  3. GXDLMSDirector Landys+Gyr Issue
By mtinner , 10 April, 2017
I'm trying to read an E450 Meter from Landys+Gyr with the GXDLMSDirector Version 8.0.1704.070.
I can read the meter with MAP110 so the serial settings and the used password should be correct.
For GXDLMSDirector i used the following settings:
Manufacturer: Landis+Gyr
Start Protocol: DLMS
Media: Serial
Authentication: Low
Password: (the one working with Map110)
Client Address: 11
When i try to connect i get this error:
Insufficient memory to continue the execution of the program.
This is the log:
GXDLMSDirector 8.0.1704.0701
Log created 14:55:51
14:55:59 Initializing serial connection.
14:56:00 Send SNRM request.
7E A0 12 03 23 93 49 9F 81 80 06 05 01 CA 06 01 80 6C A6 7E
14:56:00 Received data
7E A0 1E 23 03 73 7B CF 81 80 12 05 01 CA 06 01 CA 07 04 00 00 00 01 08 04 00 00 00 01 C7 AC 7E
14:56:00 Parsing UA reply.<CR><LF>81 80 12 05 01 CA 06 01 CA 07 04 00 00 00 01 08 04 00 00 00 01
14:56:00 Parsing UA reply succeeded.
14:56:00 Send AARQ request
7E A0 44 03 23 10 56 B7 E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 02 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 31 32 33 34 35 36 37 38 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 5C 03 20 FF FF AA 40 7E
14:56:07 Received data
7E A0 07 23 03 31 AF 94 7E
14:56:07 Parsing AARE reply<CR><LF>
14:56:07 Disconnect request
System.OutOfMemoryException: Insufficient memory to continue the execution of the program.
at GXDLMSDirector.MainForm.Connect(Control sender, Object[] parameters)
Has someone an idea how to solve this issue?
What is the meaning of the client address? Can the right address be found out with Map110?
I can read the Landys+Gyr E350 without authentication so thanks for the good work there!
Thanks!
9 years 6 months ago
Can you read your meter with authentication level None?
If client address is wrong meter is not reply.
If pw is wrong your meter is reply that pw is wrong.
If you can get trace from Map110 I can get correct settings for you.
We are reading E650 with those settings. L+G has made some changes for some meters.
mtinner
Dear Mikko
Dear Mikko
Thanks for the fast answer. No the meter can't be read without authentication also with Map110 its also not possible to read the meter without authentication.
Here is the beginning of the map110 log: (I replaced the password with 00000000)
3409283932ms - DLMS Open
3409283932ms - DLMS set State: OPENING
3409283932ms - DLMS Init ShortName CommandHandler
3409283932ms - HDLC Open
3409283964ms - HDLC wait 200 ms
3409284166ms - HDLC StartOpenEvent is set
3409284166ms - HDLC set State: OPENING
3409284166ms - HDLC StartDelay 25
3409284166ms - HDLC S-> SNRM-Frame SrcAdr=1 DestAdr=1 SendFrSize=248 RecFrSize=248 Poll=True FrameValid=False
3409284198ms - HDLC S-> 7EA01E0303934E2B8180120501F80601F807040000000108040000000155B67E
3409284198ms - HDLC Start Frame Transfer
3409284229ms - HDLC Frame transferred
3409284322ms - HDLC StartDelay 25
3409284322ms - HDLC R<- 7EA01E03037340CC8180120501000601CA070400000001080400000001255A7E
3409284322ms - HDLC R<- UA-Frame SrcAdr=1 DestAdr=1 SendFrSize=0 RecFrSize=202 Poll=True FrameValid=True
3409284322ms - HDLC Frame received
3409284322ms - HDLC Handle received Frame
3409284322ms - HDLC set State: OPEN
3409284322ms - DLMS set State: AUTHENTICATION
3409284322ms - DLMS S-> COSEM AARQ (with ACSE Requirements)
3409284322ms - DLMS dlms SendReceive
3409284322ms - DLMS S-> 603980020780A1090607608574050801028A0207808B0760857405080201AC0A80083030303030303030BE0F040D01000000065F04001C13200000
3409284322ms - HDLC HDLC DATA EXCHANGE
