  3. Cannot Add New Authentication Types To a Manufacturer Through The GUI
Cannot add new authentication types to a manufacturer through the GUI
By coppice , 10 April, 2017
In GXDLSMDirector, if I choose Tools->Manufacturers->[some maker]->edit, the Addressing Authentication selection box only shows the subset of authentication types the manufacturer supports. There doesn't seem to be a way to add a new authentication type to a manufacturer through the GUI. I have to exit its XML file, and add the new authentication type there.
Once the new authentication type is added in the XML, it can be configured through the GUI
9 years 7 months ago
You are right. At the moment authentication types must modify from xml.
I'll add this to work list, but priority is low because this is not done often.
