  3. Difficulty In Landis+gyr E250 To DLMSDirector
Difficulty in Landis+gyr E250 to DLMSDirector
By Snghndh , 5 August, 2017
I m trying to connect to my Landis+Gyr E250 DLMS meter with DLMS director with following settings but getting error
GXDLMSDirector 8.0.1706.1107
Log created 12:44:57 AM
12:45:04 AM Initializing Network connection.
12:45:04 AM Send SNRM request.
7E A0 07 03 21 93 0F 01 7E
12:45:09 AM Failed to receive reply from the device in given time.
at GXDLMSDirector.MainForm.Connect(Control sender, Object[] parameters)
Protocol: DLMS
Manufacturer: Landis+Gyr
Authentication: none
Address type: default
Wait time : 5
client address : 10
physical server: 1
Resend Count: 0
Host name - Laptop ip address
Port - 80
proctocol- TCP
Could you please help with this. I have also tried the default setting but it didn't work.
8 years 9 months ago
Are you sure from TCP/IP port? Sent data is correct.
Snghndh
In reply to Difficulty in Landis+gyr E250 to DLMSDirector by Kurumi
landis error
I changed the port to 4059 as mentioned in the client program. Then got the following error
Log created 1:19:26 PM
1:19:29 PM Initializing Network connection.
System.Net.Sockets.SocketException: No connection could be made because the target machine actively refused it
No one is listening that port. Can you check this from the meter manual?
You can try with 1000.
Snghndh
Tried port 1000 but same error. Looked at the meter manual but could only see 4059 which does not work.
Check is your TCP/IP module enabled. Problem is that your meter's TCP/IP socket is not working.
sheminasalan
4 years 3 months ago
Hi there, I want to read data
Hi there, I want to read data from the Landis Gyr E250. Have you been successful, Could you advise me how to achieve this?
In reply to Hi there, I want to read data by sheminasalan
Hi Shemin,
Hi Shemin,
Please, create a new topic if you have a new question and don't create multiple topics from the same question.
I'll answer your question after you have created a new topic.
