  3. Retrieving Multiple Attributes At Once
Retrieving multiple attributes at once
By ykhristo , 27 March, 2017
Dear sir,
is it possible to retrieve multiple attributes (e.g. entries in use, capture objects, and data buffer of a profile generic) of a certain object in a single order using Gurux C++?
best regards.
9 years 8 months ago
First you must check is your meter supporting Multiple references or Access services.
http://www.gurux.fi/Gurux.DLMS.Conformance
If your meter is supporting Multiple references you can use ReadList method. Access functionality is not yet added to C++ version.
ykhristo
9 years 7 months ago
Thank you so much sir.
  • Toko Bangunan Mahkota Jaya | WA 083148835648
