  3. HLS With Static Client Challenge, F(CtoS) Fail
HLS with static client challenge, f(CtoS) fail
By taishyang , 31 March, 2017
Hi sir, for Manufacture = Indian Standard, HLS(2)=AES128
if client challenge = 1234567890ABCDEF, KEY = HHHHHHHHHHHHHHHH
1.which item we should input the KEY? Block Cipher Key or Authentication Key
2.which item we should input the service challenge?
3.the app should send packet for f(CtoS) as below
7E A0 2B 03 61 32 8D EB E6 E6 00 C3 01 C1 00 0F 00 00 28 00 00 FF 01 01 09 10 E9 15 92 8B E1
2B 36 F6 3E 97 CA C4 C2 0A 18 70 08 7B 7E
but we get
7e a0 2c 03 61 32 ac bc e6 e6 00 c3 01 c1 00 0f 00 00 28 00 00 ff 01 01 09 11 10 00 00 00 00 10
80 20 49 e3 ae 3f 74 a6 17 d9 03 a2 fd 7e
the packet length 0x2c is wrong, due to string length 0x11 is wrong, it should be 0x10
and f(CtoS) should be E9 15 92 8B E1 2B 36 F6 3E 97 CA C4 C2 0A 18 70
please help to confirm, thanks
9 years 7 months ago
You can input key as password. You do not need to change anything to Secured Connection tab.
Set Authentication to High.
taishyang
In reply to HLS with static client challenge, f(CtoS) fail by Kurumi
Hi sir, thanks for your reply
Hi sir, thanks for your reply, I input
Password=HHHHHHHHHHHHHHHH
Challenge=31323334353537383930414243444546 = (1234567890ABCDEF)
the log as below
TX:
7E A0 4C 03 61 10 58 27 E6 E6 00 60 3E A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 31 32 33 34 35 36 37 38 39 30 41 42 43 44 45 46 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 1E 1C FF FF F1 02 7E
RX:
7E A0 58 61 03 30 07 51 E6 E7 00 61 4A A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 0E 88 02 07 80 89 07 60 85 74 05 08 02 05 AA 0A 80 10 56 61 6E 67 6F 54 65 63 68 2D 48 4C 53 53 32 43 BE 10 04 0E 08 00 06 5F 1F 04 00 00 18 1D 00 B2 00 07 1E 52 7E
The app didn't send action 0xc3 for next step? please help to check, thanks.
Are you using GXDLMSDirector or own app?
taishyang
Hi sir, yes I'm using
Hi sir, yes I'm using GXDLMSDirector, the app means GXDLMSDirector
taishyang
Hi sir, did you have any
Hi sir, did you have any updates?
Could you share a example for 4 steps HLS with static client challenge? thanks
step 1. C->S
step 2. S->C
step 3. f(CtoS)
step 4. f(StoC)
Check Authentication using challenge from here:
http://www.gurux.fi/Gurux.DLMS.Client
You can set static challenge at GXDLMSDirector in "Secured connections" tab.
If you are making own app, set CtoSChallenge.
taishyang
Hi sir, thanks for your reply.
sorry you're you are misunderstanding.
I mean that, I used GXDLMSDirector.exe with static client challenge
assuming client challenge = 1234567890ABCDEF, KEY = HHHHHHHHHHHHHHHH
so I input
[Device Setting]
Authentication = High
Password = HHHHHHHHHHHHHHHH
[Secured Connections]
Challenge = 1234567890ABCDEF
Log:
[GXDLMSDirector send]
[Meter reply]
My question is
The GXDLMSDirector didn't send action 0xc3 for next step? why?
taishyang
Hi sir, do you have any
Hi sir, do you have any updates? thanks
9 years 6 months ago
Can you send GXDLMSDirector log to be by email? There should be no reason why action is not send.
taishyang
9 years 4 months ago
log file
GXDLMSDirector 8.0.1706.1107
Log created 下午 02:01:23
下午 02:01:25 Initializing serial connection.
下午 02:01:25 Send SNRM request.
7E A0 14 03 61 93 05 A1 81 80 08 05 02 00 B2 06 02 00 B2 30 55 7E
下午 02:01:25 Received data
7E A0 20 61 03 73 05 9E 81 80 14 05 02 00 B2 06 02 00 B2 07 04 00 00 00 01 08 04 00 00 00 01 D9 B7 7E
下午 02:01:25 Parsing UA reply.<CR><LF>81 80 14 05 02 00 B2 06 02 00 B2 07 04 00 00 00 01 08 04 00 00 00 01
下午 02:01:25 Parsing UA reply succeeded.
下午 02:01:25
7E A0 4C 03 61 10 58 27 E6 E6 00 60 3E A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 31 32 33 34 35 36 37 38 39 30 41 42 43 44 45 46 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 1E 1D 00 B2 0C 3E 7E
System.IndexOutOfRangeException: 索引在陣列的界限之外。
於 GXDLMSDirector.GXDLMSDevice.InitializeConnection()
於 GXDLMSDirector.MainForm.Connect(Control sender, Object[] parameters)
You want to use High Authentication:
http://www.gurux.fi/GuruxDLMSTranslator?pdu=603EA1090607608574050801018…
But your meter wants to use GMAC authentication.
http://www.gurux.fi/GuruxDLMSTranslator?pdu=614AA109060760857405080101A…
You must set correct GMAC settings to "Secured Connections" tab.
Ask correct settings from the manufacturer.
taishyang
it working now, thanks for
it working now, thanks for your help
Thanks for let me know that it helped.
  • Victorian | WA 083148835648
