  3. Samgas Check Status
Samgas check status
By Ruggero Quargentan , 12 January, 2017
Gurux.Serial
Hello, i'm not able to have answer from a samgas without setting up comunication
in the device.
What does it mean checking status ?
What is the function that i can use ?
9 years 8 months ago
Samgas check status
Press Green button. Then move to SD. Values should be 01 01 01.
If they are, change as described on the manual.
Ruggero Quargentan
In reply to Samgas check status by Kurumi
Hello, i know this procedure
Hello, i know this procedure and it works.
I need to know if there is a way with the infrared probe to do this.
Do you know if there is a wake up sequence to send ?
thanks .
Samgas
We are using infrared probe. Just connect optical probe and check status as described.
Then you can read your meter.
murox23
9 years ago
Good morning;
Good morning;
i add a new post here because i'd like to know if there is some "work around" in order to keep alive the optical port without every time go phisically in front of meter just for "power on" the display going under SD status.
I ask this because i need to read data from meter periodically with a SCADA software that's disclocated in other area respect the meter.
If have any suggestion or also if there isn't possibility to do this please reply anyway at this answer.
Many Thanks in advance!
Have a nice day
Marco M.
9 years ago
In reply to Good morning; by murox23
Samgas check status
Please, create own topic if you have new question.
If you are not reading your meter continually try send keep alive message every 30 second (about).
It might keep connection up. Remember that this is using battery.
