  3. How To Configure For Elster A1500
How to configure for Elster A1500
Profile picture for user Fatih
By Fatih , 20 April, 2017
Hello.
I have a Elster A1500 Meter with Serial Number 00391068
But I dont know Meter's Physical address, and I must connect via RS485 over transparent modem.
Modem IP is 192.168.2.250 and port 10001.
I'm connection Actaris/Itron modem very well wtih this configuration
Serial Number: 73032578
Physical address: 2578
Comm Options {
BaudRate: 9600,
Data Bits: 8,
Stop Bits: 1,
Parity: None,
Gurux Config : http://oi67.tinypic.com/11i382c.jpg
But I Don't know how to connect Elster A1500 Meter
Physical address: ????
Comm Options {
BaudRate: 300,
Data Bits: 7,
Stop Bits: 1,
Parity: Even,
Probably Gurux Config: http://oi66.tinypic.com/11bszkk.jpg
Where can I make mistakes
Thanks for the answers.
9 years 1 month ago
Elster A1500
Elster A1500 is using IEC 62056-21. You can't read that with DLMS.
You can find more info from here:
Fatih
9 years 1 month ago
Mean
Hello again. Thanks for the answer:
Is this mean "There is no way read with Gurux library"?
9 years 1 month ago
Elster A1500
Hi Fatih,
Yes, we are not supporting IEC 62056-21.
You must ask this from manufacturer.
Fatih
9 years 1 month ago
Thanks ^_^
Thanks ^_^
fsimja
9 years ago
Reading A1500 with RS485 electrical interface
Hello, I am trying to read out Elster meter, using IEC 62056-21. I use standard configuration for the serial port but the meter never returns anything. Does anyone has any experience with this matter?
thanks
9 years ago
Reading A1500
Check this link.
http://www.gurux.fi/node/5415
I updated how to start communicate with Elster A 1500 and A 1700 meters.
