day from there succeeds, setting the special day with Gurux fails. The data sent from the tool looks like this:
0x00, 0x01, 0x00, 0x01, 0x00, 0x01, 0x00, 0x1b,
0xc3, 0x01, 0xc1, 0x00, 0x0b, 0x00, 0x00, 0x0b,
0x00, 0x00, 0xff, 0x01, 0x01, 0x02, 0x03, 0x12,
0x00, 0x03, 0x09, 0x05, 0xff, 0xff, 0x0c, 0x19,
0xff, 0x11, 0x00
When I try to set the same special day with Gurux, I send the following data:
0x00, 0x01, 0x00, 0x01, 0x00, 0x01, 0x00, 0x1f,
0xc3, 0x01, 0x41, 0x00, 0x0b, 0x00, 0x00, 0x0b,
0x00, 0x00, 0xff, 0x01, 0x01, 0x09, 0x10, 0x01,
0x01, 0x02, 0x03, 0x12, 0x00, 0x03, 0x09, 0x05,
0xff, 0xff, 0x0c, 0x19, 0xff, 0x11, 0x00
There are some extra bytes in the data sent with Gurux:
0x09, 0x10, 0x01, 0x01
What are these bytes? Is that was causing the problem?
Regards
Helena
8 years 8 months ago
Are you using C#, ANSI C, ANSI C++ or Java version?
BR,¨
AndreasAtPowel
We are using C# /Helena
We are using C#
/Helena
GXDLMSSpecialDaysTable
Are using GXDLMSSpecialDaysTable.Insert method to add this entry?
Or are you generating this by yourself?
AndreasAtPowel
Yes, we are using Insert.
/Helena
AndreasAtPowel
Hello
Hello
Are you looking at this, if it´s a bug in Gurux? We are using version 8.5.1711.1701 of Gurux.DLMS.Net. I can´t see that you have made any changes regarding SpecialDays since then. It´s quite urgent for us to get pass this problem.
Regards
Helena
We are checking this. I'll give more information today.
This is fixed in Version 8.5.1803.0401. Get the latest version.
AndreasAtPowel
Thank you, now it works :-)
Regards
Helena
Hi Helena
Thanks for this info. Have a nice and relaxing Easter.
  • Tb. Laris Jaya | WA 083148835648