3409284322ms - HDLC StartSendEvent is set
3409284322ms - HDLC set State: SEND
3409284322ms - HDLC S-> I-Frame SrcAdr=1 DestAdr=1 RecSeqNr=0 SendSeqNr=0 Segmentation=False Poll=True FrameValid=False
3409284354ms - HDLC S-> 7EA047030310A8B1E6E600603980020780A1090607608574050801028A0207808B0760857405080201AC0A8008303030303030BE0F040D01000000065F04001C13200000FCE67E
3409284354ms - HDLC Start Frame Transfer
3409284432ms - HDLC Frame transferred
3409284525ms - HDLC StartDelay 25
3409284525ms - HDLC R<- 7EA825030330186AE6E7006128A109060760857405080102A203020100A305A103020100E2F57E
3409284525ms - HDLC R<- I-Frame SrcAdr=1 DestAdr=1 RecSeqNr=1 SendSeqNr=0 Segmentation=True Poll=True FrameValid=True
3409284525ms - HDLC Frame received
3409284525ms - HDLC Handle received Frame
3409284525ms - HDLC set State: OPEN
3409284525ms - HDLC StartReceiveEvent is set
3409284525ms - HDLC set State: RECEIVE
3409284525ms - HDLC S-> RR-Frame SrcAdr=1 DestAdr=1 SeqNr=1 Poll=True FrameValid=False
3409284556ms - HDLC S-> 7EA00703033194977E
3409284556ms - HDLC Start Frame Transfer
3409284556ms - HDLC Frame transferred
3409284650ms - HDLC StartDelay 25
3409284650ms - HDLC R<- 7EA01A03033221EDBE0F040D0800065F04001C022005DCFA00550F7E
3409284650ms - HDLC R<- I-Frame SrcAdr=1 DestAdr=1 RecSeqNr=1 SendSeqNr=1 Segmentation=False Poll=True FrameValid=True
3409284650ms - HDLC Frame received
3409284650ms - HDLC Handle received Frame
3409284650ms - HDLC set State: OPEN
3409284650ms - DLMS R<- 6128A109060760857405080102A203020100A305A103020100BE0F040D0800065F04001C022005DCFA00
3409284650ms - DLMS check ACSE-Response Values
3409284650ms - DLMS set State: OPEN
3409284666ms - COSEM Add Type=Read Obj=0xFD08 Sel=0 Data:null
3409284666ms - COSEM Add Type=Read Obj=0xFF08 Sel=0 Data:null
3409284666ms - COSEM Execute ShortName Commands
3409284666ms - DLMS set State: SENDRECEIVE
3409284666ms - COSEM Read: 0xFD08, 0xFF08,
3409284666ms - DLMS dlms SendReceive
3409284666ms - DLMS S-> 050202FD0802FF08
3409284666ms - HDLC HDLC DATA EXCHANGE
Thanks a lot.
Greetings Marco
Landys+Gyr E450
Change Client address to 1 and make a new try.
mtinner
Still get the same error.
Still get the same error. Heres the log:
GXDLMSDirector 8.0.1704.1101
Log created 08:23:38
08:23:45 Initializing serial connection.
08:23:45 Send SNRM request.
7E A0 07 03 03 93 8C 11 7E
08:23:45 Received data
7E A0 1E 03 03 73 40 CC 81 80 12 05 01 80 06 01 CA 07 04 00 00 00 01 08 04 00 00 00 01 30 7E 7E
08:23:45 Parsing UA reply.<CR><LF>81 80 12 05 01 80 06 01 CA 07 04 00 00 00 01 08 04 00 00 00 01
08:23:45 Parsing UA reply succeeded.
08:23:45 Send AARQ request
7E A0 44 03 03 10 65 94 E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 02 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 31 32 33 34 35 36 37 38 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 00 00 FF FF 0E 64 7E
7E A8 25 03 03 30 18 6A E6 E7 00 61 1F A1 09 06 07 60 85 74 05 08 01 02 A2 03 02 01 01 A3 05 A1 03 02 01 01 37 41 7E
08:23:45 Parsing AARE reply<CR><LF>61 1F A1 09 06 07 60 85 74 05 08 01 02 A2 03 02 01 01 A3 05 A1 03 02 01 01
08:23:45 Disconnect request
System.Exception: Not enough data.
No this is not a same error. Your meter is using so small frame size that AARE message is not fit to one packet. We have fixed this and there is a new version from GXDLMSDirector available.
Start your GXDLMSDirector and restart it. It will say that there is a new version available. Install that and it works.
mtinner
Great!
Great!
In addition i had to enable Logical Name Referencing after that is was working fine. Thanks a lot for your help.
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
