  3. Write Attribute : Value Ignored and Replaced By Zero
Write attribute : value ignored and replaced by zero
By angmokio , 12 May, 2017
I am trying to write an attribute, but whatever the value I enter in the field, DLMSDirector sends value 0 to my device.
See below log, where I wanted to write value of 900 to my Demand Register period attribute (8). I typed 900 in the GUI filed, then press enter (I hear the Windows bell sound).
I then click on the Write icon, and see the data being sent to my meter but value is 0 instead of 900.
On thing important is that my meter does not implement attribute 2 of Association LN object, so I created objects manually in the xml config file :
Kind Regards,
angmokio
9 years 6 months ago
10:44:24 Write object
00 01 00 01 00 01 00 12 C1 01 C1 00 05 01 00 01 04 00 FF 08 00 06 00 00 00 00
10:44:24 10:44:24.807 Sent 00 01 00 01 00 01 00 12 C1 01 C1 00 05 01 00 01 04 00 FF 08 00 06 00 00 00 00
10:44:25 10:44:25.697 Received 00 01 00 01 00 01 00 04 C5 01 C1 00
10:44:25 Received data
10:44:25 Read object DemandRegister
00 01 00 01 00 01 00 0D C0 01 C1 00 05 01 00 01 04 00 FF 08 00
10:44:25 10:44:25.697 Sent 00 01 00 01 00 01 00 0D C0 01 C1 00 05 01 00 01 04 00 FF 08 00
10:44:26 10:44:26.177 Received 00 01 00 01 00 01 00 09 C4 01 C1 00 06 00 00 00 00
10:44:26 Received data
We have made some changes. Re-start app it will say that there is a new version available.
Let me know if you still have problems.
angmokio
Unfortunately, this new
Unfortunately, this new version does not start properly :
GXDLMSDirector 8.0.1705.1502
Log created 13:30:46
13:30:47 System.NullReferenceException: Object reference not set to an instance of an object.<CR><LF> at GXDLMSDirector.MainForm.LoadFile(String path)<CR><LF> at GXDLMSDirector.MainForm.OpenMnu_Click(Object sender, EventArgs e)
Can you send your file to me by email? We'll check this ASAP.
We made an issue today. It's fixed. Restart GXDLMSDirector and update to nevest version.
  • Victorian | WA 083148835648
