  3. Reading OBIS Code Values Decimal Is Missing
reading OBIS code values decimal is missing
By vamsi , 4 May, 2017
I am trying to read indual OBIS code values ,ican able to read the value but decimal is missing .
i am using the below code to read OBIS value.
CGXDLMSVariant value;
CGXReplyData reply;
CGXDLMSObject pObject(OBJECT_TYPE_REGISTER, "1.1.1.8.0.255");
comm.Read(&pObject, 2, reply);
value = reply.GetValue();
printf("Register value is:(int) %d\n", value.iVal);
Below is my log
reading single registers started
<- 08:35:20 7E A0 19 03 41 F6 12 3D E6 E6 00 C0 01 81 00 03 01 00 20 07 00 FF 02 00 80 4E 7E
-> 08:35:20 7E 01 81 00 12 58 A5 B1 9F 00 00 01 0F 03 16 01 00 02 E1 76 00 00 00 00 88 FA FC
Voltage : 22693
<- 08:35:25 7E A0 19 03 41 18 62 33 E6 E6 00 C0 01 81 00 03 01 00 21 07 00 FF 02 00 AB 4A 7E
-> 08:35:25 7E C4 01 81 00 10 03 E8 B7 84 00 01 0F 03 16 01 00 02 E1 76 00 00 00 00 88 FA FC
Power Factor : 1000
<- 08:35:30 7E A0 19 03 41 3A 72 31 E6 E6 00 C0 01 81 00 03 01 00 1F 07 00 FF 02 00 D9 B4 7E
-> 08:35:30 70 7E 01 81 00 12 00 00 21 84 00 01 0F 03 16 01 00 02 E1 76 00 00 00 00 88 FA FC
Current : 0
<- 08:35:35 7E A0 19 03 41 5C 42 37 E6 E6 00 C0 01 81 00 03 01 00 01 08 00 FF 02 00 37 A5 7E
-> 08:35:36 B8 63 7E 81 00 06 00 00 00 29 00 01 0F 03 16 01 00 02 E1 76 00 00 00 00 88 FA FC
Cumulative Energy (Kwh) : 41
<- 08:35:41 7E A0 19 03 41 7E 52 35 E6 E6 00 C0 01 81 00 03 01 00 01 07 00 FF 02 00 CB CF 7E
-> 08:35:41 7E 01 81 00 10 00 00 99 C5 00 00 01 0F 03 16 01 00 02 E1 76 00 00 00 00 88 FA FC
signed Active power (KW) : 0
reading single registers ended
please guide me to solve the issue .
cyient team
9 years 6 months ago
reading OBIS code values decimal is missing Primary tabs
You must read scaler and unit before reading actual value. They are in attribute index 3.
vamsi
first i tried to read in attribute index 3. But its returning 0 and i am getting read register error,
i i use index 2 not getting read register error.
please give me suggestion to overcome this error.
pushpa
Try with this:
CGXDLMSRegister r("1.1.1.8.0.255");
comm.Read(&r, 3, reply);
comm.Read(&r, 2, reply);
vamsi
Hi mikko i tried with thi but i am getting the below error
gurux.dlms.client.bin: src/GXDLMSVarient.cpp:CGXDLMSVarient::ToDouble():Assertion '0' failed.
Aborted
please guide me in this
Reading OBIS code values decimal is missing Primary tabs
Are you sure that you data is correct. Send data looks good, but reply is invalid.
vamsi
I tried with even DLMS director i am getting the correct data . same we are reading voltage, current, powerfactor,kwh,kw reading through CGXDLMSClientExample.cpp rading values is correct.but we are missing decimal if i gave index 3 it returning 0 .
Can you send trace from send and received bytes to me by email. We can check this.
  • Victorian | WA 083148835648
