  3. Connecting Landis+Gyr E250 Meter To DLMS Director Through Optical Port
Connecting Landis+Gyr E250 meter to DLMS director through optical port
By akhilp2602 , 11 December, 2017
I want to connect my Landis+Gyr E250 DLMS meter with DLMS director through optical port.
Does dlms director supports communication through optical port ?
if yes then how can i connect this ?
Please see attached log:
GXDLMSDirector 8.1.1712.0701
Log created PM 05:33:08
PM 05:33:10 Initializing serial connection.
PM 05:33:10 Send SNRM request.
7E A0 07 03 21 93 0F 01 7E
PM 05:33:10
7E A0 20 21 03 73 73 98 81 80 14 05 02 00 80 06 02 00 80 07 04 00 00 00 01 08 04 00 00 00 01 CE 6A 7E
PM 05:33:10 Parsing UA reply succeeded.
PM 05:33:10 Send AARQ request.
7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 02 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 1C 03 20 FF FF 80 AB 7E
PM 05:33:10
7E A0 2D 21 03 30 63 63 E6 E7 00 61 1F A1 09 06 07 60 85 74 05 08 01 02 A2 03 02 01 01 A3 05 A1 03 02 01 01 BE 06 04 04 0E 01 06 01 F7 68 7E
PM 05:33:10 Disconnect request
Gurux.DLMS.GXDLMSException: Connection is permanently rejected. No reason is given.
8 years 9 months ago
Try to select "Logical name Referencing". New Landis+Gyr meters are using Logical name Referencing.
akhilp2602
I have selected "Logical name Referencing". Now i am able to get some data. Thanks.
But i am getting only two parameters "Logical device name & Manufacturing number".
How can i get more data ?? How to read voltage and power of meter ??
Change authentication from None to Low. You need also set the password.
Then make the connection and select "Refresh" from "File" menu.
akhilp2602
Can you please tell me how to set password ?
When i choose Authentication to Low then client address also automatically changed to 11.
You need to ask right password from the meter vendor. In GXDLMSDirector meter settings it's under authentication level.
akhilp2602
It means i can't change or set password its already define ?
When i choose Authentication to Low then client address also automatically changed to 11. Can i change again to 10 or 11 is ok.
You can change the password after you have connected to the meter with the correct password.
Client address must be correct. I don't know what address your meter is using for Low authentication, but you are getting the error if that is wrong. :-)
