  3. Setting of EMI Metering
Setting of EMI metering
By Valendil1403 , 4 January, 2018
Its is first time setting up a EMI metering (LZQJ-XC).
Any tips on the way?
How to we select current transformer 5A/300A
We want to use RS485 DLMS and convert it to IEC61850 protocol. Using Kalkitech gatway, never used it before.
8 years 10 months ago
LZQJ-XC
Are you sure from the model? As far as I know, LZQJ-XC is from EMH, not EMI.
You should ask from gateway from Kalkitech.
Valendil1403
In reply to LZQJ-XC by Kurumi
Hi.
Hi.
It is EMH.
I think I will try using the GuruX software first.
Do you know if it is possible to configure the meter from the software?
If it's EMH you can use GXDLMSDirector to read your meter.
Check right settings from
Find EMH metering GmbH settings
Note! You need to set serial number to same as in the meter.
Valendil1403
Do you know if it is possible to change some of the settings?
Write from GuruZ to the EMH meter?
OBIS:
0.4.1 Readout factor energy
0.4.2 Transformer factor current
0.4.3Transformer factor voltage
Write from GuruX to the EMH meter
If you want to edit that value in GXDLMSDirector you should be able to write it.
You need to verify what client address you should use from a vendor.
You need to know also the password.
  • Toko Tiga Saudara | WA 083148835648
  • Tb. Laris Jaya | WA 083148835648
