  3. New Release Code
New release code
By vamsi , 16 May, 2017
Hi mikko ,
I used gurux new release and did the basi changes of
com /dev/ttyUSB0 and CGXDLMSClient cl(true)
i am getting the below error
InitializeConnection
<- 07:13:26 7E A0 07 03 21 93 0F 01 7E
-> 07:13:27 A0 1E 21 03 73 C3 7A 81 80
<- 07:13:27 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 1E 1D FF FF E7 25 7E
-> 07:13:27 7E 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E 00 00 00 00 00 00 00 00 00 00 00 00 00 00
AARQRequest failed 258.
InitializeConnection failed Invalid parameter..
if i commented
if ((ret = comm.InitializeConnection()) != 0)
TRACE("InitializeConnection failed %s.\r\n", CGXDLMSConverter::GetErrorMessage(ret));
// return 1;
CGXDLMSObjectCollection Objects;
if ((ret = comm.GetObjects(Objects)) != 0)
// return 1;
fallowing return 1
<- 07:14:42 7E A0 07 03 21 93 0F 01 7E
-> 07:14:42 7E 00 00 00 00 00 00 00 00
<- 07:14:42 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 1E 1D FF FF E7 25 7E
-> 07:14:42 7E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
GetAssociationView
<- 07:14:42 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 C1 00 0F 00 00 28 00 00 FF 02 00 91 53 7E
<- 07:14:42 7E A0 07 03 21 51 11 E4 7E
<- 07:14:42 7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 C1 00 00 00 01 51 BE 7E
<- 07:14:42 7E A0 07 03 21 91 1D 22 7E
<- 07:14:42 7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 C1 00 00 00 02 CA 8C 7E
-> 07:14:43 7E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
<- 07:14:43 7E A0 07 03 21 D1 19 60 7E
-> 07:14:43 7E 08 00 00 00 00 00 00 00
<- 07:14:43 7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 C1 00 00 00 03 43 9D 7E
terminate called after throwing an instance of 'std::length_error'
what(): basic_string::_S_create
Aborted
please guide us to over come this error
9 years 6 months ago
New release code
You must read data until packet is ready. GXDLMSClient::GetData return DLMS_ERROR_CODE_FALSE if all data is not send.
Check ReadDLMSPacket method.
vamsi
New release code
Hi Mikko ,
I checked with the ReadDLMSPacket method. I found the issue now its working fine with index 3 Thank you very much for your support.
pushpa from cyient team
New release code
Hi Pushpa,
Nice to hear. Happy coding.
