  3. Error Reading Landis Gyr E650, CU-U52 Meter Data
Error reading Landis Gyr E650, CU-U52 meter data
By mostafiz789 , 20 April, 2017
Hi there,
Using C# I am trying to read data from a Landis Gyr E650, CU-U52 3G communication module meter. I can read data using DLMSDirector without any problem using settings as the attached logo image.
But when I am trying to read using the DLMS client example, on the first run program terminate with message “Unknown Error”. Then if I try to read again using DLMSDirector or example client program in both cases I am getting the error message “Insufficient memory to continue the execution of the program”, this error persists until I reboot the meter.
I have used the below command in client example
Gurux.DLMS.Client.Example.Net_2010.exe /m=lgz /h=xxx.xxx.xxx.xxx /p=1001
I also tried using following commands but no luck
Gurux.DLMS.Client.Example.Net_2010.exe /m=lgz /h=xxx.xxx.xxx.xxx /p=1001 /s=DLMS /client=16 /server=1
trace when getting "Unknown Error" at first run https://www.dropbox.com/s/mzgd3r75ifvh1o0/unknown-error-trace.txt?dl=0
trace when getting insufficient memory exception from the second run https://www.dropbox.com/s/94z05bb5h7oadc6/insufficient-memory-trace.txt…
log of DLMSDirector when getting insufficient memory exception https://www.dropbox.com/s/6bky9glfkw0hudw/insufficient-memory-log-for-d…
Please help to resolve the problem and suggest me anything I have to do. Thanks in advance
9 years 7 months ago
I updated the example. Get latest version from GitHub. Reason why GXDLMSDirector fails after that is because meter is in wrong state and it's sending invalid data.
mostafiz789
Thanks for your kind reply. After using the updated client example I am not getting the first exception which was returning "Unknown Error" message. But now I am getting "Insufficient memory to continue the execution of the program" exception message. Below is the console usage details of the client example. Please help me on it.
Initializing Network connection.
Parsing UA reply succeeded.
Parsing AARE reply succeeded.
Get available objects from the device.
----------------------------------------------------------------------------------+Read scalers and units from the device.
Disconnecting from the meter.
Insufficient memory to continue the execution of the program.
I read our L+G E650 and there are no problems. Can you send your trace to me by email. We'll check this.
mostafiz789
I have emailed the trace into [Email removed by admin]
9 years 6 months ago
We have fixed multiple reference read issue. Get latest version.
mostafiz789
Thank you for the update. I will use the latest one.
Mostafiz
  • Toko Bangunan Mahkota Jaya | WA 083148835648
