  3. Secure I-credit 350 Shows Data But Not Register
Secure i-credit 350 shows data but not register
By kajal , 11 September, 2017
Hello Sir,
I want to read Secure i-credit 350 meter. I am trying since 15 days and i established connection but, i am not able to read voltage and current.
As i am using DLMS Protocol, i found in one post and you suggest there to refresh device after connection, it will automatically read supported OBIS Code from meter. but, in my case it is not working.
i attachedDLMS connection JPEG file. Kindly Reply me.
i used only one OBIS Code and that is Data-0.0.42.0.0.255
Manufacture settings:
Flag ID:EHL
Using logical name referencing: checked
keepinterval: 40
start protocol: DLMS
Addressing:
authenticatoin:none
client address
address(hex):10
server address
address type:Default
serial number formula
physical:1
logical:0
Device properties:
manufacture:Secure meter
Logical name referencing:checked
start protocol:DLMS
media:serial
authentical:none
password:
waittime:7
client address: 10
address type:default
physical address:1
logical address:0
settings
serial port:COM11
My log file is also here.
GXDLMSDirector 8.0.1708.1801
Log created 03:27:25 PM
03:27:35 PM Initializing serial connection.
03:27:35 PM Send SNRM request.
7E A0 0F 03 21 93 D7 E4 81 80 03 06 01 80 6B 66 7E
03:27:35 PM Received data
7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
03:27:35 PM Parsing UA reply.<CR><LF>81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01
03:27:35 PM Parsing UA reply succeeded.
03:27:35 PM
7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 1E 1C FF FF 3B 7F 7E
7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 10 18 00 80 00 07 16 C7 7E
03:27:35 PM Parsing AARE reply succeeded.
03:27:59 PM Read object type Data index: 2
7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 C1 00 01 01 00 00 00 06 FF 02 00 59 E6 7E
03:27:59 PM Received data
7E A0 19 21 03 52 69 1D E6 E7 00 C4 01 C1 00 09 07 45 53 4C 2D 30 30 32 8F 8F 7E
7E A0 19 03 21 54 5F DE E6 E6 00 C0 01 C1 00 01 00 00 60 01 00 FF 02 00 89 A0 7E
03:28:00 PM Received data
7E A0 1A 21 03 74 90 7C E6 E7 00 C4 01 C1 00 09 08 58 42 35 39 30 31 31 34 A8 AF 7E
03:28:00 PM Read object type Data index: 2
7E A0 19 03 21 76 4F DC E6 E6 00 C0 01 C1 00 01 01 00 00 00 01 FF 02 00 78 B1 7E
7E A0 19 21 03 96 41 9D E6 E7 00 C4 01 C1 00 09 07 4E 31 58 31 47 30 41 EE F6 7E
7E A0 19 03 21 98 3F D2 E6 E6 00 C0 01 C1 00 01 00 00 2A 00 00 FF 02 00 12 80 7E
7E A0 1B 21 03 B8 4B 6C E6 E7 00 C4 01 C1 00 09 09 45 48 4C 45 31 43 78 78 78 B1 67 7E
03:28:00 PM Read object type Clock index: 2
7E A0 19 03 21 BA 2F D0 E6 E6 00 C0 01 C1 00 08 00 00 01 00 00 FF 02 00 60 1A 7E
7E A0 1E 21 03 DA 08 42 E6 E7 00 C4 01 C1 00 09 0C 07 E1 09 0B 01 0F 1B 3B 00 80 00 00 56 6E 7E
7E A0 19 03 21 DC 1F D6 E6 E6 00 C0 01 C1 00 01 00 00 60 05 04 FF 02 00 75 FF 7E
7E A0 15 21 03 FC 29 C6 E6 E7 00 C4 01 C1 00 06 00 00 00 00 7D 18 7E
03:28:40 PM Send Keep Alive
7E A0 19 03 21 FE 0F D4 E6 E6 00 C0 01 C1 00 0F 00 00 28 00 00 FF 01 00 F9 79 7E
03:28:41 PM Received data
7E A0 18 21 03 1E BA 89 E6 E7 00 C4 01 C1 00 09 06 00 00 28 00 00 FF B6 6E 7E
03:29:20 PM Send Keep Alive
7E A0 19 03 21 10 7F DA E6 E6 00 C0 01 C1 00 0F 00 00 28 00 00 FF 01 00 F9 79 7E
03:29:20 PM Received data
7E A0 18 21 03 30 C6 41 E6 E7 00 C4 01 C1 00 09 06 00 00 28 00 00 FF B6 6E 7E
03:30:00 PM Send Keep Alive
7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 C1 00 0F 00 00 28 00 00 FF 01 00 F9 79 7E
9 years 2 months ago
Usually problem is that you must use Low authentication to get all data.
With some meters connection without authentication will show only small part of the data.
You need password if you want to use Low or High Authentication. You must ask this from meter vendor if that is not on the manual. We don't know it.
kajal
Hello Sir,
Hello Sir,
Thank you for your quick reply.. i asked my vendor for authentication password.
now, my other question is that is it possible to connect meter by transmitting SNRM request directly from serial terminal??
i transmitt following request
7E A0 0F 03 21 93 D7 E4 81 80 03 06 01 80 6B 66 7E. but, meter is not responding.
i want to send this request directly from microcontroller to connect meter. is it possible through UART without implementing whole protocol.
Check your serial port settings.
SNRM is just one command that is used. I'm afraid that you have to implement whole protocol.
We have also ANSI C stack, but it's not open source.
asura22nov
9 years 1 month ago
Even i am getting the same result with Secure Premium 300 meters.
But the passwords given by the vendor for both LOW and HIGH authentication is still not helpful as it shows either authentication error or service write error : service unsupported.
8 years 11 months ago
You should ask if there is new firmware from the meter manufacturer.
BR,ยจ
bagdeparag
8 years 3 months ago
I am working on Genus 3-phase meter with DLMS Protocol.
I can check data using a Common Meter Reading Instrument.
Can I get the meter data using a Microcontroller?
Microcontroller
Please, If you have a new question, create a new topic.
I believe that you need to use our ANSI C stack. It's not open source.
Send an email to me if you are interested in it.
yogesh
6 years 5 months ago
In reply to Hello Sir, by kajal
Hello
Hello
Can i get secure 300 premium meter high authentication password?
In reply to Hello by yogesh
Hi yogesh,
Hi yogesh,
  • Toko Tiga Saudara | WA 083148835648
  • Tb. Laris Jaya | WA 083148835648
