  3. Problem of HLS Peer Authentication With GMAC
problem of HLS peer authentication with GMAC
By twinkle__star , 25 March, 2017
I'm developing a smart meter, and referencing this open source code.
I've tested this code with parameters of 9.2.4.8.4 example in Green Book 7 as following:
System Title : 4D4D4D0000BC614E
Frame Counter : 01234567
Initialization Vector : 4D4D4D0000BC614E01234567
Block cipher key (global) : 000102030405060708090A0B0C0D0E0F
Authentication Key : D0D1D2D3D4D5D6D7D8D9DADBDCDDDEDF
Security control : 10
CtoS : 4B35366956616759 (“K56iVagY”)
StoC : 503677524A323146 (“P6wRJ21F”)
and GXDLMSChipperingStream class constructor described as following:
GXDLMSChipperingStream gcm = new GXDLMSChipperingStream(
Security.Authentication,
true, // encrypt
new byte[16] { 0x00, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09, 0x0A, 0x0B, 0x0C, 0x0D, 0x0E, 0x0F }, // block cipher key (AK)
new byte[25] { 0x10, 0xD0, 0xD1, 0xD2, 0xD3, 0xD4, 0xD5, 0xD6, 0xD7, 0xD8, 0xD9, 0xDA, 0xDB, 0xDC, 0xDD, 0xDE, 0xDF 0x4B, 0x35, 0x36, 0x69, 0x56, 0x61, 0x67, 0x59}, // aad (0x10 + AK + CtoS)
new byte[12] { 0x4D, 0x4D, 0x4D, 0x00, 0x00, 0xBC, 0x61, 0x4E, 0x01, 0x23, 0x45, 0x67 }, // IV
null);
byte[] plaintext = new byte[] { 0x4B, 0x35, 0x36, 0x69, 0x56, 0x61, 0x67, 0x59 };
gcm.Write(plaintext);
byte[] result = gcm.FlushFinalBlock();
Console.WriteLine(BitConverter.ToString(a.Tag));
The result tag must be as following in Green Book 7:
T (SC II AK II CtoS) FE1466AFB3DBCD4F9389E2B7
T (SC II AK II StoC) 1A52FE7DD3E72748973C1E28
but actually different resulted.
AA-49-7E-EB-16-BB-49-09-3B-2C-B9-39
What's wrong with my code?
please help...
9 years 8 months ago
GMAC
Do you have latest version from source codes? Then check your Invocation counter. I do not have Blue Book here but in my mind it's reversed.
twinkle__star
Invocation counter is
Invocation counter is contained in last 4 bytes of AAD field(but I was wrong to comment //IV, Sorry), and I've downloaded source code at 2017-3-24 from Github.
I've thought that there's a problem of parametering gcm.
In the book, only authentication does not contain plaintext, but GXDLMSChipperingStream.Write(byte[]) requires plaintext. I've tested with non-plaintext (new byte[]{}), but result is wrong, too.
Maybe other problem with my parameterizing?
Mr. kurumi, Please help me to get the correct result.
Thank you in advance sincerely.
GMAC
I check this from Green Book. If I set parameters from the GB 8-2 I get right reply.
target.Ciphering.SystemTitle = Helpers.HexToBytes("4D4D4D0000000001");
server.Ciphering.SystemTitle = Helpers.HexToBytes("4D4D4D0000BC614E");
//Invocation counter
target.Ciphering.InvocationCounter = 0x00000001;
server.Ciphering.InvocationCounter = 0x01234567;
target.Ciphering.BlockCipherKey = Helpers.HexToBytes("000102030405060708090A0B0C0D0E0F");
server.Ciphering.BlockCipherKey = Helpers.HexToBytes("000102030405060708090A0B0C0D0E0F");
target.Ciphering.AuthenticationKey = Helpers.HexToBytes("D0D1D2D3D4D5D6D7D8D9DADBDCDDDEDF");
server.Ciphering.AuthenticationKey = Helpers.HexToBytes("D0D1D2D3D4D5D6D7D8D9DADBDCDDDEDF");
target.Authentication = Authentication.HighGMAC;
target.CtoSChallenge = Helpers.HexToBytes("4B35366956616759");
server.StoCChallenge = Helpers.HexToBytes("503677524A323146");
http://www.gurux.fi/GuruxDLMSTranslator?pdu=C30181000F0000280000FF01010…
twinkle__star
Hi, Mr. kurumi.
Hi, Mr. kurumi.
I've tested with 3 Security of Authentication, Encryption, Authentication_Encryption.
And the results of Encryption, Authentication_Encryption were correct.
Only Authentication's result was wrong.
Could you tell me why this happened?
twinkle__star
Source Code Here.
Source Code Here.
byte[] block_cipher_key = StringToByteArray("000102030405060708090A0B0C0D0E0F");
byte[] authentication_key = StringToByteArray("D0D1D2D3D4D5D6D7D8D9DADBDCDDDEDF");
byte[] system_title = StringToByteArray("4D4D4D0000BC614E");
uint frame_counter = 0x01234567;
byte[] plain_text = StringToByteArray("4B35366956616759");
byte[] aad = GetAuthenticatedData(Security.Authentication, authentication_key, plain_text);
true,
block_cipher_key,
aad,
GetNonse(frame_counter, system_title),
null
gcm.Write(plain_text);
byte[] cipher_text = gcm.FlushFinalBlock();
Console.WriteLine($"Tag ({gcm.GetTag().Length}) : {BitConverter.ToString(gcm.GetTag())}");
Result :
Tag (12) : 79-16-34-63-74-90-FD-5C-3A-EA-6A-0F
twinkle__star
I have solved this problem!!!
================ SOLVED !!!! ==================
I'm very sorry to annoy you about this problem.
I've missed that if Security is Authentication, MUST have not to call Write(byte[]).
The problem is solved.
Thank you for you attention to me.
Please help me in advance.
GMAC
I'm glad that this is solved.
zhihongzeng
9 years 2 months ago
i want to the soure codes of aes_gmac(for C)
hello :
twinkle__star
I have the same problem with kurumi at work .i have see you tell kurumi "http://www.gurux.fi/GuruxDLMSTranslator?pdu=C30181000F0000280000FF01010…; now i want to the soure codes of aes_gmac,can you give me,my email :[Email removed by Admin] Thank you twinkle__star.
Wish best Regards zhihong zeng.
vineet
8 years 7 months ago
In reply to GMAC by Kurumi
Target challenge does not match
Dear Mikko
I must be making some dumb mistake but I have several times on GuruX Translator .. and ...
The reply for server challenge is correct.
But the reply for the target challenge does not come out to be correct ...
System Title: 4D4D4D0000BC614E
Invocation Counter 01234567
Challenge: 4B35366956616759
Expected Challenge String: FE 14 66 AF B3 DB CD 4F 93 89 E2 B7
GuruX generated Challenge String: 55 C8 77 21 3C D8 0F 7C C4 13 7E 2E
Could you please help me here?
Many thanks.
Profile picture for user pardeepk3264
pardeepk3264
6 years 9 months ago
Please help me to selection
Please help me to selection of function in C language
which function I will used for get a Expected Challenge String. as above mentiond
In reply to Please help me to selection by pardeepk3264
Hi RAJPURA,
Hi RAJPURA,
I'll answer your question there.
