  3. DLMSDirector UDP Wrapper
By angmokio , 2 May, 2017
Hello Gurux team,
I am using version 8.0.1704.1901 and could not find how to interact with a meter implementing COSEM UDP transport, with WRAPPER layer.
Here is my settings :
- Start protocol : DLMS
- Media : net
- Hostname : xxx
- Host port : xxx
- protocol : UDP
- use serial port through ethernet : false
With this setting, DLMSDirector sends a UDP encapsulated SRNM frame to the specified IP address / port..
I would expect more a WRAPPER 8 bytes header followed by AARQ...
Am I doing something wrong or is this not yet supported ?
AngMo
9 years 6 months ago
Hi AngMo,
If you want to use WRAPPER, you must select "Manufacturers" under "Tools". Then select manufacturer and check that "Use IEC 62056-47" is checked. If SNRM message is sent, you are using HDLC, not WRAPPER.
angmokio
In reply to DLMSDirector UDP Wrapper by Kurumi
Thank you very much Mikko,
Thank you very much Mikko, works fine !
  • Tb. Laris Jaya | WA 083148835648
